Question about Hyundai Computers & Internet
After 20 minutes since I start computer and my Hyundai W241D monitor the screen start to shake more and more constantly. I check my monitor on other computer and problem was the same.
4 Suggested Answers
  • 1129 Answers
SOURCE: MY 92 CUTLASS AFTER 20 MINUTES STARTS SHAKING
if a temp. light does not come on and the engine is not over heating I would look into the ignition components such as ignition module inside the distributor, sometimes when these components heat up they can cause this problem you described
Posted on Jul 03, 2009
  • 1684 Answers
SOURCE: Samsung 214t syncmaster flickering
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine.We just posted a repair guide showing how to remove the case ansreplace the parts. The capacitors do need to be installed with thecorrect + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 25, 2009
SOURCE: My HP 1740 monitor keeps going in to "auto
Press and hold button "Auto Adjust" or "Menu".
Posted on Jul 25, 2011
Hi, I have a problem with a Hyundai W240 monitor. When it's been turned on for a while (15-20 minutes or so) the screen starts to flicker/jump really fast. The longer the monitor is on, the worse the...
Hi Mjau_beibi,
Technically, yes. It requires a level of expertise though. You would want to start by replacing the pixel panel. (Which is inside of the monitor and requires knowledge of monitor repair) - I would not recommend doing it yourself unless you are familiar with in-depth repair of components like this. Depending on the cost of the repair, it may be worth it to purchase a new monitor unfortunately. Sorry for the relatively bad news. Hope all works out! - Cheers!
Oct 04, 2017 | Hyundai W240 Monitor
When pc left on after 15 minutes the screen keeps changing colours from reds /greens /greys/blues constantly is this normal
Maybe this is a Screen Saver, set to start after 15 minutes. Open up Control Panel then Appearance and Personalization, then Screen Saver to check on this and perhaps choose a more pleasant screen saver.
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
Display shakes on monitor
Try these, 1) check the pins on the leads into monitor and computer thy tend to bend,
2) check there is no mains near the cables or monitor, it can cause feed back (EMF)
3) check the graphic card "if fitted " is not lose, unplug computer, then switch on comp without plug in socket, this will purge the board of any electicity, remove graphic card check for dust ect clean and then replace, put plug back in socket and switch on.
4) when a moniter is first switch on it purges the screen "degauses" "maybe spelt wrong" if it is constantly doing this it will be a fault within the screen.
5) Try a different cable that you know works it could be a break in the cable someware.
grandpaben
Aug 16, 2009 | Computers & Internet
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
ACER AL 1912 Colors bad screen shakes
your asking which part you want to replace. try first to check all the connections.
Jan 02, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
Monitor goes blurry, colours/pixels start shaking across screen
Do you have your screen saver enabled, i so turn it off and se if it still does it. Secondly boot your pc in safe mode(pressing F8) on boot up and select start windows in safe mode. See if the monitor still does it, if so a monitor fault or loose/faulty vga lead. If it is ok then your graphics driver may be corrupt and need re installing.
Dec 30, 2006 | BenQ FP71E 17" LCD Monitor
Computers & Internet Logo
142 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
