How do I change the fax number that is printed on the sent faxes?
  • 106 Answers
Usually it is fax settings (press menu and find the corresponding item).
Posted on May 22, 2011
How can i Troubleshooting Fax Issues on my hp officejet 4650?
If you get issues like Faxes can be sent but not received, Faxes can be received but not sent error on your Printer then follow the given troubleshooting steps.
Solution to Faxes can be sent but not received
    ·Initially, you have to check any of the telephone line services are enabled. There are,
    1.Voice Mail
    2.Call Waiting
    3.Billing Tone
    4.Privacy Block
    5.Security Screen
    6.Anonymous Call Rejection
    7.Privacy Manager
    ·These may block your incoming faxes. So disable the above features.
    ·If you are using Automatic fax reception option on your fax recipient, then check whether the Automatic Answering feature is enabled or not, if it enables means Auto Answer green LED should be on.
    ·Check the Ring to Answer value.
    ·If the value set as answering machine that causes the issue on fax reception. Then change the value to Fax or FaxTel
    ·Now, you can receive the incoming faxes.
    Solution to Faxes can be received but not sent
      ·Check whether the dialed number is correct or not. Every one of the digits required to make a telephone call from a similar line must be dialed.
      ·On the off chance that the Speed Dial has been used for dialing or the fax has been sent from your PC, print the page to be faxed and dial the number physically on the HP Fax front board.
      ·Check whether the Tone Dialing is set on you HP Fax product.
      ·In the event that faxes are sent effectively from the HP Fax front board, but, it's fail when sent from the PC, test the communication between the HP Officejet 4650 printer and your PC by tapping the Status button in the HP Director application, or attempting to print some record.
      ·If the printing fails to send the fax, then check whether all cables (from system to HP Officejet 4650 Printer) are connected properly, if it's not then connect it properly.
      ·Now restart it. On the off chance that communication still can't be set up, Call Printer customer service team via Toll-Free: +1-800-836-3987 to resolve your HP Officejet 4650 fax issues.
Jun 27, 2017 | HP Office Equipment & Supplies
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Need to confirm details of when and what number a fax was sent approx 15 days ago.
The only way to check old transfer info for faxes is by printing out the journal. The way to do this varies from fax to fax, but most often is either with it's own button "reports" (and then "fax journal"), or by choosing "print reports" in the regular menu. The journal is emptied during power outs, so if you have had a power failure since, you cannot get the information. Additionally, the only info you will get from this is to where/from where the fax was sent, and if it was successful. Any information on the actual fax content is unavailable.
Jun 03, 2009 | Brother Office Equipment & Supplies
My HP Photosmart C6180 All-in One Series prints out a Fax Log after each Fax sent, How do I change the setting so that it prints a Fax Log only on request
Press the Fax Menu button twice to get to the Fax Menu to select or change Fax Options. I didn't see Fax Log in the manual, but I think they refer to it as a Fax Confirmation.
The only reference I saw in the manual was this:
"Note If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes."
Oct 20, 2008 | HP Office Equipment & Supplies
Printing a sent fax
in the settings of the fax there is a setting in reports that you have to turn on conformation with print out.
that gives you time date and 1/2 of the top page of fax sent
May 20, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
FAxing in "real time" rather then sending to memory
You can go into the setup mode. There should be either a memory clear which will reset it to default settings, or a setting to simply reset.
You can go into the menu on the machine and print out a help sheet which will help you through the problem.
And there should be a settings sheet to print out that will help you isolate which setting needs changed.
Dec 11, 2007 | Brother IntelliFAX 4100 Laser Fax
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
101 people viewed this question
jasbo
jasbo
