Question about Suzuki Boating
Suzuki df4 4hp 4stroke outboard will not start and will not even fire after leaving petrol in during winter. fuel to carb ok. slosh a small amount of fuel into air inlet on carb then it fires but will not run. Taken out and cleaned the jet on the top of the carb but still no good. Do I need to strip the carb & if so how difficult is it to get it back together and what replacement parts do i need if any. any other ideas please? The engine is 4 years old.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Suzuki Master
  • 1,190 Answers
Totally strip carb and clean properly ! as u take it all apart lay it out in order on work top , even take notes etc ! pictures even ! easy !
Posted on Jun 08, 2014
SOURCE: Hello, I have a 2001 Suzuki 5hp outboard. 2
Check the needle valve that the float holds in position is free to move if it is check the float is working OK ie.whole and intact.
Posted on Sep 09, 2010
  • 8 Answers
SOURCE: My 2 stroke 3 cylinder carbureted 90 hp Yamaha
Just pull them apart and clean.
Posted on Nov 07, 2010
bonedivers
  • 1140 Answers
SOURCE: trying to identify hp & year of old outboard
try searching mercury marines web site
www.mercurypartsexpress.com
Posted on May 20, 2011
goldbill
  • 184 Answers
SOURCE: tohatsu outboard 15hp 2 stroke was running great,
First: with flashlight or mirror look down the carb- with switch off- and gear and throttle wide open and see what the butterfly valve inside there is doing. It should be parallel to the air flow.
If not you need to find the actuator am and be sure it moves with the control and opens all the way.
Next make sure the timing plate under the flywheel moves at the same time the throttle is opened. Then -using timing light- see if the timing is set to the correct "wide Open throttle" - this is a 2 man job done at sunset with good marks on the flywheel (don't wear a tie). This can also be done static by running it out of gas and using the pull cord- if it has no safety interlock.
Last- and the saddest part- is the compression test. The strength of the reading is not as important as the similarity. When I worked on Chryslers, they were bad if the two readings were as little as 8# apart. The minimum reading should be over 80#.
Posted on May 26, 2011
philwalker78
  • 608 Answers
SOURCE: Hello i have a Suzuki
Hi, basically the carby needs to be stripped down and all jets cleaned out. Also the idle speed may be set to low. Hope this helps, regards Phil.
Posted on Sep 06, 2011
What should I check to repair this problem? Vehicle has spark and gass flow, but will not fire.
that leaves compression
or coil....can be ok when cold fails when hot
rings worn or valve clearance to check
Oct 12, 2016 | ATVs
I have a 02 Yamaha yzf600r no start fuel is pumping, crank with starter fluid so theirs fire it's like gas is not going into carbs.
Jets might be clogged up or trash in carbs. Remove carbs and service them, then sync them again. This is common on any carborated bike that sits for an amount of time (like during winter), ethanol in modern fuel is also known to clog up carburetors.
Jun 09, 2015 | 2002 Yamaha YZF 600 R thunder cat
Does a ***** boy 50cc have a reed valve? Bike
Hi first thing what is the bike second thing is the engine a 2 stroke, if it is 2 stroke it most prob. has a reed valve, check that the carb needle valve is working as it should, then drain the cylinder and crank of fuel check the plug sparks, leave the carb off and put a small amount of petrol in it, try and start it if it fires once or twice, then it should start with the carb on it, if not there is a problem with the carb. good luck.
Sep 12, 2014 | Motorcycles
How to adjustment jets on a suzuki 115 hp outboard 1989
I am not familiar with the Suzuki brand but short of small motors (under 25 hp) most if not all motors by 1989 are fixed jet and not adjustable. If fuel is the problem, cleaning it the answer.
Jul 07, 2014 | Light Outboard Motor Boat Bass Fishing...
Suzuki outboad 6hp 4stroke
outboard motor yes ? only run in a tub or water attachment turned on before starting ! after 2 or 3 min the choke should be able to go off ! if not then remove the carb and clean jets etc with carb cleaner ! been stood a while ? fuel older than 5mths is off so replace also ! ??
Apr 20, 2014 | Motorcycles
I have fuel and I have fire but the bike still wont start. Any ideas and suggestions would be appreciated.
Start with spraying a small amount of fuel into the cylinders past the carbs. If she hits then you have carb. problems. A good tool for this is a small syringe like used for injections. Open the throttle all the way and squirt some gas right in the cylinder.
Sep 10, 2011 | 1998 Suzuki VZ 800 Marauder
My ariens snowblower only works in the choke position. once i turn it where it sould be it stalls
had same problem with a small 2 cycle outboard motor last year. I had run it during the summer, put it away for the winter and when I went to fire it up the following Spring it would only run with half to full choke. Old fuel had gummed up the carburater by letting it sit in there for a few months, had to disassemble and clean all the carb parts (including the jets) and it worked good as new. You could do it yourself or take carb to a small engine repair shop and have them do it. May or may not require a rebuild kit depending on how gummed up it is. Hope this helps.
Feb 10, 2010 | Champion International Champion& Small...
LEAKING OVERFLOW PROBLIM
it sounds to me like the carb float levels are out of adjustment and it is overfilling the bowls,or,the needle valve seats are worn and leaking,which will allow fuel to continue filling the bowls even though it looks like they are closed,remove the carbs from the bike,remove the bowls,turn the cabs upside down close the floats(push them right to the top,this simulates full bowls)then blow throgh the fuel inlet pipe,if you can hear air escaping from around the seats they are faulty,also check that the seats themselves are tight in the carb body,i dont know why but gsxr carbs seem to shake the valve seats loose..hope this helps
May 30, 2009 | 2000 Suzuki GSX-R 600
Boating Logo
465 people viewed this question
Top Suzuki Boating Experts
Steve
Steve
ray gallant
merc racing
Level 1 Expert
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
