Question about Iomega ScreenPlay
I turn screenplayer on it hums but yellow light blinks when i push the front button no content display on laptop and tv displays it has no disc
Did you ever find a solution for this? I'm having the same problem...
Posted on May 28, 2011
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
Aug 02, 2014 | Acer Veriton Computers & Internet
Reset clean light
Did you clean the machine? When you went through the cleaning steps it should have cleared the clean light. I will tell you what to push first Remove the front cover. If the machine is operating then push and release the harvest button. When the machine completes the Harvest cycle it will stop. Push and release the OFF button. Push and release the clean button. The yellow clean light will blink and display will show C. The machine will drain the reservoir and refill it. Go into the next step when the reservoir has filled. Allow the the ice machine to circulate water for at lest 10 minutes. Normally this is when you would add your cleaning solution but i take it you have already cleaned the machine. Now push and release the Clean button again. The yellow Clean light will be on continuously and the machine will drain and refill the reservoir repeatedly to purge out the ice machine. Now Allow the drain and refill process to continue for at least 20 minutes. Now Push and release the OFF button. The clean cycle will stop and the display will show 0. Now push and release the on button. This should have cleared the yellow clean light. Now with that out of the way if it did not clear it then you will need to replace the control board. The machine will steel make ice with no problem and you just clean the machine every 6 mounts. The yellow clean light is just to remind you that it is time to clean the system. The board is quite costly.
Apr 24, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When i connect my screenplay director to my tv the picture is in black and white, how can i fix this problem?
Confirm that the ScreenPlay Director is correctly connected to video input on your TV set.
Make sure the ScreenPlay Director is connected to power and turned on.
Make sure you have selected the correct video input on your TV to display output from the ScreenPlay Director.
The video output setting on the ScreenPlay might not be correct for your TV. Press the TV SYS button on the remote control repeatedly until the screen displays normally.
Try on a different TV, you TV may not be supported with this device.
Oct 25, 2010 | Iomega ScreenPlay Pro MP3 Player
Displays No Disc on TV
Hi jasnarysheuv,
Did you fix the problem you had? If so could you tell me what you did? I formatted my Iomega Screenplay HD Mulitmedia Drive (500gb) last night on my mac and now it displays 'no disc' when I hook it up to my tv.
Any help would be grateful.
Sep 28, 2009 | Iomega ScreenPlay
61md10 front panel controls lit uo, but the TV does not respond
With a non responsive remote that would be inpossiable you need to replace the control board inside around $100 bucks then you can have a good tv again but to get to the service menu your controll has to be working.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
InFocus ScreenPlay Projection HDTV does not turn on
try accessing the service menu and doing a factory reset on it
Jul 30, 2009 | InFocus ScreenPlay 61" Rear Projection...
Display reads oil at 15%
You will have to reset the maintance light. Turn the key in the on position.( Not the crank position ) Push the trip meter button until you see the mileage reading. Now turn key off and with left hand hold in trip button. While holding in the button with left hand turn key to on position until you see dash lights. Hold button in until light starts to blink then after 4 blinks release button for 4 blinks then hold in again until light resets. If it doesn't work try trip A instead of mileage reading.
Apr 27, 2009 | 2006 Honda Accord
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Iomega ScreenPlay Logo
158 people viewed this question
Top Iomega Televison & Video Experts
Martin Murray
Chris Larocque
Are you an Iomega Televison and Video Expert? Answer questions, earn points and help others
