SELECTING AV2 INPUT ON LCD TV PRODUCES BAD SOUND COMING THROUGH SPEAKERS, MY TV IS 1 WEAK OLD AND I AM DAMNED WORRIED
  • 32,281 Answers
If your TV is new then it will still be under warranty. I suggest you get the supplier to repair or replace it under warranty.
Posted on May 22, 2011
I have it setup on my Samsung TV with RCA cables, but no sound comes out
Why do you need to use RCA cables as a TV will produce sound through the internal speakers without any cables required.
May 24, 2016 | Samsung Televison & Video
I have a samsung LCD TV. it shows only AV..I can not use it as AV1 AND AV2
You can select its other 2 av inputs by pressing the AV button on its remote control.
Jan 23, 2013 | Samsung P50HP 50 in. LCD TV
I have no sound coming out of my speakers when I connect the receiver to my tv and ps3.
There's really not enough info here to answer your question. What outputs are you connecting to what inputs on your receiver? 1. Does the receiver produce sound from other inputs? If yes, then receiver to speaker is OK. 2. Do you have sound at a headphone jack but not speakers? This would indicate bad speaker wiring or blown output fuses.
A bit more info will help - maybe gathering it will lead you to where the connection is not correct.
Oct 22, 2010 | Sony STR-DH100 Receiver
I have my dvd player attached but don't know what channel to put the tv on so the picture from the dvd comes on and not just the sound
You should be using the Video input, you should have three cables hook up to one of the Video input,
Yellow for composite video, red for right channel sound input, white for left channel sound input, then select AV1 or AV2 depend on which one you choose.
Oct 30, 2009 | Philips 19PFL3504D 19 in. LCD TV
Use of AV2 input sound socketsto play ipod
The sound is muted unless a video signal is detected on this TV. The only work around would be to connect the camcorder or some other active video to tha input but using the IPOD for the audio.
Jul 23, 2009 | LG RZ-17LZ21 17 in. LCD Television
VIZIO Flickering Fade to Black
Do you have more than one source on the input you are using for the tv signal? For example, are you using AV1 for tv, AV2 for dvd? If a signal is weak, real weak, the tv will automatically move to the next like input. That being said, if you are in fact setup like I'm asking about, a weak signal would explain the flicker and fade to black. Of course, it could be the main board in the early stages of going bad but we'll try to stay positive for now. :^ )
Let me know please.
Jul 05, 2009 | Vizio VX42L 42 in. LCD TV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
No signal
Try this.
1. Take note of what input you are using to your television. AV1 or AV2 or Component 1 Component 2.
2. On the remote, toggle the input selection to corresponding input for your DVD.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Computers & Internet Logo
David Payne
David Payne
