Question about Dyson DC25 All Floors Bagless Upright Vacuum
I have just emptied the cylinder and can't get it back on again
Loss of suction
do not connect to electricity at this point claim a little work area put a blanket down as you are going to strip it all down into little bits clean and then put it all back,
Take apart power cable unwrap, unclip middle glass cylinder section to empty rubbish out, there should be a filter at the base that you can see now unclip clean put back, empty rubbish out of cylinder clean base and top rubber section and filter section with fine brush, use a wet cloth to wipe clean all black rubber suction connectors put back, at the back there will be a hose connector at the base unplug clean put back and make sure no debris is in any of the connectors and underneath where the floor brush is before you start puting it all back , Hope this helps
Feb 17, 2014 | Eureka AirSpeed Bagless Zuum
My vax power 8, 2200 watts 300 air watts 4L capacity upright Hoover is brand new, I emptied out the dust/dirt collecter and cleaned the motor filter yesterday for the first time, i switched it on and all...
I had the same problem. It looks like the seal on the lid on the bottom of the cylinder has fallen out when it was emptied. There is no longer a proper vacuum being created so you don't get the cyclone effect and the dirt doesn't collect where its supposed to. it just clogs up the filter. I put sellotape to seal the lid and it works fine.
May 14, 2013 | Vacuums
Power won't turn on
Hi Colleen,
I'm sorry to hear you're having difficulty with your DC25. If your machine won't run, it may have overheated due to a blockage, and the filters may also need a wash. You should find you machine will run again once it's had at least two hours to cool down - however, to make sure this doesn't happen again, please follow the steps shown in our online Support guide:
http://www.dyson.com/support/help.asp?article=51&product=DC25-ALLFLOORS
This should resolve the issue, but if you'd like any further assistance or advice, please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Apr 12, 2012 | Dyson DC25 All Floors Bagless Upright...
How to empty cylinder
For guidance on removing, emptying and replacing your Dyson's clear bin, please refer to the user guide supplied with the machine. In case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you need any further assistance, please get in touch with us directly - you can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Sep 24, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I vacuum the upstairs and i go to empty the bag and it doesn't work properly. I turn it on, but it doesn't "come on," then i extend it bend it to use the powerful part and it comes on,...
I'm sorry to hear you're experiencing intermittent power when using your DC17. It's probably best if you get in touch with us directly, so we can resolve this as quickly as possible for you. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Sep 16, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Woh do you remove the clip in plate to repair/ reconnect the power lead to the machine
hi, i take it your going on about the plate thats behind the cylinder at the back where the power lead is,
you know when you empty the cylinder and it all lifts up so you can take the cylinder off to empty well you take the cylinder off and the top half then thats loose can be uncliped as well so unclip this off so the whole front of the vac is off and you can see the area thats behind the cylinder, well once you have access to this part and the part you empty is removed and the part above it is removed, now if you look where the wire goes into the vac at the back now look at the front in exactly the same place and you will see a small panel that should be screwed in, this problem you are having is a very common one and i take it you plan on cutting the wire back and fitting it back in.
so you dont get to the connector from the back of the vac where the wire goes into it you get to it from the other side at the front its behind the top part of the cylinder not the part you empty but the part above that so you either need to hold it up to get to this panel or you take it off so its not in your way then you should see the small plastic panel that comes off, once you have this panel off you will then see the wires and the block they are held into and this is the part you need to undo and cut back.
this panel might be held in place with torque star shaped screws but if you have a good fitting flat headed screwdriver you should be able to get it undone using that.
this panel from what i remember has torque screws, so to get to the wires you need to get to the panel is accessed from the front but behind the cylinder you take off, its exaclty opopsite where the wire goes into at the back and once the panel is off you can do the work you need to do.
this is a very common problem on all dysons and it happens to all of them at some point.
if the panel is not held in by screws then it should just be clipped in place, ive not come across one that has not got any screws but they do bring new models out and change them slightly, so your not getting to the wires from the back of the vac where the wire goes in your getting in fro the front of the vac but you need to remove the part you empty and the part above this that swings out to enable you to remove the part you empty then this panel is located just behind their.
i hope you understand what im going on about, if you have found this panel and its the part your going on about then this should just clip off if it dont have screws in it, but make sure its from the front of the vac not the back their will be a small panel behind the yellow part that swings out to get the cylinder off you empty after its full
let me know how you get on or if you need further assistance ok
Feb 21, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The hoover has just had cylinder emptied, but now wont turn on unless the pedal has been pressed. there does not seem to be much suction aswell
Try taking the cylender back out and put it back in again carefully to be sure it goes in correctly as they need to sit perfect if they don't they will have next to no suction because it is not sealed properly.
Oct 07, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
I cannot get the top of the dust cylinder to empty it
check for any switches, latches or buttons that me lever, slide, twist or completely remove your cylinder.
These have been designed to be intuitive to use. (I know sometimes these machines appear counterintuitive). Patience and you can find the way.
What model/make of vacuum, and we may be able to find a manual explaining how to empty cylinder.
May 10, 2009 | Vacuums
Hi, im hoovering my mothers house whilst she is away, using a vitesse pet lover, but now the cylinder is full and i can work out how to open it so i can empty it. thanks
Lift the catch where the canister lid joins the handle, then pull the whole assembly away from the handle.  Take the assembly to wherever you want to empty it, then press the button at the bottom front of the canister.  The bottom swings down and the muck falls out.  In the ideal world, you will then take the lid off by twisting it slightly anti-clockwise (you'll see the "lock" and "open" markings on the canister rim), remove the pleated filter (again by twisting anti-clockwise), give it a good shake and then brush between the pleats.  Reverse this process to put it back together, and away you go again!
I hope this helps. Any more questions, just ask. Please remember to rate my response, thank you.
Apr 14, 2009 | Electrolux Vacuums
Dyson DC25 All Floors Bagless Upright Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
