Question about Dell Dimension 3000 PC Desktop
I have a DELL imension 3000 that is showing a blank screen when booted up. I have ran an express diagnostic check and it has given me the following error: Error Code:0f00:136C IDE Device Failed: Blank media or no media present in optical drive. Need advice as to how to resolve this problem as cannot access anything on PC
    Scholar:
  • 106 Answers
1.If there's a cd or dvd in the cd/dvd drive, remove it and try booting again.
2.press DEL at the start up screen to go into BIOS. go into BIOS and change the boot sequence options, set it to boot from the hard drive.
Posted on May 22, 2011
Why Dell inspiron 6400 LCD screen goes blank when I unplug the ac adapter from laptop?
  1. Restart the computer.
  2. As the computer boots, press <F12>
  3. when the Dell Splash Screen appears.
  4. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics and press <enter>
  5. A graphical menu listing all discovered devices in the system is now displayed and the express diagnostics should run (Takes about 4 minutes).
This will test the hardware on your computer.
I am thinking it could be the battery but this is just to be sure.
Aug 06, 2014 | Dell Inspiron Computers & Internet
Dell latitude E/6400 blank screen worked yesterday
run the dell diagnostic by turning the laptop on and tapping F12 key when you see the Dell logo
keep pressing F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
during the test it will beep and display colored bars then ask your if the colored bars were displayed. to press Y for yes and N for no
this test the graphics/video chip on the computer to see if the hardware is working.
You can also connect it to an external monitor like a monitor that comes with a pc.Then press and hold the "FN" key and press the F8 (CRT/LCD) key to toggle the external monitor. if the image is displayed in the monitor then it can be a lcd screen or lcd inverter in laptop.
hope that helps
Feb 27, 2014 | Dell Latitude D630 Intel Core 2 Duo T7250...
Spot screen
Hello
First find an external monitor to test if its the screen on your laptop or the graphics chip in your laptop. If you have an external monitor then hook it up to your laptop and toggle the video over to see if you still see the spot.If it only shows on the laptop screen the Replace the screen.
Another thing you can do is run the built in Diagnostics
Diagnostics before windows using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen.
Dec 18, 2013 | Dell Vostro Computers & Internet
During boot up of my dell studio 1537 laptop it just keep repeating the dell studio load screen
If PC is not going further Dell logo screen then most of the time its a hardware issue. You can try only to steps to fix this issue easily.
1.Ran a diagnostic of dell by Cd
insert your dell drivers and utilities disk into your drive>>turn off the comp>>restart the comp by pressing F12 key>>you will boot menu now>>choose the option boot to utility partition>>hit enter>now it will show you 3 test> choose Express test and hit enter>>now it will start checking your hardware component of your computer
2.If hardware diagnostic pass then you can try dell factory rectory restore.
if you have xp they try this:-
1.Turn off the computer>>restart the pc by pressing alt+f11 again and again>>now you will get the dell factory restore wizard and follow the on screen instruction. sometime it does not show you the dell factory Restore screen in case if it is damage or corrupted.
hat screen if
If you are using Vista or window 7 then follow this:-
  1. Restart the computer. To do this, click Start, click the arrow next to the Lock button, and then click Restart.
  2. As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
  3. Press the downarrow.jpg(Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
  4. Specify the language settings that you want, and then click Next.
  5. Log in as a user who has administrative credentials, and then click OK.
  6. Now you will get Recovery Tool so here Choose the last option dell emergency backup/factory restore
7.Hit enter and next and next and enter your personal information like country, user name, language etc....and finally you will get you desktop welcome screen.
cheers!
Let me know was this helpful.
Mar 22, 2011 | Computers & Internet
My dell vostro 1510 vista starts shows the dell screen then goes blank iv tried to boot it iv tryed to restore it but its still blank please help sharon
Seems like the computer might have some hardware issues on it...
So try to run a hardware diagnostics on the computer
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
Dec 07, 2010 | Dell Vostro 1510 Laptop
No Sound Dell Dimension 3000
1)Check whether sound is enabled in bios.
2)Install Latest drivers from support.dell.com
3) Boot From the ResourceCD to Run Dell Diagnostics
1. Insert the ResourceCD in the optical drive, and restart the computer.
2. Tap the <F12> key during startup until the One Time Boot menu appears.
Note: If the One Time Boot menu does not appear, restart the computer and try again.
3. Press the <Down Arrow> to highlight Boot from CD, and press <Enter>.
4. In the ResourceCD menu, select Run the 32 Bit Dell Diagnostics, and press <Enter>.
5. The Dell Diagnostics screen appears.
Run sound test
Jan 10, 2010 | Dell Dimension 3000 PC Desktop
Won't fully boot. Get windows screen, then it stalls gray
reformated twice? have you already ran diagnostics on the hdd? check first the hdd thru diagnostics it might the hdd causing the problem. if no errors found in hdd make sure it was reformated as clean install. your hdd might have partition and just reinstalled OS on he same partition without deleting partitions. Try deleting partitions then create new partitions then reinstall OS.
Oct 21, 2009 | Dell Latitude D610 Notebook
When running diagnostic for Dell computer was given error code OF00:1A44. I ran the diagnostic becasue I was unable to get past the blue screen in Windows - error there is Unmountable_boot_volume.
Boot to the XP CD, Enter recovery console by pressing "R" at the 1st prompt, run the command CHKDSK /P and see if the system will boot normally after the command finishes running. If nothing changes, then the hard drive will need replacement
Jun 18, 2009 | Dell Inspiron 6000 Notebook
Dell "Drivers and Utilities" CD
NEEED TO GO INTO CMOS SET EVERYTHING UP DATE THE HARD DRIVE , CD ROM, DVD, FLOPPIES DRIVES,HD DISK, HDS, CYCLDR, SETORS,
C-MOS BATTERY MAY NEED TO BE REPLACED,
ROD
DRIVERS
WWW.DELL.COM/DRIVERS
WWW.MOTHERBOARDS.ORG
WWW.MRDRIVERS.COM
WWW.DRIVERSHQ.COM
WWW.TOMSHARDWARE.COM
WWW.WINDRIVERS.COM
ROD
GO ON LINE AND TYPE THE FOLLOWING;
DELL LATITUDE D600 DRIVERS
OR
DELL INSPIRON 1150 DRIVERS
ENTER
ROD
Feb 10, 2009 | Computers & Internet
Blank screen when powered on.
Do you have any CD’s that came with your laptop? If so, look for one that has “Diagnostics and utilities” listed under the “Contents”. To boot from that CD disk, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. You can also boot from the Windows reinstallation disk. If the computer boots from either CD, then your Operating System is corrupted and needs to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Inspiron E1505 Notebook
Dell Dimension 3000 PC Desktop Logo
177 people viewed this question
Alun Cox
