Question about Dell Inspiron Mini 10 Notebook
Upon starting my dell inspiron mini 10 I have to wait 17 min before I can use the start button. ctl+alt+dell show me the process running: system idle process is the only process running, the CPU usage is between 0 and 2% I tried to disable all the useless program at start up. I have done a system restore to a previous date.
    Guru:
  • 610 Answers
Do you have any antivirus program installed? If you have, check if it set to scan during startup. This might be the reason why your computer is slow during startup since a full computer scan can definitely eat up memory usage.
Hope this helps.
Posted on May 22, 2011
Testimonial: "Thanks I check for that. I have avast free antivirus instaled. Set to scan file at opening.in silent mode. Can it be the problem?"
  • Christopher Ian Tecson
    Christopher Ian Tecson May 22, 2011
    Yes it is the problem. Please disable the Scan at boot, as you don't really need it. Avast has real time protection anyways.
    Sergeant:
  • 170 Answers
Please reset your time and date correctly and restart your system and try again
I want to factory reset a mini 10 but screen is broke(i am using t.v) im afraid to start the process and then not be able to see anything after
Yes that could be horrid. Try setting the tv as your only screen. If you go to l settings Navigate to the "Start" menu, and click it once to open it. Select "Control Panel." Click "Adjust Screen Resolution" under "Appearance and Personalization." Click the drop-down arrow next to "Multiple Displays" in the window that opens. Select "Show Desktop Only On 2." Windows will disable the Mini 10 display and use the external monitor as the primary screen Read more: How to Run an External Monitor on a Dell Inspiron Mini 9 ' eHow.com http://www.ehow.com/how_6821296_run-dell-inspiron-mini-9.html#ixzz1hFvetaud
Nov 25, 2011 | Dell Inspiron Mini 10 Notebook
My dell mini inspiron doesn't work when i turn it on; it starts but then nothing, it is obvious that it is on but it is only a black display on the monitor. What could be the problem?
You can switch it OFF and remove the battery.
Wait for 5mins, Connect the battery again, Also connect the Power Cable to the Laptop.
Try to switch it ON, It should work.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 08, 2010 | Dell Inspiron Mini 10 Notebook
My dell inspiron mini 10 bootes up to the main sceen but no icons nor start button appear.. please help
ok try starting in safe mode, keep pressing f8 on startup till menu appears, then run system restore if safe mode works
Aug 30, 2010 | Dell Inspiron Mini 10 Notebook
All i do is click shut down but it doesnt do anything at all. what should i do?
CTL,ALT.DEL select task manager under there you should see that there is a program that is not shutting down thus causing your issue. You need to shut it down before shutting down the computer again. Otherwise hold down the power button to FORCE SHUTDOWN.
Thanks and do be considerate when leaving feedback and ratings.
May 29, 2010 | Dell Inspiron Mini 10 Notebook
Services are erased and I cannot see start button and cannot use system restore. Please help.
Hi. Press Ctrl+Alt+Del and choose Task Manager..
Click New Task and type: explorer.exe then press OK...
Your start button should appear as well as other icons... ^_^
May 21, 2010 | Dell Inspiron Mini 10 Notebook
How do I restore factory settings on my dell inspiron mini 1012?
  1. Restoring a Dell System Running Windows XP.
    Turn off and reboot your computer. When you see the Windows flash screen, depress "CTRL" and "F11". Be sure to press them simultaneously and release them simultaneously.
    Select "Restore" in the "Dell PC to restore by Symantec" window and press "Enter".
    Highlight and select "Confirm" when the message shows that you wiill lose all data if you continue. This will begin the restore process. It usually takes about 10 minutes or so. When it's done, you should receive a message that states the system recovery process was successful.
    Select "Finish" to complete the process and restart your system.
  2. Step 6 Restore a Dell System Running Windows Vista
    Shutdown and restart your computer. Keep pressing "F8" until you see the "Advanced Boot Options" menu. You must depress the keys before the Windows Logo screen appears. If you wait until after the screen appears and then press "F8", it's too late and you'll have to reboot the system and try again.
    Navigate to the "Repair your computer" option
    Select the appropriate language and click "Next".
    Sign onto the system as an administrator. Without administrative privileges, you will be unable to perform the system restore.
    Select "Dell Factory Image Restore" and click "Next".
    Place a check in the check box next to the text that says "Yes, reformat hard drive and restore System Software to factory condition" and click "Next".
    Click "Finish" to complete the process. This will reboot your computer.
May 19, 2010 | Dell Inspiron Mini 1012 Netbook PC
Fomating dell inspiron mini 10
You can make a bootable USB stick with everything you want and boot from it.
Stelios.
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
Dell Mini 10 constantly sticks - especially on the internet. Scrolling through a page, or trying to type in address bar.
Do the following: ctrl alt delete Selcet task manager. Click on the processes. Check to make sure any extra process are running. Do not stop anything you are not sure of though.
Nov 15, 2009 | Dell Inspiron Mini 10 Notebook
The wallpaper shows up but the icons don't show up. I cant get to any programs.
Does the start button work?  If not, run ctrl-alt-delete and go to processes.  Check for explorer.exe.  If it is not there, click on New Process and type EXACTLY explorer.exe and hit enter.
Jun 07, 2009 | Dell Inspiron 1501 Notebook
Delayed keyboard response on Dell Inspiron E1705 Laptop
Is the mouse response sluggish as well during these times?
In most cases, it means the computer is busy with another process. The keys you press stay in the keyboard buffer until the CPU has time to process them.
Check your CPU busy time when this happens. In Windows XP, press ctl-alt-del to start the task manager, the select the processes tab to see if one process is tying up the system (by % of CPU), or press the performance tab to see CPU usage. If it is pegged at close to 100%, something is tying up the system.
May 12, 2008 | Compaq Presario 700 470024-192 Notebook
Dell Inspiron Mini 10 Notebook Logo
145 people viewed this question
Alun Cox
