My laptop compaq nx7010 screen is flickering. Sometimes when i press it hard near the power button, it shows up.. what is the problem?
  • 32,281 Answers
There could be a loose video connection. Try reseating the LCD screen video connector on the motherboard.
Posted on May 22, 2011
Hi,i have a nx7010 that powers up but no actvity on screen,,swopped mem. modules,,nothing,but when i swop the chip it powers up normaly everythings okay,but when i shutdown the problem returns,swop the...
hi
old PC
when did it last run perfectly last week last year, never, I found it in dumpster. or garage sale for $1
swap, (exchanged)
the screen never ever shows text. right? = equals no activity>?
this old PC is CCFL pC, back lighted.
and as such those fail easy, (20,000 hr rated max)
we use LED now, and never fail.
the tests are here
laptop, PC, NX old series. from long ago.
all are problematic this old,
But screen dead is #1 for sure. 100% dead.
btw that lamp can turn on then off, the flicker go dim or just be pure intermittant folly;, a PITA they are and the inverter same.
see the simple tests here.
http://www.pcdied.com/monitors.html#Laptop
Aug 05, 2017 | HP Compaq nx7010 Notebook
Power on button problem,,,first i pressed it really hard so it turned on ,,now it dznt work at all
might wanna check if the powerbutton actually presses the point it needs to to turn the pc on.
Mar 03, 2011 | HP Compaq nx7010 Notebook
COMPAQ NX7010 WONT START .PLUGED IN POWER PRESSED ON SWITCH POWER LIHHT FLASFES 3 THEN NOTHING
Check on the ram, power adapter cable, battery and if that is not the case try to see if you can repair windows xp. Otherwise it could be that the motherboard is damage
May 17, 2010 | HP Compaq Business nx7010 Notebook
My hp nx7010 laptop screen glows very dim from today morning... this was not yesterday... what should I do? What is the problem?
press and hold "fn" button beside the control button, then press "right or "up button.. depends on what is the sign on the button.. it should be like the sun.. and the other one is speaker sign.. - (this is the shortcut)
Feb 16, 2010 | HP Compaq nx7010 Notebook
Nx7010 does not start.
Hello dear, probably some BIOS values changed, causing u no displays. Try this key combination immediately after startup
esc - loads bios, but not in display
F9 - (hope its F9 in ur laptop) resets BIOS
F10 - saves BIOS to default values and exits
RESTART
Or else try removing CMOS battery, its right beneath the keyboard. (Just remove 1 screw) Remove and hold for 1 minute and then reinsert and turn up laptop on. Your PC should be fine.
Jul 04, 2009 | HP Compaq nx7010 Notebook
Have compaq nx7010 can power up but screen blank and hard disc light (between power and mains power symbols) not staying on. have tried removing battery and refitting which has worked once before but now...
The HDD light is not meant to be on solid, it comes on only when the hard drive is actually working. The situation you're describing is usually just a lockup in standby.
Although you're onthe right track with the battery, To reset the power, unplug the AC cord, remove the battery and then hold the power button for 30 seconds. Now put the battery back plug it in and turn it on. It may give you an error about not being able to resume, this is normal.
If this doesn't work get back to us with more info: does it beep when it turns on, how many times, longs/shorts.
Did you try plugging and external monitor into the laptop and rotating displays to see if your backlight is out?
Ok, giver a try and let us know.
Chris
May 24, 2009 | HP Compaq nx7010 Notebook
I have a hp compaq nx7010 that powers but cant display. the screen if fine ,i have tested it on anoth machine and it is showing what can be the problem?
Try the holding the fn button and pressing the display button to change the output display from external to the initial display. If this doesn't work then attach an external display, if it works then try switching back from the external to the LCD. If that doesnt work then Hold the fn button and set the brightness of the LCD to its fullest by pressing the correct key on the keyboard.
hope this helps
Apr 23, 2009 | HP Compaq nx7010 Notebook
HP compaq nx 7010
Sorry to dissappoint You mate, but NX7010 has no built-in microphone... VERY illogical design, for its time, but it's the sad truth. Buy an external one, plug it in and You shall see, that the sliders and tickers are suddenly working.
Feb 22, 2009 | HP Compaq nx7010 Notebook
Laptop not turning on
you would atleast be able to access the bios if it was just the hard drive issue.
If you are running just off the battery try running with your power supply on it and see if that does anything else
if not you may have a short in the power supply some where.
Aug 07, 2008 | HP Compaq nx7010 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
