Question about Vacuums
The service manual to but the Unistar DF-268A Back together
  • aboinextdoor May 22, 2011
    its not a vacuum it is an Unistar DF268 4-in-1 Swamp Cooler Fan with build in Humidifier Air Purifier
My hoover water reservoir will not fill up with water because on the bottom all little parts came off. I can't get them back on. Hoover 5810
Brenda, is the hole I see in the middle a "broken" attaching post?
Plastic is problematic as far as glue is concerned.
try this for user's manual and or repair manual. Find a picture of all the parts and the way they go together. Google pictures might help. Warrantee? Reciept? I'd call MFG customer service. Be nice. They won't tell you, but their engineers Need to know this has broken and their design is Sub-standard for home use appliance. Customer service may know this and help you out.
Mar 09, 2015 | Hoover Vacuums
Manual for bissel upright bagless vacumn cleaner
Not knowing what needs to be put back together I am giving
you this phone #....Bissell Consumer Services !-800-263-2535
Make sure you have the Model Number available.
Regards,
Dennis.
Aug 24, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
How do I get the u5290-900 apart far enough to remove old power cord and plug in a new one?
First you need to remove the Dirt Cup followed by the front cover / handle. Page 4 1-6 of the PDF Manual below shows how to do this.
http://static.fixya.com/Manuals/H/Hoover/5288_900_prg_B4F5E4DE0DB02590E2525C367EFB5C4C.pdf
This should then give you access to remove the internal cover and replace your cable.
Jun 26, 2011 | Hoover U5290-900 Upright Vacuum
I have emptied the bagless container. How do I put it back together? I need to look at a picture
The below site contains a downloadable manual for the Whirlwind Plus, which should be similar to yours. The information you need is on page 4.
http://www.eureka.com/service/manuals/80509.pdf
Feb 15, 2011 | Eureka Whirlwind 410 Bagless Upright...
The TechDrive Pedal on my Kirby G6 fell out of the back of my vacuum cleaner. I removed the screws from the metal plate one the bottom to try to see if something had come a loose. Can you send me a diagram...
This requires removal of the transmission assembly and replacement of the pedal assembly - it cannot be repaired. The handle and upper motor shell must be remove to access the transmission assemby. There are two screws in front, and two under the plastic switch plate.
Jan 18, 2011 | Kirby G6 Bagged Upright Vacuum
Ya I messed up and thought that I could fix the vacuum all on my own, but now I don't even know how to put it together. I have a Dyson DC17 Animal Bagless vacuum. Do you have a picture of how the machine...
That's why a highly recommend people take their vacuums to an authorized (by the manufacturer) store for repairs. I've seen quite a few come in with this problem. Some with broken parts from trying to get it apart. And most companies don't provide service manuals to the public. If they did, service technicians would lose work.
At this point you'd be better off taking it in to the shop and having the tech put it back together.
Also, always check your warranty information. These machines carry a 5 year warranty, but that is voided if the owner or an unauthorized tech takes it apart. I don't know if yours was still covered or not.
Nov 16, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Looking for manual for bissell proheat 7901-8901 series took it apart a can't remember how to put the bottom back together
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Sep 02, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
142 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
