Question about Verbatim Drive USB 2.0 4GB Store'n'Go Certified for Windows ReadyBoost and VistaCertified for Wind... Hard Drive
HOW TO REMOVE PROTECTION FROM A USB FLASH DRIVE IN ORDER TO FORMAT IT
  • Verbatim Master
  • 27,725 Answers
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on May 22, 2011
  • Brian Sullivan
    Brian Sullivan May 22, 2011
    click start click on my computer you should see your pen drive
    right click then select format
    another way is to control panel administrive tools computer management disk management right click on your drive select format
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
How to fix a write protect usb flash drive
Both these links have some good advice
http://www.tomshardware.com/forum/265507-32-format-write-protected-drive
http://www.techrepublic.com/forum/questions/101-207273/usb-flash-drive-is-write-protected-how-do-i-remove-it
Apr 16, 2013 | Electronics - Others
How to format write protected SanDisk Blade Micro 16GB USB 2.0 Flash Drive?
i have SanDisk 16 GB Flash it's write protected kindly advice how to remove the write protected from my USB flash.
your kind advice will highly appreciate
Oct 28, 2012 | SanDisk Cruzer Electronics - Others
I am trying to format the 64 kingston DataTraveller usb but i cant because it is write protected
You will have to remove the write protection in order to be able to format the flash drive.To do so,
please follow the detailed instructions from the below page.
http://en.kioskea.net/faq/4214-remove-write-protection-on-pen-drive
Nov 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to reformat a write protected usb?
No need to reformat your write protected USB. The hings you should do is to slide to small button you can see in your USB to remove the write protected.
Mar 29, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I cannot remove write protection of my transcend 4GB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
USB flash drive write protection
Most USB drives don't have a Write Protection switch, but if yours does, then move the slider.
If it doesn't have a switch, the only way to use the drive is to format the drive. First, note the drive letter, such as E, F G for your drive. *** BE CAREFUL *** This will remove all files. Go to Windows Explorer, note the drive letter , Right-click and select Format. Again, BE CAREFUL not to format any other drive, just your removable USB drive.
Hope this helps.
Aug 10, 2009 | Electronics - Others
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
8GB TRANSCEND PEN DRIVE - WRITE PROTECTION DELAYED - REMOVE WRITE PROTECTION
Use following link to download recover jetflash from transcend site.
http://www.transcend.nl/support/dlcenter...
note that the data on the pen drive will be erased. so back it up before you run it.
  • 1 week ago
Sep 16, 2008 | Electronics - Others
Verbatim Drive USB 2.0 4GB Store'n'Go Certified for Windows ReadyBoost and VistaCertified for Wind... Hard Drive Logo
290 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
