Question about Handmark Software MobileLists (950142) for PC, Mac
Tv not working
My mobile tv not working properly
  • Anonymous Aug 18, 2008
    tv and fm both are not working. when i touch the antenna the fm works.
Solution
Posted on Oct 25, 2008
Im trying to connect my laptop to my TV, laptop end is a VGA and tv is HDMI. i also have a cord that does VGA on laptop Component on TV..neither will work.. whats the problem?
Hey Erin, when you mean it does not work as in there is nothing on the screen including audio? With VGA to HDMI (assuming you have the VGA to HDMI adapter) you should only get video since VGA does not support sound. As far as connecting goes its pretty much plug and play. That's also assuming that you have set it to the correct input on your tv and make sure your laptop has proper settings. Go to control panel and go to display. Make sure it recognizes dual monitor. Other than that there really should not be a problem. Look at video input on tv and display settings (OR mobile pc > windows mobility center > connect to a projector or other external display (not under classic view - Vista). I hope this helps. Give me a feedback if not. Good luck Erin.
- Joe.
Oct 22, 2013 | Televison & Video
How can i watch tv on my 7610, if there is any software, plz tel me abt it.....!
You will not be able to watch TV on your phone.
The phone does not support a fast enough of a connection to watch TV on it.
Jun 19, 2011 | Nokia Cell Phones
Nokia 1209 some key are not founction Please solv my problem
As you are using Nokia 1209 mobile you need to contact you are nokia service center there they will make you are mobile to work properly.This may take few minutes after repair check weather it is working properly or not.And you can also make service by your self by opening you are mobile panel cleaning the keypad area there you will find a huge amount of dust it may make you are mobile not to work.Thanks for you are question.
Jun 17, 2011 | Nokia 1209 Cell Phone
Unreponsive touchpad
Touch pad is a thin glass layer that is available below the display screen which interacts with the mobile when we touch. Since you have not specified your mobile functionality; I think your mobile is working properly when you use the Keypad. If your mobile is not working properly using the touch alone then the touch pad in the mobile got affected. Touch pad in the mobile can be replaced easily. Please visit the nearest mobile service center and ask them to replace the touch with a new one. Nowadays touch screen are available at very low cost.
Jun 21, 2010 | Lands Phones
My tv remote and sky remote wont change channels, Ive replaced the batteries and still nothing
Get a Video camers or mobile with video function
switch it on and and focus it on the remote IR and press the remote simultanusely and then check of any white light visible on the LCD screen of your camera or mobile
if visible your remote is functioning properly ...
and the problem may be in the TV sectio
if there is no white light visible .....the remote is 100% not functioning
may be your remote IR(infrared LED) needs replasement ........or sometimes best option is to get the new remote for your TV of its brand
Sep 20, 2009 | Hitachi 43FDX01B TV
Anything about a new phone i purchased recently.
ur mob. is 3G model that means to activate ur 3G facilities such as TV & much more. U hv to register ur 3G model from wellknown mobile shopee.
If these 3G facilities launched in ur country or state, then after proper reg. all the 3G facilities in ur mobile wll b activated, otherwise u hv to wait for future launching.
Aug 13, 2009 | Cell Phones
Remotes working sporatically
Your description suggests bad/dirty contacts inside the remotes and jammed volume buttons on one of them. Cleaning the rubber pads and the circuit boards on all of the remotes might solve the problem.
Use some ethyl or isopropyl alcohol and cottonwool to clean them.
By the way, here's a nice way to test a remote using your mobile phone's camera:
Turn the camera on, point the remote towards the camera lens so you can see it on the mobile's display.
Look at the display on your mobile phone and press buttons on your remote - you should see bluish/greenish flashes from your remote's emmiter each time you press a button on the remote (the camera on your mobile shows infrared light from the remote as visible light on the display - if it doesn't do so in the normal mode, try the night mode for the camera instead).
If you press a button and there are no flashes, that button probably has a bad/dirty contact.
if the remote is making flashes even when the buttons are released, this means that a button is jammed (you need to clean the rubber pads and the housing, especially the holes where the buttons come through as there's probably some dirt that keeps the button pressed in, which causes the volume to go up/down all by itself).
hope this helps...
regards
3rq8 (Triarcuate)
Jul 21, 2009 | Samsung TV Remote Control
Autolock problem.
try out the restore factory settings option in settings menu...and try pin as 1234
May 15, 2009 | Nokia N73 Cellular Phone
Handmark Software MobileLists (950142) for PC, Mac Logo
16 people viewed this question
Top Handmark Software Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Alun Cox
Tarpan Shrivastava
Tarpan Shrivastava
Are you a Handmark Software Computer and Internet Expert? Answer questions, earn points and help others
