I WANT TO STOP THE BEEPS AT THE END OF A PROGRAMME ON A BOSCH WASHER DRYER WVH28420GB/03' THANKS
  • 108 Answers
SOURCE: WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Posted on Mar 26, 2008
jason0110
  • 66 Answers
SOURCE: We have a Bosch Exxcel
would try cleaning your pump and sump as when its draining without the force of the spin the pump is idle but with the force when you put on other programs ie the spin this will push the water through the pump hope this helps
Posted on Jun 22, 2008
  • 3 Answers
SOURCE: very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: annoying beep when wash cycle finishes on bosch classixx 1400 express
You should be able to power up the appliance with the dial turned to "x" so that a programme is not selected and keep the door open so that the machine is certain not to start a cycle. Please let me know if this helps at all. Thank you.
  • 14 Answers
SOURCE: Can you supply me with instructions for a Bosch washer/dryer
Bosch Product web site.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Click on WVTI2840GB/04 for info.
The model number has the letter "I" not "1"
Posted on Mar 03, 2009
I have a bosch logicxx 7 washing machine. I've
Suggestion: Keep the beep button pressed or keep pressing till the beep indicates 'off'.
Mar 24, 2013 | Washing Machines
Why is F16 code flashing up on my bosch avantixx washer dryer
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Aug 26, 2012 | Bosch Logixx WFT 2806 Front Load...
How do I unlock my bosch washer dryer logixx 7/4. the red lock key symbol is on
Model WVH28420GB :
Firstly, follow the instructions for "Emergency Release" on page 13 of the Operating Instructions for this machine.
If, when you switch on the machine and select a washing programme after doing this, the key symbol still appears, press and hold down the 'Timer' button (second from top on the left hand side of the message panel) for a few seconds until the key disappears. Now operate the machine as you normally do.
Dec 04, 2011 | Washing Machines
Washing wool?
I assume you are asking if there is a wool programme.
There should be a seperate wool programme incorporated in the timer or programme control unit, and it is usually a 40 degree wash.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Very annoying beep when finished programme
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFL 2872 washing machine has just started beeping (3 beeps) at approx 1 minute intervals at end of program until I turn machine off. washer is 3 years old & has never done this before - does it...
A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
Select any programme - say 30 Cottons
Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
Jul 24, 2008 | Washing Machines
Bosch Maxx 6 doesn't dry anymore?
Yes,it is the first thing to check ,If you can somehow see if its glowing when you start the dryer.It may also be a thermal fuse.
May 22, 2008 | Dryers
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
