WHICH IS UNLEADED FUEL 91 OR 95; PLS REPLY THANKS
2 Suggested Answers
  • 105 Answers
SOURCE: I have a honda goldwing
Unleaded fuel because it has hardend seats MOPAR KENNY
Posted on May 22, 2011
Could you please let me know. 1] Can I use E10 fuel in my new RLT 30 CET 30cc trimmer that I have just purchased and am yet to start up? 2] Is 50 to 1 50mm of oil to one litre of petrol?
Hi and welcome to FixYa, I am Kelly
First off the engine is designed to operate on unleaded fuel. The manufacturer makes no statements at all about E-10 Fuel. I will tell you from experience that you can use E-10 Fuel but.... should you ever have a warranty claim make sure the entire fuel system is 100% unleaded pre-mixed fuel. Your not going to hurt the unit using E-10 fuel as long as you maintain the proper fuel-oil mixtures. If anything a splash more of 2 stroke oil as in 22 mm / liter vs 20 mm. Or (+) 8 mm per gal.
Manufacturers statemenrts and recommended fuel mixtures below:
Thanks for choosing FixYa,
Kelly
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Feb 27, 2011 | Ryobi 15" Electric Factory Reconditioned...
What type of fuel is to be used? oil/gas mixed? pls advise
Check to see whether 4 stroke is written on engine. If this is the case, regular gas can be used.
Feb 19, 2011 | Karcher 2500 PSI Pressure Washer
Can 94 jetta run on leaded or unleaded petrol
It is best to run this engine on unleaded petrol. A high grade unleaded will give you extra performance and cause no damage. Leaded fuel was designed for cars made in the 60's to 80's that had used softer materials in their cylinder heads, leaded fuel pro-longed cylinder head life and reduced pre-ignition. Unleaded fuels are a cleaner, safer fuel to use.
Jan 24, 2011 | 1994 Volkswagen Jetta
What petrol should i use in my 1989 citi sport golf? Lead replacement or unleaded fuel? Thanks
Unleaded is recommended for this car but it is compatible with LRP since it has no catalytic converter.
I am asuming you are in South Africa? Have a look at the NAAMSA fuel compatibility database.
Nov 16, 2010 | 1989 Volkswagen Golf
I just bought it and need to no which gas is best for it out of the three types. and if i put regular gas in, will that break it!
when you open the gas flap to put gas in it should say "unleaded fuel only" or " premium unleaded fuel only". If it says premium only use premium. If it just says unleaded then you can use normal unleaded gas. But some stations have a lower grade unleaded gas. Use 88 octane or better.
Jun 14, 2009 | 1994 BMW 3 Series
About super unleaded and unleaded fuel
Hi,some manufacturers recomend either super or regular unleded ,the diference is the octane rating ,this will not afect your motor but you allways should stay with the factory recomendations......
Aug 17, 2008 | 1996 Mercury Mystique
Unleaded fuel
Am afraid nothing much you can do since you have to make do with what is locally available. However, a couple of things you can keep in mind:
1. Using leaded fuel with a car intended to use unleaded fuel would destroy your car's catalytic converter faster than normal wear and tear;
2. At times unleaded would be available, pls use as much as possible to help clean/remove the lead additive, tetraethyllead that will cover some soft engine parts with the lead-containing material;
3. you may have to tune your engine's timing to compensate for the leaded fuel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 15, 2008 | 2007 Kia Sorento 4x4
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
