Question about Panasonic Televison & Video
I have a panasonic tu-hdt104a and finding it hard to set up properly to be able to scan and pick up channels what am I doing wrong? Can someone give me step by step guide to setting it up thank you.
Bluehound
  • 25 Answers
SOURCE: Philips DVD622 Factory reset
Go to http://www.philips.com and search for your modal then look in Q/A's or just look in the manual for the factory reset....Usually found in the on-screen menu!
Posted on Jan 11, 2008
Benimur
  • 6966 Answers
SOURCE: reset tv to factory setup
Most current TV units can be reset to default factory settings by being unplug from the mains fro at least a couple of hours (or overnight).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
SOURCE: audio driver for compaq presario c772 tu
I have problem with my sound drive I had tried sp33443/sp35682 after installation off UAA (sp32646)but the system shows "could not find media device for this driver" please help
Posted on Dec 06, 2008
  • 40 Answers
SOURCE: KM-1820 scanner setup
The KM-1820 to scan to PC is using SMB, FTP or e-mail.
for SMB:
I am assuming you have the KM-1820 connected within the network and a static IP address for it.
open any Internet browser and go to KM-1820's IP address.
You should see the Command Centre web page.
Go to Basic page and add/register a contact within the Address Book.
Give a name and at the SMB section field, fill up with your computer hostname or the ip address of your computer where you want to scan. Fill up the user name with the local user name - the one what you are using to get into your computer - or create a new LOCAL user for your PC lets say "kyocera". So for SMB will be your computer and username: kyocera. (You will need a password for that computer user (kyocera) ). Then create a folder "scan" where you want ot receive the scanned files and add "scan" at the path field (SMB section of that webpage - command center).
Now share the folder "scan" as "scan".
if you want you can always use the scan to e-mail !! but you need a smtp server. All the settings can be done using that command center webpage.
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: Cannot set channels
It is the software or the program that have the TV to operate properly.  Sorry for my english.
Posted on Jan 27, 2009
My 47"doesn't pick up any channels while connected to the house antenna. The scan picks up nothing even after doing a factory reset. Please any suggestions
Sadly without being able to put hands on. this type of problem can not be FIXED this could be as minor as not having the input set properly or the antenna is not pointed in the right direction ,or the cable is defective,or the antenna needs a booster added to it , and the list goes on .getting someone to service antennas is getting harder in all areas of the world
Sep 30, 2017 | Televison & Video
Auto scan not working??
Make, model, and year please.
Jan 22, 2016 | Televison & Video
How can I get my Toshiba Sd H400 to find satellite signal?
You have to use some of the special connections on the back to connect the Satellite box. It will not work with those you are trying. See the manual below:
Toshiba SD H400 TU Installation Manual Using Your Sd h400 With Cable Or...
Oct 05, 2017 | Toshiba Sd-h400 Combination...
Cant get my digital antenna to pick up any channels
In your area, it may be necessary to use an antenna with an amplifier.
Jun 29, 2017 | Televison & Video
Why is the tv not finding channels when channels are scanned?
make sure your tv is set to pick up the signal it could be cable digital or analog channells.there should be an option for this in the menu.
Jun 04, 2012 | Scott LCT37SHA TV
How do i unlock my two way so i can scan and pick channels
The scan function on an XTN is not to be a scanner, but to scan between channels you have programmed into the radio. The scan feature is only available on the 2600 series. You can manually go to each channel and look for or listen for channel activity. Start with channel 1, when someone else is talking, there is a "busy" indication on the LCD on the radio. You can listen in by pressing the Monitor button. If you are using the factory defaults, you may hear someone without pressing the Monitor button.
Jan 21, 2011 | Motorola XTN UHF Two-Way Radio Series
I have re-tuned my TU-CT20 Panasonic set top box several times, successfully in that I have a new list of stations, but every time BBC1 and BBC2 are omitted. It starts with ITV1 at channel 1.
If you have all the cahnnels updated then you will have to manually edit the station list and change the order of the channels. refer to your manual for instructions.
Oct 01, 2009 | Panasonic Televison & Video
Cant figure out how to set TV to cable setting
The company's page for this set is here. There's a link toward the bottom to download the user's manual.
If I read the manual correctly, you're out of luck without an external tuner such as a cable box. This set was made for the European market and its tuning system isn't fully compatible with that used in the US. There's a "channel swap" function which lets you reassign the channels it finds to whatever channel number you want, and it's described in the manual. I assume that's to allow for the different frequency/channel number assignments in use in all the areas it tries to cover. The set's tuner just may not be able to pick up all the channels on your cable system. As long as it gets US channel 3 or 4 correctly, you can use the set with a cable box or video recorder that properly tunes the cable channels.
Apr 23, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
I have a radio shack pro 96 digital trucking scanner.the other day we finally put up my outside antenna for it.it worked fine all through xmas and new years.the other day turned it on and it would not pick...
The very part of your scanner that makes it a scanner is inop. YOU can find it but IT won't scan. Back to radio shack for warranty before they change their mind.
Jan 09, 2009 | Computers & Internet
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
