Question about Xerox DocuColor 12 Printer
Printing problem Problem with the printing out the colour is fading towards the bottom of the page. The print out looks less glossy compare to before almost to matt finish. My supplier told me to change the fuser nip clutch. Just want another second opinion on this issue.
  • 1 more comment
  • printmartzy Aug 16, 2008
    Fuser oil supply is about half the container what about oil pump how can you tell if is causing the problem? Please advice.
  • printmartzy Aug 21, 2008
    Hi jaiku
    How do I clean my oil assembly can I used paint thinner as suggested by my fren? I notice ink has stuck on the bottom of the oil assembly.
  • Anonymous Sep 01, 2008
    I have the same problem on heavier stock, maybe the last inch or so the toner fades away, when xerox was here for another problem they said that when the sheet is fed thru the trailing edge lifts and causes this, no real fix.
Jaiku sir last i am siva36 you have given me a solution for me that i bought machine from mumbai dc12 colrs fading worest printing you told me check devloper base plate. 2nd btr and ibt but the main problem is toners are not **** into developers toner were not running full jammed now i solve the problem thanking your but now another problem is my fery when connected to the machine i am getting blank plage. using work station alos i am getting blank page. give me the suggestion. prasad.............
Posted on Aug 22, 2008
  • 79 Answers
Pls check ur fuser oil supply, and oil pump?
Posted on Aug 16, 2008
  • 1 more comment
  • jai kumar
    jai kumar Aug 16, 2008
    if oil pump doesn't work proberly the fuser roller geting only low oil. so that u check that and if u can pls clean ur oil assemply.
  • jai kumar
    jai kumar Aug 21, 2008
    best u use petrol to clean oil tank.. its better than thiner.. dont use petrol in oil wick, oil filter and oil rolleres. in that unit u use clothes only.. when u finish cleaning process than lightly apply oil to oil rolleres and oil wick.. ok all the best.. further u have any dout just reply me???
  • jai kumar
    jai kumar Oct 23, 2008
    hi blank page means first u check drum unit, if image applying in drum 2nt u will check ibt assay then 2nt btr unit. and try one test page through ur fiery..
Why is my printer printing faded colours
Hi Kath,
I expect you have it sorted by now.
I think you might have had one off the developer tanks stuck or broken. If the developer roller does not turn then the colour quickly fades along the page. If you tried to do a test page and that was good then there was nothing wrong with that side of things.
Good luck.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
Faded color prints
* If your are printing color photos on a Glossy paper you must chose the paper type from Media Type in the Printing Properties while giving Print command. If you don't know what is the type of your glossy paper then just select other glossy paper from the given options. f91a3a39-5f37-45c6-9bca-21ac453f79ef.gif
May 06, 2014 | Brother MFC Office Equipment & Supplies
Dell 2135 fading left side when printing
It's possible that this could also be down to a toner cartridge inside the printer. I would recommend running off a copy of the colour laser test page found here.
The colour bars towards the bottom of the page separate cyan, magenta, yellow and black. Hopefully you will be able to notice that one colour is affected more than the others and replacing that colour may help.
Apologies if you have tried anything similar previously.
Oct 31, 2012 | Dell Office Equipment & Supplies
Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
Dec 22, 2009 | HP Designjet 110plus nr InkJet Printer
Wont print out accurate color when printing a Greyscale photo
Hi, I recommend doing a nozzle check first to ensure all the colours are printing fine.
Within the advanced option of the printer driver you have an option to select greyscale, it might be worth enabling this feature.
If you are using glossy media the problem might be down to the ink reaction with the glossy resin as this can cause casting or bronzing. To check this try printing on matt paper.
If you are printing from Photoshop check your colour matching settings, the easiest way to do this without messing to much is try printing from another application, I would recommend Epson's own, Easy Photo Print.
Dec 04, 2009 | Epson Stylus Photo R200 InkJet Printer
Cannon MP600 will not print accurate photo colours
First clean and align the printer correctly.
You will need to ensure that you have selected Photo Glossy Paper for best results. You will also need to adjust the gamma settings and also play with the colour saturation controls to achieve a good colour balance that you are happy with.
Try printing a basic colour additive chart and comparing screen against printout and adjusting settings as required.
http://en.wikipedia.org/wiki/File:AdditiveColor.svg
http://upload.wikimedia.org/wikipedia/commons/archive/6/67/20071203133356%21CIE1931simple.png
Also have a look at myPANTONE colour splash to get the definitive Pantone Colour Mixes at
http://www.pantone.com/pages/pantone/pantone.aspx?ca=24
or use a paint tool or PhotoShop etc to create solid colour blocks of basic colour to compare against.
Nov 06, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
Xerox DocuColor 12 Printer Logo
243 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
