Question about Vacuums
How best to open casing on Bosch Formula Hygenixx Vacuum cleaner to get at cable winding system to free jammed cable
SOURCE: I own a self-propelled Hoover
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794479
Generic problem for all Vacuums
Posted by gohornsgo on July 17, 2008
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the HEPA filter on this model (*this model uses a vacuum cleaner bag also).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to clean the HEPA filter is to take it outside and use a blower over the trash can and blow off the dust and dirt, or use things like an old paint brush and brush it off, or you can vacuum it off with another canister vacuum or shop vac if you have an extra one. For the best filtration is to replace it, there fore the air flow will catch most of the dust and dirt and then you would have to watch how fast it gets dirty and then do the maintenance.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 17, 2008
SOURCE: vacuum cleaner by bosch
Visit www.stevessewandvac.com for bags if you don't see them up on the site contact us. On the average you should change your bag once a month regardless of how full this will keep your vacuum from taking on odors of pets or whatever it is you may have sucked up. Also if you happened to have sucked up any food products they tend to start to grow things.
Posted on Aug 12, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
  • 38 Answers
SOURCE: Bosch Formula vacuum cord stuck
You need to take apart the reel. The cord is wound over itself and kinked. Be careful taking apart because if it gets away from you, you will have to wind the spring by hand and it is difficult to do and frustrating.Good luck
Posted on Jul 26, 2009
Vac Belts
  • 701 Answers
SOURCE: How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Posted on Nov 19, 2009
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
Bosch hygienixx formula bsg71266gb/07.Lost my manual and would like a copy. Also can't work out how to empty the bag.
Hi. Visit http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html and follow the link to add the model number in. Also if no joy there contact Bosch UK - they will be happy to help you. Generally this vacuum has a bin door at the top that opens up towards the owner. The hose will have to be removed and the latch is behind the handle. Thereafter the bag can be slipped out and replaced.
Oct 29, 2013 | Bosch Vacuums
I have a dyson 27 hoover and it is stuck upright, i cant tip it back to hoover
Sorry to hear you're having difficulties with your DC27. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, it might be worth using a little more force than usual, in case the upright lock mechanism has jammed. If this doesn't help, or if you're reluctant to try this, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Dyson Customer Service
Aug 10, 2011 | Dyson DC27 Bagless Upright Vacuum
My vacuum will not engage to unlock to vacuum. I turn the vacuum on - that works fine. I put my foot on the part to make it so I can vacuum and it will not unlock. What could be the problem. SOO...
I'm sorry to hear you're having difficulties with your DC28. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, check the clear U-bend at the rear of the machine for obstructions, as a blockage here could jam the valve carriage, making the cleaner difficult to recline. For guidance on doing this, please see the link to our Support page below:
http://www.dyson.com/support/help.asp?article=1236&product=DC28-ANIMAL
After removing any blockages from the U-bend, stand the cleaner upright, and try reclining it again. It might be worth using a little more force than usual, in case the upright lock mechanism has jammed. If this doesn't help, or if you're reluctant to try this, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Dyson Online Customer Support
Apr 29, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
I can't get replacement bags for my Bosch Premium 1300 W vacuum cleaner.
Greetings from GoVacuum,
Your Bosch Premium canister vacuum cleaner uses Bosch Style P Bags.
We carry 2 different types of Bosch Type G bags for your vacuum cleaner.
We have the genuine Bosch Bags Available for Purchase Here;
Bosch Type P MEGAfilt™ Super TEX Vacuum Cleaner Bags
And also in bulk buy here;
3 Pack Bundle Pack of Bosch Style P Vacuum Cleaner Bags Part #BBZ52AFP2U
And we also carry a generic paper style bag that doesn't filter as well as the cloth Bosch genuine bags, but is suitable if you don't have any breathing issues or allergies in your home. Here are the Bosch generic P bags;
Bosch Type "P" Canister Vacuum Bags Generic
I hope that this information was helpful to you. If this helped you, please be sure to rate this as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of my answer.
Feel free to email me at chris.jones@govacuum.com if you have any questions or need further help with your Bosch canister vacuum.
Thank you so much,
Chris Jones
GoVacuum.com
Feb 22, 2010 | Bosch BSG81313UC Premium Bagged Canister...
Vacuum will no longer turn on. Vacuum bag was
Same problem. I suppose BOSCH dumped these into the market and have chosen to disown them. Support is pitiful and vacuums have also been taken off their website. Too bad, was a nice quiet product for the 2 months it worked. Solution = new, non-BOSCH vacuum.
Oct 04, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Jul 26, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Can't refit dustbag to bosch ergomaxx barrel cleaner
The bag slips into the holder which should be attached to the machine. If you have taken this out by mistake and thrown it you'll have to contact Bosch to order a new bag holder.
Jan 22, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the Hepa filter on this model (*this model uses a vacuum cleaner...
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
The cord won't rewind anymore.
all these rewinds are a pain! the rewind mechanism is a spring-loaded coil. fault is possibly that the cable is jammed and you may be able to free it by gently tugging and releasing. otherwise there is a problem with the spring and that is not worthwhile repairting
Mar 26, 2007 | Bosch BSG81313UC Premium Bagged Canister...
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
