Question about Sony STR-K840P
I have a Sony STR/K840P and since moving and installing we can only hear music or background noise but very poor foreground and voices. This is on fibre optic or coax on set top box or PS3. Suround blue indicater can be on and still poor sound. Please help Ive tried all settings and its driving me made. Regards Adam Roache
SOURCE: sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Posted on Dec 30, 2008
dunnbiker
  • 8546 Answers
SOURCE: Sony DG510 - Not Getting surround sound out of Cable
Did you try it on BOTH the SAT and Video 2 optical ports? Still not working? Could be the Optical cable is bad.
Does your Cable Box also have a coaxial digital ouput? It looks just like a standard RCA connector but says Digital somewhere near it. Try one conductor of a standard audio cable from it to the "DVD" coax connector. Select DVD to hear it.
If it still doesn't work jump into the Cable Box setup to make sure it's output is set up properly.
I would recommend using the coaxial digital option if you have it.
1) The cable isn't special or expensive like the optical cable is; a garden-variety RCA cable works just fine.
2) You have virtually unlimited distance to work with in the house.
3) You don't have to be so darned careful with it as with optical.
Posted on Apr 03, 2009
SOURCE: I have my 80 gb PS3 hooked up to my STR-DH800. I
if you have the old fat ps3 it will only output linear pcm through hdmi.if you have the new slim ps3 it will output the true hd and dts master audio through hdmi.there is nothing you can do about it as far as i know.i hoped sony would fix this but so far they have not
Posted on Jan 30, 2010
  • 128 Answers
SOURCE: Hi I have a STR-DN1000
Your connections are fine the issue here is with the onboard processor.
HDMI is a great connector ONLY because it simplifies wiring.
The "concept" was to give consumers a simple way to connect their components while allowing devices to "communicate" to each other by being able to send control signals through the same cable.
HDMI is a digital format which has advantages but unfortunately these signals must be processed by the receiver, the problem that arises is that dvd players, video games etc. generally do not encounter issues when connected directly to a television but once you route that signal into the receiver well that a whole new ballgame there. (you are adding processes to the signal)
The delay and popping are caused by the processor making the needed adjustments and "reading' and converting the signal for display.
Personally I use HDMI but I also connect the optical AND component cables, Why? well for starts you can "upconvert" to HDMI but not "downconvert" so if you need a analog signal for a dvd burner s-vhs recorder or ? the HDMI signal can't be converted to a lower quality (for copyright reasons)
If you are not using the receiver for video switching or for multi room you will get a better picture by bypassing its video capabilities.
On low or mid line receivers such as your Sony I would run the hdmi's to your HD monitor and run the optical cable to your receiver.
Yes this will mean you will have to switch 2 inputs when changing sources (tv and then receiver) but should give you quicker video processing and better picture.
Now I don't want you or anyone to think "oh my Sony sucks" as its not entirely Sony's fault HDMI through ANY receiver brings issues I have a $2000 Denon and the HDMI sucks on that too!
I did write an extensive article/post on HDMI processing about a year ago its somewhere on this site.
Hope that helps
Posted on Sep 23, 2010
lohrelem
  • 14 Answers
SOURCE: What are the steps to
Here is a link to the manual for your receiver:
http://www.docs.sony.com/release/STRDE597revision.pdf
Posted on Sep 24, 2010
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Sony rm-pp411 av system remote not connecting to str-k840p amplifier
The problem might not be your remote. It could be your IR sensor in the reciever.
Apr 10, 2012 | Audio Players & Recorders
Hi i am a new member and i have a problem with my str-k840p it started to have a protect mode flashing and I can't hear the at all the tv or speakers. What could i do i check all my connection and they...
Protect display indicates that receiver is in protection mode due to some serious problem in output amplifier section and most probably any output channel output chips got shorted out.
Protection mode turns On to avoid any further damage in receiver. If your Sony STR-K840P is under warranty then call numbers written on warranty documents to ask warranty cover and if unit is out of warranty then either Sony service center or local repair shop will help you to get it fixed, it is not user level repair.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 29, 2010 | Sony Audio Players & Recorders
Surrond noises play but no voices , we can hear the music on the dvd and background noises but not the voices
The voices generally come out of the center channel speaker, in a 5.1 or higher dolby set-up. Hope this helps.
Apr 08, 2010 | Audio Players & Recorders
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
Surround sound won't work
Try Googling (sony)(STR-K840P)(manual) without parens.
May 25, 2017 | Audio Players & Recorders
Background sound too loud
Thank you, everyone! I thought maybe I was losing my mind. I can hardly watch a lot of the TV shows anymore due to the inappropriate use of music -- either it's too loud or there's just too darned much of it. Come on, TV producers! You are supposed to get better with time, not worse! Thank goodness I'm not alone.
May 30, 2008 | JVC AV-32260 32" TV
Sony STR-K840P Logo
51 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
