Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I am using the WD5000ME external hard drive and everything looks good till last last year..And after that when ever i connect my hard disk..the autoplay starts...stops..starts..this goes on (cycling)... It seems like my hard disk connection is being lost multiple times. Any help will be greatly appreciated as i am not at all able to use my hard disk at all.
    Scholar:
  • 106 Answers
alright, so, it can be a number of problems. I will try to address everything that i think might be the problem.
Use these steps one by one until you get a solution.
1. First of all, update your anti virus software. The autorun.inf file on external drives gets attacked by viruses and corrupted quite often.
2. Try manualy deleting the Autorun.inf file from your hdd. (this is a hidden file, you will have to use the Folder Options "show all files" to see it.
3, Disable the Autorun option for the hdd from the operating system. (Sometimes the OS get's confused about the hard drives and their boot up sequences,) Refer to this link to do it in XP, if you are using Vista or Win 7, then do this: type "gpedit.msc" in Run...go to "Computer Configuration > Administrative Templates > Windows Components > AutoPlay Policies > Turn Off auto play for all drives....." Repeat the same going to "User Configuration > Administrative Templates > Windows Components > AutoPlay Policies > Turn Off auto play for all drives....." This will not work if you have Home Premium Editions, there's a optional workaround for this in those editions, but if you have Home preomiums, then skip this step.
4. If all of the above doesnt help, then try this: right click my computer, select manage. select disk administrator. right click each of your drives, select "change drive letter and path" and remove the drive letters for each. reboot. go back into disk administrator and give them drive letters again.
5. If none of these steps worked, the cable and connectors themselves may be damaged or not connected properly. Try to find another cable to connect ur hdd, see if it helps you. If not, then maybe you should take it to a service professional and see if they can help you.
Posted on May 22, 2011
Hello, I have an external hard drive western
First of all, I'd like to make sure I understand what you meant in regards to the simple pine connectors. I assume that they look like a series of jumper pins, is that correct? any pictures? If so, those connectors don't need to be connected to anything. They are there in case you want to bypass the USB connector.
Is this an USB 3.0 or USB 2.0 drive? Are you using the official WD cable to power this up? these drives (especially USB 3.0) tend to be power hungry, and if the cable is worn out or too long, then it may not deliver enough power to let the drive operate. Any other feedback would be good for me to understand your problem further =)
Sep 10, 2013 | Western Digital Passport Computers &...
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I have been using a seagate freeagent Go 500GB usb hard disk without any problem for the last one and half years, sparingly, to take up system backups. Couple of days back, my computer recognises this...
Is the drive's warrany still valid?
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive. Check Seagate's web-site; they offer a "no-charge-if-we-cannot-recover-your-files" service.
Nov 05, 2010 | Seagate FreeAgent GO 500GB 5400RPM...
I have a cavalry CAUE37500 500GB 2.0 that I have literally used less than 50 times since I bought it a few years ago. I haven't used it for the last 6 months, but thought it was a good time to delete...
> ticking of a watch ...
A typical sound from a disk-drive that has malfunctioned.
If it still has a valid WARRANTY, exercise the warranty to get it repaired/replaced.
If the warranty has expired, then open the case, remove the disk-drive, buy a new "compatible" disk-drive, connect it, and thus "revive" your external storage device.
Oct 23, 2010 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
I am using simpletech 320gb for last 1 year.now the speed of copying and pasting files is very low......what should i do to increase the speed?
The drive may have gotten badly fragmented. Connect it to the PC, and run defragmentation, say, overnight (may take long with an USB drive).
You can use the defragmenter built into Windows (found in drive's Properties, Tools tab), or better use a 3-rd party solution, like DiskDefrag.
There may be other causes as well, but defragmenting the files/folders on the disk would be my first move. Good luck :)
Jun 21, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Dropped my external drive WD5000ME and not it does not work any ideas
check SATA / IDE connector inside if loosen...maybe light is on but no signal..
May 24, 2010 | Western Digital My Book Essential Edition...
External hard disk not detected in explorer
Try a different USB port and verify the cable is good.
Jan 20, 2010 | Western Digital 320GB MyBook External USB...
External Hard Disk
When you plug your external HD, did you see 4 drives? What file system your using? NTFS or FAT32? what OS?
Aug 19, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
My mac cant see my minimax 500GB, it powers on and spins up, but i cant see it on my desktop. I'm using the firewire cable.
The above answer is wrong. All MiniMax drive are formatted for Macs out of the box (that why they are shaped exactly the same as a mac Mini).
Try connecting with a USB lead to see if that works.
These units are generally very good (i've installed about a dozen in the last year) but I have known some be DOA (I've only had one). Do other externals work in your FW port? If they do, plug them into one of the other ports on the MiniMax and see if they still work.
There is always a chance that your FW port is faulty - they have been known to need resetting (you'll have to google that as I can't remember the exact procedure - I think a quick way is to disconnect everything from the mac - yes everything! and leave the mac sitting naked and forlorn for about 20 minutes, then reconnect everything including your minimax and power up the mac. With luck it should come on and mount. Let us know what happens.
Jul 15, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
212 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
