Hello! My Grundig Vision II LXW 68-9620 DOLBY Screen turns blue when swiched on, then it shows an signe "service" and then it starts to work, after aproximatley 10minutes the screen turns black, and the blue led light on the botom, at the middle starts to blink, after a minute ore two it stops for 5sekundes and then the blinking starts again and goes on.
wyoed1
  • 211 Answers
SOURCE: Screen went black
I am working on one right now with a similiar problem. The power supply is bad in the one I am working on, and sadly, the part is not made anymore. I hope you have better luck than I am finding the bad component in yours. Sorry for the negitive answer.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
javswr
  • 44 Answers
SOURCE: Blue light goes to Orange blinking no sound no picture Screen on
Hi!
Okay, if the screen is white! First, take apart and check the ribbon like cable that goes from your signal board (where you inputs are plugged in) to the lcd controller (under a small metal plate feed the lcd screen), see if loose and or reset! Secondly you either have a bad signal board or lcd controller!
Posted on Mar 04, 2009
  • 1738 Answers
SOURCE: lcd problem
Unplugging the television for about fifteen minutes or so, then plugging it in again.
Posted on Dec 26, 2009
techman007
  • 1112 Answers
SOURCE: I HAVE A 50' PHILIPS
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Posted on Mar 10, 2011
Testimonial: "THANK YOU I WILL GET BACK WITH YOU AS SOON AS I TRY THIS"
  • 51255 Answers
SOURCE: I turned my Sony Bravia flat screen on this morning and got a black screen. The green indicator light goes on but no screen only black.
take it to a repair shop for a diagnosis of the fault
Posted on Jan 09, 2017
Grundig Amira 32 LXW 82-7512 no go
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 27, 2014 | Polaroid Televison & Video
Tv pin code
tray -oooo- or 1000 or 1111 if not tray 8500 this is the service cod
Nov 25, 2013 | Televison & Video
Grundig Lenaro tv: White line appearing on the screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 16, 2017 | Televison & Video
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
My Compaq Presario V3000 has a problem with the wireless on it. Whenever the wireless side-switch is turned on before I turn on my laptop, before it shows the login screen a blue-screen message shows...
you should reinstall the wireless drivers on your laptop go to the hp support site and type in the model number (it can be found on the white service tag under the laptop)
Jun 14, 2011 | Computers & Internet
I have a Creative Zen Vision:M 60 gig mp3 player. When I switched it on, it started to boot up, showing a "Creative" screen, then a "Zen" screen and then a "Zen Vision:M"...
When you reset the player make sure you hold the reset button down for about 10 seconds. If that does not help have you tried hooking the player up and go to your my computer option where the player shows up as a removable device and formatting the player. If that does not help then the HD will need to be removed and formatted out side the player or ran threw some repair software to fix it. If it cant be repaired then it will need to be replaced.
If you need any more help, parts or your player repaired you can go to my repair service web page and e-mial me, call me or contact me threw my Ebay user name at from my web page at firehouse7777.weebly.com Thanks
Dec 02, 2010 | Creative Labs ZEN Vision:M Digital Media...
Grundig TV Model MFW70-3210/8 dolby going black and white
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ///
Dec 21, 2017 | Grundig GU19WDT 19 in. LCD TV
Lcd problem
Dec 26, 2009 | Grundig GU19WDT 19 in. LCD TV
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
How to unlock a grundig t63-640?
Swich off tv from main swicher. Press i on remote control and hold it. Swicn on the tv from main swicher. On the screen should appear a service menu. Under decoder level with volume button from remote change from off to on. The same is with hotel mode for volume control. Exit the service menu by presing i on remote control and have a nice day!
Dec 27, 2007 | Grundig GF70-600 TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
