Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag MDB9150 Dishwasher soap dispenser door doesn't open
I have a Maytag MDB9150 Dishwasher. The soap dispenser door does not open during wash cycles. I removed the inside of the door panel to inspect the back side of the dispenser. Mechanical lever linkage seems to be working fine. The wax motor had a zero reading on my ohms meter so I replaced it. With new motor installed, door still does not open. What's my next thing to check?
  • burnie1503
    burnie1503 Sep 30, 2008
    A follow-up to my dishwashers dispenser door problem. Since the mechanical linkage was working and I already replaced the wax motor, I came to the conclusion that the motor was not getting power from the the control board. I ordered a control console from easyapplianceparts.com for about $100, installed that and it now works fine.
    Problem Solver:
  • 12 Answers
The plastic lock of the soap dispenser in side the dish washer door is broken
Posted on Jun 09, 2009
    Novelist:
  • 166 Answers
Peace,
You need hands on service!
Posted on Sep 07, 2008
Ge Profile soap dispenser doen't fully open during wash
Pour boiling water into the dispenser, it may be gunked up with soap residue
Mar 21, 2017 | Dishwashers
The soap door does not open during the wash cycle
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid 24 in. KUDI02CR Built-in...
The soap compartment will not open during the wash cycle.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these.
Please revert for any further assistance.
Daniel
Aug 28, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Wet dishwashing soap
make sure that the you let the hot water run for 2-3 min to make sure it is hot going into machine or it will not break down the soap.if the dispenser is opening then it is a tempproblem. let me know if my assistance was any help with a 4 thumbs up post
Feb 27, 2010 | Maytag 24 in. MDB9750AW Dishwasher
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Dishwasher soap cup lid will not open during a wash cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
jj
Dec 31, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Jan 16, 2008 | Maytag 24 in. PDC3600A Built-in Dishwasher
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
1,480 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
