Question about Canopus DVRex M1 (770-10015-200) Video Capture
I have a problem about Canopus DVREX M1 and Canopus DVREX RT cards (with external connection). I installed two cards on a computer with these features: - Pentium 4 3000Mhz; - Asus P5S800 VM S mother board; - 1Gb Ram; - Windows XP Sp2 Operating System; Computer knows two cards and I can work also on Adobe Premiere 6.5. But when i use "Rex Video" capture program, after to configure video and audio input and others settings, I can't capture the video and audio even if video is visible on overlay monitor. I tries to reinstall both two cards but i didn't resolve the problem. I wait for your answer. Bye
4 Suggested Answers
  • 119 Answers
SOURCE: cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
Posted on Aug 11, 2008
SOURCE: matrox rt.2x and adobe premiere cs4
not found in RT.X100
· Adobe Creative Suite 4 Production Premium and Adobe Premiere Pro CS4 support
They cannot work together unfortunally
Posted on Feb 23, 2010
  • 1116 Answers
SOURCE: I had my Rex M-1
Listen, lets start at the beginning. Reverse the entire process you performed on the new system. Remove all of the cards you put in after you bought the new system. With that having been done, does the new system start-up and run correctly?
Posted on Jul 01, 2011
Can I capture a video file from an ordinary PANASONIC camcorder SDR-HR5 with just a USB adaptor and edit it using my CANOPUS RAPTOR EDIT i LINK data port. or can i capture videos from my PC to my...
Not to my knowledge, however there are lots of "video grabbers" on the market, they are an external piece of hardware that will take the composite outputs from your cam corder and download into your PC through the USB port. Amazon has a large selection and they are fairly low priced..Hope this gives you some insight on the problem...Dave
Mar 30, 2011 | Canopus DVStorm2 Pro (Bundle) Graphic Card
I just want driver for canopus dv storm2 pro.
I buy DVStorm2 card Serial NO: 28AA031P. Include 3D RT
Software #510-100-10075-001.
So that I can not install 3D RT.
Because I lost 3D RT Serial NO.
Please sent for me 3D RT Serial No. ? PC-XXXXX-XXXXX-XXXXX-XXXXX
Thank a lot
Feb 24, 2011 | Canopus DVStorm2 Pro (Bundle) Graphic Card
I am using canopus DV storm XA(DVX -E1) with Radeon X 700 GPU. Last moth my gpu burned off and this one is not in market then i bought Radeon HD 5670 card and install it but now my preview monitor both in...
canopus dv strom xa (dvxe-1) editing card is supporting graphic card number is asus eah4350 and 1 gb graphic on board is very suitable if doesnot suite the card call me +91 9010016553
from babucreations andhrapradesh india
Nov 03, 2010 | Canopus DVStorm2 Pro (Bundle) Graphic Card
I Have a Canopus Dvstorm2 Pro But I Lost my Software Cds Please help me I Want The Drivers Pack That Run In Adobe Premier Pro 2
Hi Ali,
You can download the driver for your graphic card on the link below:
Oct 28, 2010 | Canopus DVStorm2 Pro (Bundle) Graphic Card
DVStrom-RT and Edius Pro 3
Activation Code .....?
May 09, 2010 | Canopus ACEDVio/EDIUS Pro 3 Bundle...
Let's edit 2 doesn't work with windows 7 I can't install it, can someone help me?
Installing LE2 in Windows 7:
install a newer version of QuickTime than the 6.x included with LE2
run Setup.exe in the "Let's EDIT 2" folder of the LE2 disc
(do not use SetupMgr.exe in the parent folder!)
enter your serial number
continue the installation until the unhandled exception occurs
Error number: 0x80000FFFF
Description: Catastrophic failure
do NOT close the error window yet!
(otherwise the installed files will be deleted)
use the windows explorer and go to C:\Program Files\Canopus\
(the chosen installation location)
rename the "Let's EDIT" folder, for example "Let's"
go to C:\Program Files\Common Files\
rename "Canopus Shared" to "Canopus"
make a copy of the desktop shortcut
(copy - paste shortcut)
make a copy of the "Canopus Let's EDIT 2" start menu folder
now click OK in the exception error window and wait a few seconds
restore the "Let's EDIT" folder name
restore the "Canopus Shared" folder name
start Let's EDIT and adjust the settings
especially video standard (NTSC/PAL) and format (DV/DVCAM)
close Let's EDIT
add the following entries to the registry in order to allow installing 3DRT
(adjust DestDir if installed into a different path)
these entries will also allow installing the 3DRT update
(if you have the updated 3DRT 2.01 version that has the improved 3D PIP)
"DestDir"="C:\\Program Files\\Canopus\\Let's EDIT"
run install.exe in the "3D RT" folder of the LE2 disc
(or install 3DRT 2.01 instead, if you have it)
Apr 06, 2010 | Canopus Let's EDIT 2 (77610158100)
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
Board recognition
install the software it came with (drivers software etc)you will need to reboot after.
if still is not working remove the software from control panel/remove programs after remove driver and device from the control panel/device manager and perform a disk cleanup from startup/accessories/system tools/disk cleanup-stop computer and remove card.Boot again and let windows login and run for few minutes.shut down again and reinstall card.boot again and make sure the installation cd is in the cd drive.if prompted choose to install the files from a specific location and give the cd drive location .
Oct 02, 2008 | Computers & Internet
Canopus DVRex M1 (770-10015-200) Video Capture Logo
101 people viewed this question
Top Canopus Televison & Video Experts
Alun Cox
Troy Staley
Troy Staley
Paul Bade
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
