Question about Cycling
Replacing rear derailleur - Cycling
    Brigadier General:
  • 8,546 Answers
I have a 1985 vintage bike with a friction derailleur. I want to replace the friction derailleur with a index derailleur, which index derailleur is recommended, and could I use exiting gears on bike
I will preface this by saying that if you don't have the tools, and to a lesser degree the experience, to properly work on your bike it's not worth the time or money to go to indexed shifting on a less expensive bike..
You can probably use the existing rear cluster (freewheel) if it's Shimano. You would also need compatible indexing levers and possibly new cables and housing. Any level of compatible indexing derailleur will work. If your rear cluster is not Shimano, or if it's "Ultra-6" then the freewheel would have to be replaced. In any case 6 speeds in back would be the most I recommend, and also the highest you can go without replacing the chain.
If the freewheel is not compatible then you're best off looking for a good indexed used bike and selling yours, due to cost.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Sep 14, 2017 | USE Cycling
Ezip
Since you didn't specify which derailleur needed adjusting, I have included links to adjusting both the front and rear derailleurs.
Park Tool Co ParkTool Blog Front Derailleur Adjustments
Park Tool Co ParkTool Blog Rear Derailler Adjustments derailleur
Apr 13, 2014 | Cycling
Bicycle rear derailleur slips back to high gear.
It is likely that Phil has an old school Shimano Eagle rear derailleur.
I recently had a very similar issue with a Suntour friction shifter and derailleur. I tried replacing the shift cable and housing with no luck. Then I was told to replace the chain. Made no difference.
Then I took a closer look at my bike's shifter. I took my old one apart and the gear teeth that were supposed to keep the shifter from moving were worn down.
New shifter took care of it for me.
Oct 22, 2012 | Cycling
My shimano ultegra left shifter is super stiff/hard to push in; what is going on?
Try flushing out the shifter(s) with WD-40, use plenty. The next step will be replacing the shift cables and cable housings.
  • Take the bicycle in an area free of cars and obstacles, such as an open parking lot. Concentration is required when learning to use Ultegra shifters or any other type of bicycle shifter.
  • 2 Mount the bicycle and rest both hands on the proper Ultegra hand control. The left-hand control operates the front derailleur. The right-hand control operates the rear derailleur.
  • 3 Start pedaling, smoothly and evenly. While pedaling is crucial to propelling the bicycle forward, it is also necessary when shifting the derailleur. Pedaling forces the chain to rotate. The chain must rotate before it can transfer to another gear.
  • 4 Push the outside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a smaller rear gear.
  • 5 Push the inside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a larger rear gear.
Rear Ultegra Derailleur Control
  • 1 Push the outside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to larger front gear.
  • 2 Push the inside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to a smaller front gear.
  • 3 Use the front and rear Ultregra hand controls interchangeably. For small changes in gearing, using the rear control. For larger changes, choose the front control. A smaller gear causes the bicycle to travel a shorter distance per pedal stroke but also requires less energy to use. A larger gear requires greater effort but in turn causes the bicycle to travel farther per pedal stroke.
Oct 25, 2011 | Cycling
I am trying to fix a Huffy Blackwater bicycle (15 speed). The rear derailleur is missing. Can I use a 6 speed derailleur from a Next bike? Can I disable the indexing of the Huffy (Falcon) shifter? Thanks
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
Dec 21, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
Need pulleys for my TD One derailleur
There are no pulleys on the front derailleur. Only the Rear derailleur has pulleys.
The Front derailleur consists of two plates that work the front gears (chainrings)
The Rear derailleur consists of a long arm with 2 pulleys to wrap the chain while shifting the rear gears (cassette).
Pulleys range from $10- a pair to $75-. Your local bike shop should have a suitable replacement set of pulleys, depending on the model of your derailleur it is sometimes less expensive to just replace the whole unit.
Dec 09, 2010 | Mountain Td-one Bicycle Front Derailleur...
Hi, I have recently installed a new X9 derailleur in accordance with the manufactures' instructions. I have also relpaced the rear hanger. The gears shift ok, however, when in gear, especially the...
Did you also replace the chain or any of the cogs? Skipping is a common condition when you replace one and not the other. Or if the cogs and chain are well worn, it may simply be time to replace them. You can usually do fine without replacing the gear-rings (that is, the cogs by the pedals)
Nov 10, 2010 | Sram X9 Mountain Bike Rear Derailleur
SRAM x-7 derailleur jumps gears.
make sure nothing is bent and all sprockets are tight, try replacing cable and readjusting .
Nov 23, 2009 | Sram X.7 Rear Derailleur
Alivio 8 speed rear derailleur cable broken
There is a bolt on the derailleur that holds the cable. Loosen it to remove the cable from the derailleur. If there is a cap on the cable, remove it by pinching it with a pair of pliers. i do not know what style shifters you are using, but most all of them have a plastic cap covering the port for the cable. Shift to the highest gear to prep the cable for release and remove the cap. Push the cable back into the shifter and it should come out of the port you opened. Now, slide the new cable in and pull it through its circuit of cable housings and back to the derailleur. Attach the cable and shift to the lowest gear (big cog). Now, pull the cable along the top tube or seat stay (wherever it is more accessible) away from that tube very firmly several times. This pre-stretches the cable and minimizes necessity of adjustment later. The harder you pull, the better. Once you have stretched the cable, shift to the highest gear again and release the cable on the derailleur. Adjust the barrel on the derailleur to the center of its range and turn in the one on your shifter all the way. Now, pull the cable taut and reatach it on the derailleur. You can cut the cable to length and put a cap on it now. Shift into your middle gear and use the barrel adjuster on the derailleur to align the jockey wheel over the appropriate cog of the cassette. You should be all set!
i hope this helps
-matthew
Nov 12, 2009 | Cycling
Replacing Attack's rear derailleur cable
Stop everything! Do not take the shifter apart! Go to the rear derailleur and look where the cable is attached. There is a bolt with an allen key head, it is an 8mm. Losen off the bolt. REFER TO PARKTOOL.COM
Apr 12, 2009 | Sram Attack 9-Speed Trigger Mountain Bike...
Cycling Logo
20 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
