Question about Altec Lansing ACS 251 Computer Speakers
My subwoofer is making a strange kind of noise n frequently it goes off by itself..this happened since the left front speaker started making some crakling noise every time n later the situation aggravated and nw its almost impossible for me to listen to a song or doing something as my subwoofer does a very loud noise n its jst too damn annoying!!!!
    Novelist:
  • 123 Answers
Hi
Good day. In regards to your issue your speaker connector might be grounded and there's no way to fix that i''m sorry. But try to do this step first to be sure
1.Make sure your speakers are plugged in, turned on, and properly connected to the
computer
. You've probably checked this, but it's amazing how little problems like this (or the
computer's sound being muted) manage to confound people.
2. Plug the speakers in to another computer, if possible. If the speakers work with the other
computer, proceed to the next step. If they don't, you've probably got a problem within the
speakers themselves.
3. Check sound card driver
> Open your start menu (right-click on the "Start" button and choose "Explore"), and find the "My
Computer" icon. Right-click on it and choose "Properties" from the submenu. Click on the
"Hardware" tab and then the "Device Manager" button.
> Expand the "Sounds, video, and game controllers" heading to find your sound card. The name
will depend on what sound card is installed on your PC. It will most likely have a name
containing "audio." It should look something similar to the example above. You'll know
immediately if there is a major driver error because an exclamation point (!) will show over the
card's icon.
> Double-click on the name of the sound card to open a new window. In the new properties window
click on the "Drivers" tab. If there is no "Drivers" tab then you chose the wrong sound device. Go
back and try again. On the "Drivers" tab, click the "Driver Update" button. Follow the Wizard's
onscreen instructions to update your driver. You can also contact the manufacturer of your PC
for the most recent audio drivers. They can usually be found online.
> If you already have the most recent driver, click the "Uninstall Driver" button. Then restart your
computer. When you restart your computer, the driver should reinstall automatically. If it does
not, install it manually with software (or a download) from the manufacturer.
4. Check the "Windows Troubleshooter". On the "Drivers" tab mentioned in the step above,
there is a button for troubleshooting the device. Click on that button, and follow the instructions
on screen.
5. Check the sound card itself. Properly shut down your PC and then disconnect all cables on
the back of your PC, including the power cable. Open up the CPU, making sure to touch a
grounded metal object (a doorknob or metal desk will work, for example) before opening up the
case. This will discharge any static electricity you have built up, which could damage your
computer.
> Locate the audio plug on the back of your PC. The sound card should be in the corresponding
location on the inside of the PC. Remove the sound card and put it back in. The Microsoft site
has detailed directions for installing a sound card; to remove one, simply do the reverse. Once
you have the sound card back in, reattach the cables you unplugged earlier and boot your PC
It this steps didn't work you might consider getting a new one. Hope this help you in someway and thanks for visiting Fixya. Have a wonderful day.
Posted on May 22, 2011
My sub make a strange noise. It doesen't work anymore.Tks.
Strange noises can come from your amplifier or the sub itself. The most likely cause of the strange noise is the speaker just before it dies! If you have been using the sub-woofer at high volume levels then you probably have damaged it. Try testing the sub-woofer using a multimeter(on ohms setting) it should give you a reading from 8 to 4 ohms. Sometimes they may give readings as low as 1 ohm. When testing the speaker/sub you should hear a soft scratchy, thumping or clicking sound. This indicates that the speaker may still be working. If you don't have a multimeter try a 1.5 volt battery (say a AA), DONT USE HIGHER VOLTAGE BATTERIES they may damage the speaker! You will hear a clicking, scratching etc sound from the speaker which may indicate that it is still OK. If the speaker seems OK the problem may be in the amplifier, which I suggest you bring to a professional repairer. When buying speakers and amplifiers make sure the power handling of the speaker is equal to or greater than the amplifier output power. This should stop speakers from getting damaged. Make sure the speaker and amplifier specifications are rated in the same manner ie RMS PMPO Peak. A 100 Watt PMPO speaker will not survive the output of a 100Watt RMS amplifier!
Feb 08, 2011 | Audio Players & Recorders
901's have fried left channel on two recievers what am i doing wrong
First I would make sure that the speaker cable is not shorted.
Second I would make sure that the slpeaker itself is not shored.
