Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
After connect usb, if i go into the usb drive and try to open folders, the system hangs. then i end task those folders. then system works fine. whats the solution?
    Brigadier General:
  • 10,406 Answers
It could be your anti-virus software that is "virus-scanning" all the files on the newly-attached memory-stick. That might take a while, depending on the speed of your computer.
Does this happen on _every_ computer to which you attach your memory-stick?
Posted on May 22, 2011
Unable to access my folders and files from WG passport ultra external drive. How to fix it?
Try connecting to a different USB port and restarting computer.back USB ports are better than front ones as they connect directly to motherboard.do not panic but if this still locks out then you must connect to another computer or laptop as first stage.usually these happen when someone switches off the main machine whilst it is still writing to the external drive which can corrupt a file and cause unread ability.one you have access run a quickscan to fix files and folders on the external drive.get back to me if none of the above fixes this problem and I will point you towards some some ware to correct further likely problems.
Mar 02, 2015 | Ultra Computers & Internet
Have the SimpleTech SimpleDrive External 400GB hard drive. When I click on StorageSync I get the message "Program is already running. Can't create process". Don't know what to do? Any help?
Go to task Manager > processes tab and find the StorageSync program and end process. Unplug the drive, shut down the PC, replug and start up the Pc and try again.
Oct 29, 2008 | Computers & Internet
I am having 2tb seagate hdd .. it was working well for past 6 months.. but i was so careless i often unplug with out switching it off and unplug ing it....but now when i connect it to my system (mac os) it...
It's hard to say from your description exactly what the problem is but the first thing to do is determine the condition of the drive. You can check if there are problems with the drive from Windows using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Sep 05, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Hello, Alright, here's the problem. I have a 1 TB WD My Book external hard drive with a whole lot of data on it. The thing is, when I try to access it through My Computer it says "I:\ Access is...
Typically this occurs when the permissions on your drive have been changed. Do a search on "resetting permissions" on your external hard drive that is specific to the operating system you are using. There are paid programs that can do this but don't be afraid to is a command shell window to carryout this task (this is a window where you actually type in commands with extensions like DOS in the old days). All tutorials out there will show you exactly how to open this shell window and what exactly to type in as a command. If you are not wanting to try then ask somebody you know that is computer savvy to help you out. It's only one command but once started may take sometime to complete depending on the size of your drive and how many files are on it (could take hours).
Mar 16, 2017 | Western Digital My Book Essential 1TB...
Trying to use USB connection. Power good. Program install seems correct. When told to connect USB to computer, nothing happens (no recognition.) Have to cancel out of install. Have checked out supplied...
Following are three possible issues you can easily investigate and correct:
Upgrading DLS or Adding an Additional LabelWriter
A previous LabelWriter printer may still be installed with documents in the print queue. You must delete any documents in the print queue for all previously installed LabelWriter printers before proceeding with the installation.
1.Open the Printers folder. Based on Operating System and system configuration, the Printers folder can be accessed in one of the following ways:
Start > Settings > Printers
Start > Control Panel > Printers & Other Hardware > View installed printers or fax printers
Start > Control Panel > Printers & Faxes
2.Double-click on the LabelWriter printer, the print queue will open.
3.Delete any pending print jobs and close the print queue.
4.Reboot your computer and re-run the DLS installation.
Installing DLS and a LabelWriter for the First Time
Some antivirus or anti-spyware applications may prevent the installation of DLS and the LabelWriter printer. You may have to temporarily disable these applications in order to successfully complete the installation.
1.Restart your computer.
2.After restarting, temporarily disable any antivirus and anti-spyware applications.
3.Install DLS, connect the LabelWriter when prompted during the installation.
4.Once installation has completed, re-enable any antivirus or anti-spyware applications.
DYMO Label Software Fails to Install because Word or Outlook is Running
While installing the DYMO Label Software (DLS), prompted with a message that Word or Outlook is open. How can I resolve this?
1.Exit Word and Outlook.
2.Open Task Manager.
??¦To open Task Manager press Ctrl - Alt - Delete.
3.Click on the Processes tab in Task Manager.
4.Verify that WINWORD.EXE and OUTLOOK.EXE are not running processes. If present, select every instance of WINWORD.EXE and OUTLOOK.EXE and click on End Process.
5.Close Task Manager and reinstall DLS.
Should you require updated driver/software for your printer and operating sytem, check here.
Trust this helps resolve your installation problems. Please vote.
Dec 29, 2010 | Dymo LabelWriter 330 Thermal Printer
How do I delete or repair the threat to my Laptop system that has
HOW TO REMOVE RAILA ODINGA VIRUS IN 2 MINUTES
How to remove raila odinga virus is a very easy process. Firstly, Raila odinga is a worm that attacks Microsoft word files, but it looks like a JPG file and mostly found on the desktop.
Raila odinga has some common characteristics
1. If you delete the picture file it will delete and return to where it was.
2. It runs from the driver folder in system 32 folder
3. it auto runs at system startup
4. It makes the computer boot slowly
5. It makes your computer to hang.
6. It creates new folder.exe folders in your computer
How to remove raila odinga virus, open my computer, double click drive C: open WINDOWS folder, double click on system 32 folder, open driver folder,
locate the word file in the folder, note the name. Right click on the task bar, open task manager, click on the process tab locate the name of the word file you saw in the drive folder, right click on the name of the file, click end process, to terminate the running process
Open the driver folder of system 32 where the file is, delete all the ms word files on that folder, then close the folder locate the raila odinga picture file usually on the desktop or somewhere in your computer, delete the picture file. Please do not double click on the picture file only delete it, finally empty your recycle bin and restart your computer. That way odinga is off your machine.
Mar 25, 2010 | Computers & Internet
My samsung sp4002h is in an external box plugged in through a usb it was working fine and now it won't show up anywhere. When I go to use safely remove it hangs up and then says you can't end task because...
this issue could be :
1- errors or bad sector : right click >> properties >> tools >> check now ; check >> automatically check file system error + check scan for and attempt recovery for bad sector ,
be patiant until finish .
2- or replace your USB Cable.
Mar 07, 2010 | Samsung SpinPoint SP4002H 40 GB Hard Drive
Usb problem
after connecting your USB drive or any thing just press Ctrl+Alt+Delete to open task manager from it select shut down and restart the computer with the USB plugged in.
Jul 04, 2009 | Computers & Internet
Task bar hangs
http://www.avast.com/eng/download-avast-home.html
downlaod avast antivirus from here then install in computer then update it then scan your computer i boot time schedules mode.
then when u find virus press "1" to delete it.
Jun 23, 2009 | Microsoft Windows XP Professional SP2
System hangs
i thing your laptop is problem with virus related fist you are parchesh bootabal antivirus cd and boot form cd and remove the virus and after your laptop is working fine .....ok
May 01, 2009 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
