Question about NEC AccuSync LCD93V LCD Monitor
It does all the time auto adjust proceeding - NEC AccuSync LCD93V LCD Monitor
    New Friend:
I found a little trick about this problem...i had the same issue and the only thing that really helped me was..
•Go to "Control Panel"
•Select the "Adjust screen resolution"
•Now you have just to drop your Resolution BUT you have to do the trick here...
When you will press the Apply for the low Resolution in the same time while pressing the OK/Apply you have to push the button "SELECT" in your screen
Notice: Rember you have to do it in same time!
Greetings Bill!
Posted on Oct 25, 2015
2008 nissan stereo auto volume adjustment
open the MENU and go to the setup for AUDIO, balance, treble, etcc and proceed according. However will be a great idea that you read the owner manual for better solution.
God bless you
Jul 17, 2013 | 2005 Nissan Pathfinder
2008 nissan pathfinder stereo auto volume adjustment
go to the MENU, and then to AUDIO setup, and proceed according with Balance, Bass, etc However you must read your owner manual for better illustration.
God bless you
Jul 17, 2013 | Cars & Trucks
How do I adjust the color
Hello
To adjust colour and other picture adjustments
[1] Press "Menu" key to display the main menu.
[2] Use cursor UP/DOWN keys to hilight [green]; Picture or sound ; whatever you wants to adjust, and press ENTER.
[3] Use cursor UP/DOWN keys to hilight [green] AUTO [for factory settings] or MANUAL to set picture settings according to your taste. Here you have to hilight MANUAL as you wants to set it mannualy. Press ENTER after selecting MANUAL.
[4] User cursor UP/DOWN keys to select the option you wanted to change.
then cursor keys to make adjustments of the selected option parameter according to your taste.
[5] When you have finished all the adjustments according to your taste, press EXIT key to return to normal tv viiewing. This way you can adjust the sound parameters also. Proceedings are all the same, but the option choose to hilight [green] must be sound. That is all. Ok.
Jan 12, 2011 | Sanyo DP26746 26 in. LCD Television
The image on my screen moves around. the colors are fine but the image shifts from left to right then up and down how can i fix this problem
do you see a message 'Auto adjust' from time to time? this is only if you have a 'auto adjust' function, maybe a problem with the functionality. Try doing auto adjust else you need a repair!
Dec 15, 2010 | Televison & Video
He time on my motorola shows 16:10. How do I correct The Time please?
Most Motorola phones have a feature of "auto-adjustment" for correcting time. If this feature is enabled then your phone will not show the option to set the time manually. In order to correct the time manually you need to disable the "auto adjustment" feature. After disabling this manual adjustment settings will automatically come.
Hope this will help....cheers:)
Oct 01, 2010 | Motorola Cell Phones
The auto ajesment on the rear left brake will adjest untell it will lock up on my 95 ford f 350 it has did this scent it was new
sounds like it has the wrong adjuster in it possibly a right hand adjuster was installed at the factory on the left side
Nov 04, 2009 | 1995 Ford F350
New computer won't start up stuck in auto adjustment mode
You can ask the computer tech what he did to fix you computer and post that info here.
Or, check out this tutorial on starting in Safe Mode to find and fix problems.
May 02, 2009 | Computers & Internet
Handbrake problem
hi fro uk when you reassembled brake shoes? did you notice the tubular bar just below b/cylinder? it fits between the two shoes and has a toothed wheel on the treaded side(l/h) this is the auto adjuster ie as tooth wheel is rotated it extends the treaded side thus adjusting shoes to drum o/k? this is normally done auto by the small lever below but when fitting new shoes you must adjust this rod with tooth wheel and keep trying drum fitting when you can fit drum /just? fit and press brake to centralise shoes to drum then adjust again if req'd so that drum fits and rotates withh shoes not binding ?? do both sides THENyou willdrums fitted you will feel b/pedal is improved ie less travel on braking ? SO FIRST THING YOU HAVE TO DO IS SLACKEN OFF H/BRAKE CABLE ADJUSTMENT /SLACK ? then proceed with the above instruction afterwards if you do as above then you pull h/brake up one notch ? then adust slack from cable to light tension release h/brake and ensure wheels rotate freely when you apply h/brake it should hold on approx four//five notch ? hope this helps
Feb 04, 2009 | Hyundai Motor 1998 Accent
Need to Auto Adjust Envision 20" monitor every time
yes it may be a memory problem inside the monitor replace the memory from technical person
or refer the manual with the monitor some trick may given so that push menu twotimes or operate like mobole button
Nov 09, 2008 | Proview PX-986 19" CRT Monitor
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
NEC AccuSync LCD93V LCD Monitor Logo
658 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
