Question about Olympus Stylus / mju 1040 Digital Camera
I have been having this problem with my Olympus mju1040 for quite sometime. Everytime i tried to charge the battery when the battery low signal is blinking or when the screen blackout, it will be fully charge in less than 10 mins. I wonder is it the batteries problem or the charger? when i thought it is fully charged, i place it back into my camera and after a few shots the battery die off again. It is really frustrating when im travelling which require the use of my camera for the whole day not like a few shots eventhough the charger show the batteries are fully charged. I bought an extra battery as well but the same problem happens. Please help as another friend of mine experiencing the same problem.
    President:
  • 1,607 Answers
Try charging it for an hour even if it is indicating that it is already full in 10 minutes. If the battery still gets drained after a few shots, then you should change your charger.
Posted on May 22, 2011
I have a olympus 7010 digital camera. everytime i try to turn the camera on, a orange light flashes and turns off. i've tried charging the battery numerous times.
The Olympus Stylus 7010 has a rechargeable lithium ion battery that will eventually wear out-- your battery could be at the point where it does not hold a charge any longer.
Have you previously noticed a degradation in battery life? If so, you can try replacing the battery or connecting the camera to a constant power source (like an AC adapter) to troubleshoot.
Mar 04, 2011 | Olympus Stylus 7010 Digital Camera
Hi Everyone, I have recently bought a new Iphone
Make sure that your WiFi is not left on all the time and that the signal is strong as weak signal affects the battery. Adjust the screen brightness to low and avoid using the phone for games etc to maximise battery life.
Oct 20, 2010 | Apple iPhone 3G
Nimh batteries give low batt signal even when
the trouble with rechargable batteries is their voltage is low to start with even when charged. they only give 1.2 volts each instead of 1.5 volts from proper AA bateries. I use Energizer Lithiums in all my camers and they are great and last a long time. You can find cheap suppliers on eBay I use a site called 7dayshop.com in jersey (europe).
Jul 25, 2010 | Olympus FE-25 Digital Camera
My Olympus Camedia D-540 Zoom sometimes battery registered as full and I go to take photo then message battery empty. Can anything be done?
Try using "fully charged" NiMH batteries. If you still experiencing "low battery", you may have a "leak". Your next option is the service center.
Sep 22, 2009 | Olympus Camedia D-540 Zoom Digital Camera
When I load fully charged batteries it comes up with the 'battery low' warning and sometimes 'zoom error'
Believe it or not, the batteries are not fully charged.
1. Use alkyline batteries to test if camera is ok.
2. Carry a spare set of alkyline batteries
3. Don't mix battery types or mA sizes
Sep 01, 2009 | Olympus SP-310 Digital Camera
False low battery warning
Same thing happened to me when I used alkaline batteries. Have you tried fully charged NiMH? If not you may have a "leak". Your next option is the service center.
Jun 27, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Battery charger won't charge
I'm sorry to say I don't know much about Olympus digital cameras, I've never had one on the bench.
I would take your camera and charger to a shop that sells Olympus batteries try a different battery first, this way you can try it out before you buy and make sure the camera and charger are working ok...
The battery is a Li-Ion, when these get flattened too far they shut down and will refuse to charge, they can sometimes be recovered by using a power supply to lift them but you must be very careful (use a 300ma wall wart at just over the rated voltage of the battery for 10 mins then put it back in the charger) as they can catch fire if over charged, shorted or connected backwards also if its been so flat it refuses to charge its certainly past its best and should be replaced as its likely it will let you down again.
On the other hand it could be the charger, so best to try and check out both before buying anything.
If it happened very suddenly and the battery was still able to run the camera for quite a while I would think a charger problem is more likely, if the battery has been taking less time to charge recently and lasting shorter times its more likely the battery..
Having said that the protection circuits can shut down a seemingly good battery for other reasons.
If you find its the charger third party (non Olimpus) chargers are available quite cheaply on ebay as are batteries
Best of luck
Jun 14, 2008 | Cameras
Olympus FE-280 Digital Camera problem
I had the same problem.
First the obvious, Is your charger actualy charging? Have you tried another Battery?
Sometimes the charger led turns green, when it actualy never charged the battery.
Jiggle the battery around to make sure it is seated securely. If in doubt find a friend with a Volt meter (VOM ) and check that the battery voltage is 3.7v to 4.0v when fully charged.
Assuming that you now have a fully charged battery. it's time for a little house cleaning. Use a Q-tip and Isopropal alcohol .99 cents a bottle. (Not Rubbing, it contains lanolin).
Gently clean the contacts on the charger and the battery. You dont need a lot. A little dab'l do ya. You can also clean the contacts on the charger with a pencil eraser if they look a little corroded.
Now it gets a little more fun. Look down inside the camera battery compartment and make sure the spring contacts are sticking up far enough to contact the battery, also make sure the battery eject spring is not bent and interfering with the contacts or the battery.
If you feel confident, gently, very gently, clean the contacts in the camera.
Only wipe towards the center once or twice. If you wipe the other way, you will have
cotton fibers wrapped around the contacts. not good ! If you do not feel confident cleaning inside the battery bay, Dont!....... send it to Olympus. I hope that does the trick for you. Nice taste in cameras by the way. Sumthin
Mar 31, 2008 | Olympus FE-280 Digital Camera
My Olympus Stylus 500, doesn't work the flash
hi
have you tried using lithium batteries? alkaline batteries. just try out different batteries. if it is still the same, have your camera checked in a service center for maybe it needs a replacement or there is something loose inside.
hope this helps.
Jan 28, 2008 | Olympus ? Stylus 500 Digital Camera
Olympus Stylus / mju 1040 Digital Camera Logo
190 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
