Question about EliteGroup Computer ECS H67H2-M3 Intel H67 Motherboard - Micro ATX, Socket H2 (LGA1155), Intel H...
Hi i have a h67h2-m3 board with i5 4gb ram runnung win 7. inserted a PCI DV/R card for cctv and the computer will not boot when it is in either of the two pci slots. it boots up no problem when the pci card is removed. What can you suggest Thanks
  • patrick_dwye May 23, 2011
    Thank you for your help, I can confirm that the card works on other motherboard so the PCI card is not faulty. I have the latest Bios Version.
    Guru:
  • 610 Answers
This is definitely a solid proof that the PCI card is broken but for doubt's sake, you can go to the BIOS and check for any conflicting setting e.g. Plug and Play and PCI working frequency as capture cards, video cards and sound cards requires high PCI bandwidth.. I don't think that this is an IRQ setting problem as you are using a Windows 7 Operating System which has a better way of handling IRQ requests compare to previous OSs and your mobo I believe, has ACPI support enabled. Although it is not recommended for recent motherboards to disable this and use Standard-PC mode, you can also explore this possibility.
Make sure your BIOS is updated as well and your video card drivers too.
Hope this helps.
Posted on May 22, 2011
  • Christopher Ian Tecson
    Christopher Ian Tecson May 23, 2011
    I see, If that is the case, have you tried disabling ACPI support in your mobo? This will enable the mobo to manage and assign its own IRQ for the device. If you still have the motherboard manual, you might want to check if it's PCI slots frequency matches or is it enough to run the PCI DV/R card. Take off any other PCI cards just for test purposes and see if it will boot with just the DV/R alone. If this won't work then we don't have any choice but to call it "Incompatible" with your mobo.
Orange led light ibm x3400 m3
The orange Led On the Server is letting you know that there is something wrong with a PCI. Check the pci card slot 1 and make sure they are all seated tight.
Sep 03, 2014 | IBM System x3400 M3 7379 Server tower 5U...
Hi
Well about guaranteed your 2 gigs ram is probably DDR II ram which has maximum of four gigs with 64 bit processing and 2 with 32 bit is. So motherboard needs upgrade. 35.00 for good giabit or board with 1000 megs a sec ethernet lan. With ddrIII ram. And upgrade operating system I believe win 8 has max 16 gig ram win 7 uses 8 gis vista and longhorn 64 use 4 and xp normal edition 32 bit uses 2 max. So you about have to run win 7 or 8. Win 7 will become direct x incomparable at some point making us change to win 8. Win8 cost like 300 to 350 and tiger direct.com has good deal of the win 7 pro media center for 75 bucks. So spend 150 on good speed 8 gig ram, 125 bucks for 12 core and at 4 GHz I think. And a board for 35. Reuse all other componets. And you\'ll have a 2500 dollar computer and best on the block. TigerDirect com Electronics Tablets Phones Office Supplies Video Games
May 16, 2014 | Video Game Consoles & Games
Black screen and no sound on my Hauppauge Colossus PCI Express Win 7 capture card. I have confermed that the signa is getting to the card, by plugging each the HDMI, S-Video and composite video cables into...
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Aug 27, 2013 | Hauppauge Colossus PCI Express HD Video...
Intel motherbord
Does it show any error msg?
Feb 26, 2008 | Watches
My PC Not Work With my CCTV Systems
what kind of error display
which card use 4 channel , 8 ,16
Feb 26, 2008 | Intel Motherboard
Black screen after start up
basically any board that has a pci slot will let you use your ati card
Oct 05, 2007 | Intel Motherboard
Boot beeps
re check all inserted pci cards and all memory, reseat if necassary. Have you recently upgraded anything, if so remove. Continuos beeps can also indicate processor power failure.
Mar 19, 2007 | Soltek SL-65KV2-T Motherboard
Proxim Orinoco 8482-WD PCI Card, Driver installation locks Win-XP
Try the other way around,first install the card then boot the system up. When Windows finds the card and asks for the driver, insert your driver cd and choose install driver manually and point windows to your cd drive to force the use of the correct driver. It may be that windows is trying initially to install the generic driver.
Feb 05, 2007 | Proxim ORiNOCO Gold (8482-FC) 802.11a,...
EliteGroup Computer ECS H67H2-M3 Intel H67 Motherboard - Micro ATX, Socket H2 (LGA1155), Intel H... Logo
78 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
