Question about Samsung AS18A6RB Air Conditioner
My wall-unit air conditioner will run fine and then shut off. When it does this the nature indicator light on the unit begins flashing (the blinking baby as I refer to it). If I attempt to turn it back on the fan revs up and then shuts off 15seconds later. I'm not sure what it's trying to convey with the blinking light but when the AC shuts off in the middle of the night causing my room to get over 80, it's a problem.
2 Suggested Answers
SOURCE: Blinking Nature Indicator Light
air conditioner will run fine and then shut off. When it does this the nature indicator light on the unit begins flashing If I attempt to turn it back on the fan revs up and then shuts off 15seconds later. I'm not sure what it's trying to convey with theblinking light but when the AC shuts off...
Posted on Oct 16, 2010
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
Klimaire KSWG012H113 Split System Air Conditioner
Check web site for significance of the four flashes. Could be that it is overheating and shutting down due to excessive current consumption.
Jul 24, 2016 | SNK Klimaire KSWG012H113 Split System Air...
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Enigma SLR61-GW. System runs for about 30 mins and then shuts down and a status light blinks 4 times.
Open the front end of the blower.
You will find tow filters that slide out.
Clean them with water and replays them.
Go to the outside one, take a hosepipe and run a strong stream of water thru the radiator until its clean.
This will solve your problem.
Good luck.
Oct 23, 2015 | Heating & Cooling
The green operation light keeps blinking. I've reset unit and it still blinks
Could u explain more about this error,how many led light,flashing ??? Brand???model???
May 08, 2015 | Fujitsu HALCYON ASU24CL1 Wall Mounted Mini...
E4 Error Code
Could be overheating and a sensor is triggering the machine to turn off or it could be short of gas. Check all pipework connections for tightness and especially look for oily residue on any of them. This would indicate a leak. Unfortunately, if there is a leak, you would require a licensed air con Tech to repair the leak and regas it.
Apr 09, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Jun 14, 2010 | Samsung AS18A6RB Air Conditioner
Blower keeps running even after thermostat is in off or in auto? The forced air unit stays on even after temp setting is reached or will switch thermostat switch to off. The heat stops but blower stays...
This could be an indication that there is an error code flashing on the control board and needs to be addressed. Most newer units like this indicate a problem by running the room air blower to alert the homeowner something is wrong. Really! Without shutting off the power to the unit, look for a small viewing port that looks into the cabinet. You should see a blinking light that will blink a number of times, pause then blink another number of times. Once you get this number, say 3-4, look at the wiring diagram pasted on one of the door panels for a diagnostic chart. It will give you a starting point where to look for the problem. If you have one. Or you could have a bad control board or shorted wire. Make sure the air filter is clean since you will be in front of the unit, you would not believe how many times I have to charge $100 to replace a filter the home owner could have done for less than $20.
Mar 11, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Jun 09, 2008 | Frigidaire FAA065M7A Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
60 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
