Question about Creative Labs Audio Players & Recorders
Suddenly no sound, lights on, think jacks in right but not sure,speaker jack into orange hole and line in jack into blue hole
  • Creative Labs Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 22, 2011
Unpluged my computer to get repaired, have 3 different speaker type plug ins the back, don't remember which one to use. Their color coded, blue-green- pink
In many cards, the microphone connector will be pink, the speakers or line out or headphone will be lime green, and the stereo line in will be light blue. Additional jacks may be present on newer soundcards for rear and mid surround speakers.
This is a widely accepted color standard for computer sound card input and output jacks, but connector colors may vary between different brands. If you think you have a nonstandard card, consult your soundcard's manual or the manufacturer's web site before making any connections.
Apr 13, 2011 | Computers & Internet
I have new computer. My Yamaha speakers Model YST-M7 are older. There is power to the speakers but no sound is coming out. Not sure which hole to plug them into. My choices are: rear l/r surround...
Use the "line-out" connector (usually it's light green in color), and if there is an audio control panel application, make sure the sound circuitry is set for "two-channel" or regular stereo speaker operation. It can be confusing on newer computers which have surround-sound capability built in. Depending on how you set up the sound, the jacks can have different functions. But the line-out jack is what you'll use with basic speakers such as yours.
Dec 28, 2010 | Yamaha YST-M7 Computer Speakers
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Computers & Internet
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
How do I use altec lansing acs40 with a laptop?
Fairly easy really. You'll need to buy a jack to jack AUX cable. Single point for stereo needed and a headphone jack on the laptop.
The left hand and right hand speakers are slightly different. The right hand speaker only has a cord coming out the back of it and no AUX points.
The right hand speakers has a series of small jack points.
The first hole is the adaptor plug that has to be plugged into mains socket, then the 1st hole marked SPKR has to have a jack to jack cord going from that speaker to the other one. The last two holes marked "A" and "B" give you the option to put two jack to jack AUX sound cables in.
To get it into your laptop, you'll need ONE AUX jack to jack cable and fit it into the point at the back marked "B" and then through the headphone socket on your laptop. You will then have sound.
Make sure to remember to put the system on by the push button switch on the back of the left hand speaker. The speaker system also has another rotary switch on at the front of the speaker.
I've had these speakers for well over 10 years - brilliant sound quality and very durable. Hope it has helped you!
May 04, 2010 | Altec Lansing Multimedia Computer Speakers
How can i connect speaker on my computer
You need to find powered speakers that have an aux out so you can just plug it into your headphone jack,
Nov 08, 2009 | Audio Players & Recorders
NO SOUND
They should be plugged in and turned on when you power up your system.They should be plugged into the green jack (line out). You then may have to check settings in control panel for your sound card's properties to see if digital only is checked. Try it both ways. Hope this helps.
May 22, 2009 | Boston Acoustics BA735 Computer Speakers
No sound
Restart your PC. Check all the connections in the back of the main base, and check that you have plugged the connector into the headphone jack and not a microphone or line in jack by accident
Apr 13, 2009 | Dell 5650 Computer Speakers
Trying to reconnect a set of Harman Kardon candlestick computer speakers to a Dell Dimension E520 computer. I got three plugs and dell has 6 holes...what the heck goes where? Nothing I seem to try works...
Hi rjlevesque
For the speakers, you need only connect to the GREEN jack at the back of your computer. It's OK to leave the others blank.
Your two HK speakers will, with one wire, connect to each other and, w/ another wire (usually having a GREEN connector on the end), connect to the computer.
I'm not sure what the 3rd wire is unless it's (1) the power connector or (2) for connecting to a sub-woofer.
Does the speaker set include a sub-woofer? Or does it include a "surround sound" or 3rd speaker?
You can find pics & symbols (the symbols are helpful if your sound card jacks are not color-coded) for (3) of the most common audio connections HERE.
Usually the color of the connector on the wire is matched to the sound card jack w/ the same color. (green to green; pink to pink; blue to blue).
green = speakers
pink = mic
blue = line in
Make sure you are connecting to the active sound connectors - the ones you used b4 the HK speakers.
If you have "integrated audio" (audio that is built into the motherboard) and you have an audio expansion card installed on the computer as well, one may be disabled or not selected in your computer's audio configuration.
If that's the case (that you have two sets of audio jacks to choose from), try connecting the speaker wire from the HK speakers 1st to the green jack (or the jack marked w/ the symbol of a speaker) at the bottom of your computer. (There'll only audio jacks here if there is an audio expansion card installed on your computer.)
If that is the case, there'll be other (usually) colored jacks running horizontally next to the speakers jack.
If you still have no sound, connect the speaker wire to the GREEN jack that is (usually on Dells) up by your PS2 (round - one purple and one green) keyboard and mouse connectors (also at the back of your computer). The other jacks in that set (of audio jacks) will be situated vertical to one another and on the left-most side at the back of your computer.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
No sound through speakers, but ok through headset
u have a problem either on the speaker or on the sound amplifying circuit. signal coming from the earphone jack is not amplified. check the speaker first. if its ok then check the audio output ic(integrated circuit). good luck!
Jan 31, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
82 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
