Question about De Dietrich DOC310 Electric Single Oven
Resetting oven after power failure - De Dietrich DOC310 Electric Single Oven
Power Failure while oven was in self cleaning mode. When power was restored the control panel is completely dark, no error codes or PF indicator. The oven door is also locked after 24 hours, so the the...
Hello. You have an open rear oven thermostat causing the complete power failure of your unit. The part numbers you need are W10176670 for the upgraded blower and 9759243 for the thermostat. You will have to remove the oven from the wall in order to remove the back covers to access the thermostat and blower. The blower has been upgraded from 950cfm of airflow to 1200cfm. I have performed this service flash--you will definitely need a helper or 2 in order to pull the oven out and work on it. There is a service bulletin on your oven describing this exact situation. When you replace the thermostat and blower, re-mount the oven and then restore power, the oven will function and unlock. The link for the thermostat is here:
Thermal Overload Safety Thermostat
The link for the blower is here:
http://www.appliancepartspros.com/whirlpool-blower-w10176670-ap4369539.html
If you are hesitant about performing the repair yourself, definitely call for service. I hope this helps you!
Nov 06, 2015 | Whirlpool RBS305PRS Stainless Steel Oven
Fisher &Paykal oven is off
try resetting the clock .
Aug 28, 2015 | Fisher Ovens
We have had a power failure and the oven will not work unless the clock is reset but the manual instructions do not help as the knob does not change the time.
Every one of these things has a different method for changing the time/resetting the clock. You'll have to provide a make and model number.
May 29, 2015 | Ovens
Electrolux oven wont stop beeping
Hi Friend, I am happy to assist you!
I understand your Electrolux oven is continuously beeping. Without knowing your specific model number, let's try resetting your oven. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your oven. If resetting the power does not correct the issue, then your range could possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure. Hope this helps! - Z
Jul 13, 2014 | Electrolux Ovens
Frigidaire electric oven digital display not coming on
Good Afternoon Friend, I am happy to assist you!
Based on the symptoms you are describing it sounds like your range could possibly be experiencing a communication problem with the EOC (Electronic Oven Control) or a potential wiring failure. Let's try resetting your range by either flipping the household circuit breaker to the off position or by unplugging it. It is best to wait approximately ten minutes and then turn on your range. If resetting the power to the range does not correct the issue, at this moment I would personally contact a professional to accurately diagnose your range to determine the root cause to reduce the risk of unnecessary parts.
Best regards! - Z
Jul 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
FPET305KF8
Hello Bree, thank you for allowing me to assist you!
Let's try resetting your wall oven by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your appliance on. Now set the time and try turning on the oven. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, a communication error with the EOC (electronic oven control), faulty door latch assembly or element(s). Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Dec 16, 2013 | Frigidaire 27 in. Electric Gallery Pro...
The oven won't heat to bake. It looks like it should work. It was able to self clean a few days ago but will not bake now. Help
Good Morning John, thank you for allowing me to assist you!
Let's try resetting your wall oven by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn unit on. Now set the time and turn on your oven. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, a communication error with the EOC (electronic oven control), or faulty power supply. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Best regards!
Oct 23, 2013 | Frigidaire FEB30S6FC Stainless Steel...
Frigidaire single electric oven will not power up and the screen shows an upside down and a period....or an eight with top cut off. This happened after I cleaned the oven.
Hello Veretta, thank you for your inquiry! Let's try resetting the wall oven by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn unit back on. Now set the time and try turning on the oven. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, a communication error with the EOC (electronic oven control), or faulty door latch assembly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Aug 15, 2013 | Frigidaire Ovens
What does pf on digital display mean? Oven will not work
PF means power failure.
This has caused a power outage to the oven.
This error can be removed by resetting the clock.
Hope this helps.
Thanks for using Fixya.
Dec 07, 2009 | Whirlpool Ovens
De Dietrich DOC310 Electric Single Oven Logo
48 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
