Question about Strida Areaware STRiDA 50 BType Special Edition Folding Bicycle
The large cog on my Strida bike is wobbly, I have tried to tighten it but the problem seems to be within the crank.
    Brigadier General:
  • 8,546 Answers
Why does new bicycle 24" manual speed have wobbly handlebars?
you have to tighten the screws, when it is assembled it is done using the hands and no tools are used to tighten anything, do not ride it until you fix it or someone is going to get hurt
Aug 29, 2014 | Next Kent La Jolla 24" Girls Cruiser Bike
Brand new bike gears won't engage. The gear shift is on 6 and the chain is on the smallest cranks.
the derailleur cable is too loose. Shift the shifter into the smallest cog, make sure the chain is on the smallest cog. The derailleur cable will most likely be very slack now. At the rear derailleur, there will be a nut or a allen bolt pinching the cable to the derailleur. loosen this, pull the cable finger tight, tighten the nut or bolt again and then try shifting again. You can dial it in using the barrel adjuster on the derailleur or the shifter.
Oct 15, 2011 | Pacific International Pacific Evolution...
My strida bike brake stops working. It doesn't
Something may be impeding the free movement of the cable. ONLY the spring in the brake and the lever will make it return to the relaxed state. Think: kinks.
Search engine: "how to ..." for most things.
http://www.strida.us/files/strida3.pdf
Jul 31, 2011 | Cycling
Cannot get rear derailer to work properly 24 inch girls evolution
Don't start messing with the derailleur yet! Make sure your shifting trouble isn't due to something else, such as a warped, dirty, or stretched chain, gummed-up pulleys, crud in the cable housing, trapped cable, or a bent derailleur hanger
Clean the chain and the rear derailleur pulleys. Pull the chain away from each pulley, and turn the pulley to make sure it can move freely. A pulley that offers resistance to turning must be replaced.
Now check the cable to be sure it slides freely. Mud and grit within the cable housing, or on a cable-guide, can keep the derailleur from moving a "full gear" during downshifts. If the cable doesn't slide freely in the housing, you may be able to clean or lube it to restore smooth shifting.
Let the high-gear limit screw. In your highest gear on the shifter, and with the chain on the smallest cog, position the derailleur so the upper pulley exactly matches the teeth of the small cog. Run the chain a bit with the front derailleur in the large ring, adjusting the limit screw until the pulley and the cog seem to match perfectly.
Setting the high-gear (small cog) limiting screw.
Once you're sure the derailleur matches the cog, move it just a whisker (1/8 to 1/4 turn) towards the other cogs. (You may need to readjust a bit if you get chain-skip.)
Closeup of setting the limiting screw.
Now adjust the low-gear limit screw. Shift into the lowest gear (largest cog). If it won't go, loosen the limit screw. With the chain on the largest cog (and the front derailleur in the small chainring), adjust the derailleur so the upper pulley exactly matches the teeth of the large cog.Once it's perfect, turn the limit screw so it moves the derailleur a tiny amount towards the other cogs (1/8 to 1/4 turn usually works).
Setting the low-gear (largest cog) limiting screw.
Now shift to the highest gear (smallest cog). Push the shift lever to downshift one gear (go from the smallest cog to the next-smallest). If it doesn't shift, tighten the cable with the barrel adjuster, 1/2 turn counter-clockwise. Backshift and try again. Continue tightening until it shifts. If it overshifts, going from the smallest cog to the third-smallest, loosen the cable by turning 1/2 turn clockwise. Backshift and repeat until it shifts exactly from the small to the next-smallest cog.
Fine adjustment of tension in the derailleur cable.
Now go to the second-smallest ring. Tighten or loosen the cable slightly, until the outer side plates of the chain are just clearing the third-smallest cog. Shift up and down, fine-tuning until you're satisfied.
Checking the position of the chain on the cogs.
Mar 04, 2011 | Pacific International Pacific Evolution 24...
Hiya neucleus vibe cycle, the front cog where the pedals are has come very loose i can see the barrins inside the cog i just want to know how to fix it ?
I would strongly encourage you to take this into your local bike shop. The bottom bracket (which is the part that has now loosened) should not come apart.
But... On the opposite side of the gear there should be a large disc and a big nut. Start by turning the large disc so that it is screwing back into the frame and tightening up your cranks. Get it too just tight, but the cranks still spin. Next tighten the big nut, this holds everything together.
The reason I recommend taking this into your shop is that it takes some aquired skill to be able to adjust the bearings so that they spin smooth and will not loosen again. Plus they can check the threading to make sure nothing has stripped and will most likely put a little loctite on the threads to keep the big nut from backing off. Also if you have loose ball bearings they can make sure there is the correct number, if you have cages then they can replace those. You do not want your cranks coming apart while your riding, this is a good way to get hurt.
Dec 19, 2010 | Cycling
Not leting me shift into 3rd gear
Front or rear?
Rear: Flip the bike onto the bars and saddle, then shift into third while turning the crank. Use the barrel adjuster on the back of the derailleur to align the derailleur over the proper cog. If this doesn't work, you may have a bent cog or a bent derailleur hanger. Does it only happen in third? Inspect your third cog for any deviation.
Front: Shift into the small chainring and release the derailleur cable. Pull tight and re-attach. Shift into the big chainring now. If it still won't go, use the barrel adjuster on the shifter co tighten the cable until it does shift. If necessary (because the derailleur will not go to the big chainring on account of a mechanical impedance) adjust the "H" screw to allow the derailleur to move far enough out to shift on to the big ring.
If all else fails, check with the bike shop.
Hope this helps,
matt
Sep 19, 2009 | Pit Cycling
I'm trying to adjust the shimano gearing on my trek bike and am having a little trouble
Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 02, 2009 | Cycling
Slipping while cranking
The rachets in the rear gear cog have gone bad.  Buy a new gear cluster and have it installed on your rear wheel.  about $30
Mar 26, 2009 | Mountain Bike Bmx Fit Gt Haro Chrome...
Strida Areaware STRiDA 50 BType Special Edition Folding Bicycle Logo
115 people viewed this question
Top Strida Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Strida Cycling Expert? Answer questions, earn points and help others