You need to get some kind of ohm meeter to check this.
Jan 29, 2011 | Bose 901 VI Main / Stereo Speaker
The sound on one of my speakers is breaking up and crackling terribly, especially on songs with more bass. What can I try?
try to exchange your left and right speaker to confirm. where the cracking noise come? it could be from speaker or your amp itself. 1.if after exchange speaker, it still happen on same speaker then is your speaker already damage could be the cone edge or the coil.
2.If happen on same side from your amp, then that channel output is damage from amplifier.
Nov 16, 2010 | Acoustic Research 215 PS Speaker
Boston BA790 Subwoofer Making Strange Noises
I just took my sub apart and found that the surround on the driver speaker inside the sub was totally crumbled and lying in pieces throughout the sub box.
I'm looking around now for specs on the sub speaker so I can find a replacement.
Feb 03, 2010 | Boston Acoustics BA790 Computer Speakers
I have the klipsch sub-10 subwoofer, making noise after use
it sounds like the sub is rubbing in the voice coil.
put the speaker in upside down to what it was before.
sometimes that extra bit of downward pull is enough to offset the error.
There are speaker reconing experts out there but it is cheaper to replace the sub itself.
the sub can be replaced for sure.
Jan 13, 2010 | Audio Players & Recorders
Kicker CVR making strange noise
Check all of your car electric system... may be it's a short circuits... Then check all wirring your car audio system. May be your ground cable not installed well, or your audio connection short with ground...
Jul 18, 2009 | Kicker CompVR 05CVR84 Car Subwoofer
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
Noise from speakers when playing basses
Offhand, could either be the subwoofer speaker itself or the electronics (amp and/or crossover). One way to determine is by physcially checking the sub speaker. When playing with bass on, pls try restricting speaker movement by pressing on it and see if the noise is reduced. Another is to temporarily replace the speaker. You can try speakers meant for the car, home entertainment or book shelf, just dont set the volume too high.
If the speakers are ruled out, then it would be the electronics inside. For this, you would need familiairty with electronic components and circuittry, a DVM and a soldering iron. Access to an oscilloscope and an audio signal generator would be nice but not a necessity. The idea is to inject a constant audio signal and determine where the noise (if electronic) is coming from. In most instances, it would be a leaky electrolytic capacitor either in the input stage or feedback loop. At other times, it would be also a capacitor in the band pass filter.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 28, 2008 | Audio Players & Recorders
Im sittin here with the wiring harness for my 99 altima, and the wiring thing from the back of my pioneer deh p6700MP, i have no clue which ones to match with the other one?
Here's the manual for the Pioneer -->LINK<--.
This is the 2 options of install wiring on a 97 Altima, I'm not sure if it's exactly the same, I suggest that you don't trust these pinout if yours differ at all.
Radio Constant 12V+ Wire: Pink
Radio Switched 12V+ Wire: Blue
Radio Ground Wire: Chassis
Radio Illumination Wire: Red/Green
Radio Dimmer Wire: Red/Yellow
Antenna Trigger Wire: Green/White
Front Speaker Size: 4′ x 6′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Brown
Left Front Speaker Wire (-): Black/Red
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Black/Yellow
Rear Speaker Size: 6 1/2′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Orange
Left Rear Speaker Wire (-): Black/Pink
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Black/White
THERE IS AN ALTERNATE WIRING COLOR CODE
THERE IS NO CONTACT PIN OR EXISTING WIRE THAT IS GROUND !!!!! (some really strange things happen to aftermarket radios if you think the Red/yellow wire on pin 9 of the 10-pin connector is ground”!!!!!
Large 10-Pin Connector:
Constant Hot (Memory or Clock) =RED wire pin8
Switched (Ignition) Hor = Blue wire pin4
Left Front Speaker + = Blue/white pin1
Left Front Speaker - = Blue/yellow pin5
Right Front Speaker + = Brown pin2
Right Front Speaker - = Brown/white pin6
The Smaller (6-pin) connector is only for the rear Speaker:
Left Rear + = Red pin5
Left Rear - = Green pin4
Right Rear + = Blue pin2
Right Rear - = Pink pin6
Regards
Philip
Jul 21, 2008 | Car Audio & Video
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
Altec Lansing ACS 251 Computer Speakers Logo
189 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
