Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Code c8 showing on our Bosch Exccell dishwasher - what does this mean?
3 Suggested Answers
  • 10 Answers
SOURCE: Electrolux dishwasher error c8 What does this
C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
3) bad luck
now you must reset c8 from the parameter in order to start again the diswasher
kostas
Posted on Feb 11, 2011
Macmarkus
  • 2605 Answers
SOURCE: My Bosch integra dishwasher is showing "*1" where
Welcome to FixYa.
Based on your description
I'd say the issue actually is with the control...unfortunately. This is commonly associated with a heating fault on Bosch built dishwashers ( various models including Bosch, Thermador, Siemens, Gaggenau, and Neff ).
Since the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
These are the steps you'll need to follow to resolve it or at least investigate.
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e. ( this may differ from your specific model, but the same rules apply )
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last.
Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Feb 24, 2011
Bosch dishwasher S16P1B shows code E:09 before the end of a cycle. What does it mean
An "E" on any appliance means error. perhaps your drainage needs cleaned out....
Apr 04, 2018 | Bosch Dishwashers
How to start a diagnosis test on Bosch dishwasher model SHE3ARF6UC/21 will not start because of E01 code
Error code E01 means that your Bosch dishwasher is experiencing trouble with the motor.
Feb 19, 2018 | Bosch Washing Machines
What does E14 mean ?
The code can mean different things .check the manual that came with it . the manual will also show how to do a self test .
Oct 20, 2014 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher electrolux wt30 error code c8
Hello Said Raji - Are you certain the error code is C8? Could it possibly be CE? If so, it typically indicates that the dishwasher has detected a configuration error. A professional will need to check the wiring connections between keypad and main control board.
Jan 16, 2013 | Electrolux WT30H240DU Dishwasher
Zanussi dishwasher LS9 AD/G1 reading code C8 and not working
C8 - During rinse phase boiler doesn't empty:
  • Rinse pump not efficient.
  • Rinse arms obstructed.
  • Boiler level sensor out of order.
Dado
Jun 25, 2012 | Zanussi 29 in. LS14 Free-standing...
Electrolux wt55 error code c8
If there is a set button hold it for 5 seconds.
The reasons are ..
now you must reset c8 from the parameter in order to start again the dishwasher
May 05, 2011 | Dishwashers
What does the display C 8 stand for as i am not able to start the dishwasher
The reasons are ..
3) bad luck
kostas
Jan 17, 2011 | Electrolux 504199 Dishwasher
Electrolux dishwasher error c8 What does this mean please??
The reasons are ..
3) bad luck
kostas
Nov 08, 2010 | Electrolux 504199 Dishwasher
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
1,199 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
