Question about Dell Latitude C610 Notebook
I can't open my DVD-RW disc - Dell Latitude C610 Notebook
  • Dell Master
  • 32,281 Answers
You can manually open the DVD tray by inserting a straighten paper clip into the tiny hole in the tray. Gently push the paper clip in this hole and the tray will pop out, then pull the tray fully out in the openned position and you can then remove the disc.
If the disc tray does not open normally when you press the eject button then the DVD drive may be faulty and needs to be replaced.
Posted on May 22, 2011
  • 1,511 Answers
Hello and Welcome to FixYa!
If you are having problem with ejecting your optical drive please watch the video tutorial and follow the instructions.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
2 Suggested Answers
copper7op
  • 30 Answers
SOURCE: Will not process DVD -R, +R, -RW, +RW discs
You need to get a program such as Nero or Roxio that can burn them. Once you do this, you'll be able to write content on them for use in other computers.
www.nero.com for a free demo of Nero 9
Posted on May 01, 2009
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
What brand of DVD+RW will work in RCA EZDVD1BD?
Rule of thumb. a DVD-R is the most reliable and will work in ANY DVD RECORDER. ALL RW discs are hit or miss and not reliable, no matter who makes them. DO NOT BUY discs made by Maxell or Memorex. They are **** and should be illegal to sell. Verbatim brand is by far the most reliable. If you are buying RW's because you want to reuse them over and over...give up and use -R's. your life will be much happier.
Aug 02, 2012 | RCA EZDVD1BD Digital Camcorder/ DVD...
Nec dvd rw nd-3450a write error
Open the dvd writer & clean the pick up lens with ethyl alcohol or isopropyl alcohol by using cotton swab.
Nov 24, 2011 | Dell Computers & Internet
My disks are DVD-RW and want tp use them over gain and don't know how. Also when do I finalise then and what for
For RW discs, you need to reformat them to reuse them. For your laptop, you should see a format option if you right click on the DVD icon when you have the File Explorer open to Computer (My Computer). (This assumes that the computer has a DVD writer.)
Finalizing the disc enables the contents of the disc to be read on other DVD players. (This isn't always an issue. For example, a disc burned with WinXP should be readable for a computer with Windows 7 without finalizing. However, if the disc was burned by a DVD player, the contents will not be accessible on any other units without being finalized.)
If the disc has been finalized, you need to take another step before reformatting the RW disc. Put the disc in the unit that initially finalized it. Then look for an Unfinalize option. Then format the disc again. (I've never used this feature on my computer. It's easily accessed on my DVD recorder in the same section of the submenu as finalizing the disc.)
I hope this helps.
Sep 12, 2011 | Computers & Internet
How do I remove write protection from a DVD-RW?
Your M35X-S1143 model - assuming it still has the stock drive - has an DVD / CD-RW optical drive - i.e. it will write only to CD's but not DVD's. If you try to burn a DVD, it'll tell you that the disc is write protected (when in fact, the drive doesn't even know how to write to a DVD disc.); if you go ahead and burn a CD, you will not encounter the write protection warnings.
Aug 31, 2011 | Toshiba Satellite M35X-S1143: M35X-S1143...
Disk formatting fails every disk. I used new dvd+rw..
What do u mean by formatting?U can't formatted the DVD+RW disc to blank again,after the disc been recorded and used.DVD+RW recodering mean something are recorded u can recorded some elese in it replaced what was there,that all u can do to it.U can't wipe out what in the disc data was there.
Aug 04, 2011 | Cyberhome DVR 1600 DVD Recorder
How do i get my th-a9r to play dvd-rw
You can't. The Laser will only Play +R & +RW.
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
Apr 23, 2011 | JVC TH-A9 System
I own a Toshiba SD-3980SU2 DVD Video Player. I keep getting an Incorrect Disc comment, and bad comment. I an using DVD-RW discs. I have tried disconnecting and reconnecting the player.
You are probably using incorrect disc formats in this DVD player; try DVD+RW if you must use re-writables, or DVD-R (finalised in a recorder or burned on a PC). I doubt this model supports DVD-RW, so the problem wouldn't be with the player; it would be the formats of the discs you use.
Don't use DVD-RW discs in this player if it does not support that format.
Apr 22, 2011 | Toshiba SD-3980 DVD Player
Format dvd rw
if your noterbook comes with a dvd-rw drive, then you can format dvd-rw discs by opening your burning program like Nero and selecting the "erase disc" option
Oct 22, 2008 | HP Pavilion dv6000z Notebook
Dell Latitude C610 Notebook Logo
156 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
