Question about Toshiba Satellite A105-S4334 Notebook
Toshiba satellite Model PSAA8U-14M02K... Do not have any power have tried different chargers and batteries but no lights and nothing happens when i push the power button.
  • Toshiba Master
  • 32,281 Answers
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on May 22, 2011
My toshiba satellite L25-S1194 wont turn on. no lights, nothing. how could i fix this?
Try taking the battery out, plug the computer in, and see if it turns on. Press the "Power" button for at least 20 seconds (and press hard). If that doesn't work, put the battery back in, and do the same thing. I assume no lights appear like its charging (as you said). If this is the case, then you might have a dead charger (wire broke inside, power surge broke the adapter, etc). You may want to try a different charger of the same model (either from your local Best Buy or from a friend). If it does look like its charging, then your laptop's power supply has died (or the motherboard has died). This is a much bigger hardware problem and should be under warranty (or time to buy a new laptop). All data should be recoverable, however.
Jun 19, 2013 | Toshiba Satellite Computers & Internet
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
Problem: A100 flashing Amber light but won't turn
Check your charger. It seems to indicate low batery and the charger may not work or the power socket has a faulty connection. Check for phisical damage in the power socket of you laptop.
Try to twist it or even push it in a bit while trying to switch on. Try also to remove the baterry and use the charger power supply only.
If nothing happens its very likely to be the charger.
Jul 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
Battery
Try resetting the BIOS in case something happened to it.
Power down your computer. Remove the power cord, the rechargeable battery and the BIOS battery. Wait 10 minutes. Reinstall the BIOS battery, the rechargeable battery and the powewr cord. Restart your computer and enter the BIOS setup.
If nothing happens, your video card may have failed.
Mar 20, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A135-S2276 just suddenly stopped
first to do is check your charger... remove the battery then connect the charger.. if still not working.. you need to open the system check the dc connector if its okay.. now time to check the motherboard. maybe some chips bluwn or burn... shortage... this is always happens epecially those over heating the cpu fan is slow not enougth to give out the coold..
Sep 09, 2009 | Toshiba Satellite A135-S2276 Notebook
My Toshiba Satellite won't turn on at all
If no lights/nothing happens when you press the power button then you probably have a corroded power socket on your motherboard, the positive terminal will not be connecting properly to the motherboard. The laptop needs to be dismantled and have the socket resoldered properly. This can cost quite a bit at most places. I would check the charger first to make sure it is not the problem.
Jun 16, 2009 | Toshiba Satellite L25-S119 Notebook
Toshiba satilite P100...wont turn of
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
Apr 12, 2009 | Toshiba Satellite P100 Notebook
Laptop doesn't start
Try removing the battery and reinsertit.
Or perhaps the on/off button is damaged .... (any shocks recently ?! ) Or there could be a more serious hardware issue...go on toshiba site maybe u'll find some info there ....
Jan 16, 2008 | Toshiba Satellite A45-S151 Notebook
Toshiba Satellite A105-S4334 Notebook Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
