I'm have laptop asus model k50IJ did not turn on and did not charge please help me thank you
  • 32,281 Answers
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on May 22, 2011
My ASUS K50IJ sound comes from only one speaker. I've tryed everything and the balance seems ok
One of the speakers failed or it has a bad connection.Most likely the non working speaker will need to be replaced.
Mar 29, 2013 | ASUS K50IJ-C1 Notebook
Can I replace my non backlit keyboard with a backlit one?
If it is for your exact model than that keyboard should work. The backlight function is built into the keyboard itself not the laptop. I hope that helps
Jun 12, 2012 | ASUS K50IJ-C1 Notebook
I have a problem with my webcam on my Asus K53U, on daylight there's no problem, but when it's dark there is no image, only if I turn on the light in the room, I have uninstalled and installed the...
These webcam's have low quality optics and sensors which require quite a bit of light to operate. You will need a light on or it will show dark. If you want a low light webcam you will have to purchase a USB one in the $100 range.
Chris
Aug 14, 2011 | ASUS K50IJ-C1 Notebook
How do I remove the keyboard from Asus K50IJ ?
Try these steps:
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the Asus keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus K50IJ Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus K50IJ Keyboard component toward your laptop screen. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
Jun 25, 2011 | ASUS K50IJ-C1 Notebook
Internal microphone not working (don't even know if the k50ij model has one)
Yes this notebook has an internal mic, maybe it's only muted in Windows mixer, please also check if it's not set to very low volume.
Feb 22, 2011 | ASUS K50IJ Notebook
I can find driver for my asus laptop web cam
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 06, 2010 | ASUS K50IJ-C1 Notebook
My backspace and shirt buttons have stopped working
i need to laptop modell 501j for Asus Laptop. I Waiting for Masseges. My Email : jamilm79@yahoo.com. Thanks for you.
Dec 02, 2010 | ASUS K50IJ-C1 Notebook
HOW DO YOU ACCESS THE WEBCAM ON THE ASUS K50IJ? I've looked and looked, but just can't find it
try to check this site.. download the file for your camera software support.
Feb 05, 2010 | ASUS K50IJ-C1 Notebook
Asus k50ij webcam image upsidedown
I have the same problem with my laptop Asus K50IJ, and apparently we're not the only ones. It seems that the only solution is manycam.com, as lifeframe utility or driver installations don't solve anything. Hope it helped!
Jan 30, 2010 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
