Question about Garmin FISHFINDER 300C NIC ()
I recently charged my battery and since hooking it back up to my fishfinder it constantly says supply voltage too high transducer turning off. ive tested the battery and its perfectly fine.
    Problem Solver:
  • 12 Answers
Maximum voltage for that unit is 33V. Test the voltage with a multimeter at the fuse block or as close to the unit as you can. If you are reading less than 33 volts than your voltage input is fine and you need to contact garmin for a repair or replacement if your unit is still under warranty.
Also check your connections at the battery; make sure everything is clean and that you do not have any + and - wires switched.
Posted on May 23, 2011
Northstar Explorer 657 GPS/ Fishfinder Screen went black
It appears that the back-light, a Cold Cathode Fluorescent Tube about 3mm diameter, is not working.
There are two likely causes.
1. Tube has failed.
2. High Voltage supply circuit has failed.
I'm currently pulling my unit apart to determine the cause. I suspect the tube is the problem but I will post more when I have it apart
Does anyone know what the correct operating voltage of this Cold Cathode Fluorescent Tube is? Northstar could not provide me with a service manual.
The screws are 1/16" or similar Allan Screws (about 1.6mm internal between flats). They usually can be undone with a 1/16 Allan Key but some of the screws can't be unscrewed with this key.
I'm having difficulties uploading the photos at the moment but I will try and fix that.
Jul 31, 2011 | Northstar Explorer 657...
My Garmin 400c dual beam transducer keeps freezing up, it will flash "0" depth and then go to a "updating software" screen.
check your battery voltage. Low voltage can cause errors end prevent the sonar from starting up. If charging the battery doesn't work then contact garmin for a replacement.
Nov 30, 2010 | Garmin Fishfinder 400c With Dual Beam...
Display reads sonar timed out
check the battery voltage as low voltage can cause the unit to display errors and prevent the sonar from starting up. This unit is more sensitive to low voltage than many other electronics. If charging the battery or replacing it with a known good battery doesn't work then contact garmin for a replacement of your fishfinder.
Nov 18, 2010 | Garmin Fishfinder 400c With Dual Beam...
How do i get just the gps to work, due to the transducer not being hooked up?
hey i need help trying to find out what my sim password is to mr samsung eternity any ideas
Mar 19, 2010 | Humminbird Fishfinder 565 With Transom...
Humminbird fishfinder 565
according to the manual... 10-20 VDC
Please rate this solution.. thanks
Feb 04, 2009 | Humminbird Fishfinder 565 With Transom...
The unit does not turn on.
Hello vfedele5, The plug on the unit itself maybe the culprit. Check the voltage during power up, a resistance in the power line may be present. If the unit passes these test you have an internal connection error, bad internal connection, solder connection, ect. Merry Christmas.
Dec 07, 2008 | Raymarine Ds500x Color Fishfinder: Ds500x...
Charging the battery over the winter
Hi there. Float charging the battery is a great idea over winter. You should always remove a battery from your bike or vehicle before charging. They produce hydrogen gas (EXPLOSIVE!!) and can easily ignite if a spark is generated (from the battery charge connection) . I have seen this happen before!! I would be using a constant voltage type regulated float charger to keep it topped up. Unless you can set up the constant current type you mention for a few milliamps of charge only. If you charge it at too high a rate, with constant current, it will overcharge the battery and boil it dry. Float charge voltage of 13.5-13.8 is good for any lead acid battery. Check it every few weeks initially to be sure that it is not loosing electrolyte. Thanks for using FixYa.
regards
robotek
Dec 06, 2008 | 2007 Yamaha V Star Custom
False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
Feb 25, 2008 | GPS
Garmin FISHFINDER 300C NIC () Logo
255 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
