I have computer laptop hp pavillion dv6000. It has recently stopping working. I have not used it for couple of weeks. It does not start anymore as if there is no power going through. What should I do
    Guru:
  • 610 Answers
Since you haven't used it for a couple of weeks, the first thing that you have to do is remove the battery and plug the laptop to the power adapter. If there are no other hardware problem in your computer, your computer should be able to turn on even without the battery pack.
If it able to turn on without the battery pack, the battery is just dead and needs to be charge before you can use it normally again. Try plugging the power adapter with the battery pack in the laptop for at least 30 minutes to give it a charge. If you battery has a "drain" button, please press it before plugging the battery back to the laptop and charging it.
Hope this helps.
Posted on May 22, 2011
  • ace_ania May 22, 2011
    I have already been charging it for an hour it is still dead. The power is not going through. Also I have remove the battery and tried running it without battery but it doesn't start
  • Christopher Ian Tecson
    Christopher Ian Tecson May 22, 2011
    If that is the case, you need to have that laptop serviced as the problem lies onthe board or the power supply itself.
    President:
  • 1,607 Answers
Try charging it for a few minutes before turning it on. The batteries might be drained.
2 Suggested Answers
Ezrahite
  • 2632 Answers
SOURCE: I have computer laptop hp pavillion dv6000. It has
Welcome to Fixya. First we need to know if this is a problem with the motherboard or just the adapter of the laptop.
Can you unplugged the battery and use the AC adapter see if you will be able to it on? If NOT, is it possible to use a working AC adapter? just to make sure if this is a problem with the adapter.
After using a working AC adapater and still wont get a power it only means that the problem is the motherboard of the computer and need to be replaced.
If you have questions please let me know. Thanks for using Fixya.
Hp pavillion laptop screen goes black
its the common problem with graphic card, if its nvedia chipset graphic, there is only one temp solution, ask any hardware machanics to put a glue and heat the display ic, then it would work for a week, in that period buy the amc from hp service centre, after a week if there is a prob, company will have to replacd the motherboard
Feb 10, 2010 | HP Pavilion dv6000t Notebook
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
HP Pavillion DV6000 won't start
It's a fabrication defect. For more info about it and free repair see here
Sep 19, 2009 | HP Computers & Internet
Hp pavillion dv6000 headphone mics don't work, external mics work
check external mic in another system.
update the bios of the sytem.
update drivers of sound cards
Apr 11, 2009 | HP Pavilion dv6000z Notebook
HP laptop speakers not working
hi,
whenever you put in the head phones the speaker will stop working and when you take the headphones out they will start working again this is their normal behaviour.
Further Queries are welcome
Feb 21, 2009 | Acer Aspire 3680 Laptop
Hp CUE Status Root has stopped working ERROR
You should try using Windows Restore. Restore the computer back to when it worked correctly. Then try downloading the latest software for your scanner, etc. from the appropriate websites. i.e. support.hp.com
etc...
That's probably the easiest way to do it.
Feb 20, 2009 | HP Pavilion dv9700t Notebook PC
Hp pavillion dv6000 - speakers buzzing after recording
First of all, check if the issue is with the Microphones of your Notebook.
Try disabling or turning off the Microphone of the Notebook to check this.
Additionally, try reinstalling the Audio Drivers of the notebook if possible by checking the Notebook driver page.
Sep 06, 2008 | HP Pavilion dv9000z Notebook
Beep from computer
My lap is also dv6000 and i have no symptoms like that.
it seems some thing is going wrong inside. As your lap is under warranty you should contact your service centre, it will be free.
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire One PC Notebook
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
