Question about Salter Stainless Steel Electronic Bathroom Scale
Salter digital bathroom scales displays 0-ld when i stand on it?
5 Suggested Answers
SOURCE: The display on my salter bathroom scales is
I held the two arrow and set buttons together for a few seconds and it cleared
Posted on Oct 20, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
  • 10865 Answers
SOURCE: Salter 9001 bathroom scale stopped working
Hi Pete. I don't keep receipts either : ^ )
No that I am done commeserating, try this. Remove the batteries. Use the eraser end of a common pencil to scrub and clean the battery contacts inside the battery compartment. Also pull the contacts a little closer to the surface if you can. Then reinstall the batteries and you may be up and running.
Please rate my answer as verey helpful thanks. Joe
Posted on Mar 26, 2010
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Posted on Aug 29, 2010
Calibrate Salter model 9140 bathroom scales
Remove the battery and count to 10 and then replace it.
i found this
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
and also this
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery until you first complete the steps listed above.
Not sure if this is the correct manual, but may be close. Page 3 and 4.
Salter Housewares Body Fat Computer Instruction Manual Page 3
Nov 27, 2017 | Salter Health & Beauty
After changing battery, why does err appear and not a 0?
The replacement battery could be defective or installed incorrectly.
Sep 05, 2015 | Salter 9037 - Digital Bathroom Scales /...
Aug 25, 2009 | Health & Beauty
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Salter Stainless Steel Electronic Bathroom Scale Logo
2,785 people viewed this question
Top Salter Health & Beauty Experts
vince
Andrew Taylor
Andrew Taylor
richie46
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
