I have a Denon dvd player adv-500 sd. The cds or dvds wont load properly and takes ages, wont open first time and today I got the word mechanical error come upon the display I palyed some music and after 2 minutes just stopped. HELP!!!
  • terry8928 Aug 15, 2008
    That did not work
    That solution did not work
  • 19,396 Answers
Mechanical error means that there is a problem with the mechanics that spin CD and move the lens pickup.
When this happens usually yo need to take the unit apart, inspect mechanics, test motor, eventually replace or disassemble faulty mechanics and assemble unit back.
This is a job that is better done by a technician at a repair shop.
A simple operation that you can do is unplugging power cord for two minutes, this sometimes reset the unit and temporarily clear the error.
At the end of owner manual you find a support phone number. Check also your guaranty terms.
Posted on Aug 15, 2008
    Master:
  • 848 Answers
Just clean the lens in your dvd player ........
  • gopinath pasupathy Aug 15, 2008
    You should also try a hard reset..... Just make sure the power is totally removed for at least 30 minutes, then power
    it up again and see if it clears........Most likely the optical tracking has failed and the
    disc is not being read by the laser beam..... This is caused by either the laser diode
    going bad or the tracking system too far out of adjustment.....
DVD CD player will not work. Door will not open to play DVDs or CDs or MP3 player
Disc loading mechanism fault. A broken loading belt or a gear wheel can cause this. Contact any service technician. The loading mechanism have to taken our from the device, for repair. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 19, 2016 | RCA RTD209 System
Denon 700 wont accept cds
The CD loading mechanism has the fault. Check its loading belt. If it is OK, replace the loading mechanism.
Jun 03, 2012 | Audio Players & Recorders
I nudged the loading tray with my foot when changing a disc. As a result the tray is not opening or closing, presumably because it is no longer aligned properly. Is this likely to be something I might fix...
Mechanical timing and alignment is the problem of your dvd player.
This comes when you accidentally force the disc tray to close.
You need to open the cover of the dvd player..take out the dvd mechanical loading system try to eject it manually by turning the gear with your hand.
Make sure that the cd loader reaches the limit switch before it closes. This will return back the right timing and alignment.
Feb 04, 2011 | Denon DVD-1930CI DVD Player
1815 denon won't load dvds but will load cds
Hi...
Buy a DVD cleaner disk ( radio shack or walmart or best buy)
Run it a couple times
Aug 26, 2010 | Denon DVM-1815 Multi-disc DVD Player
Acer aspire 2930 DVD player only opens some dvds
Try Media player classic under k-lite codec pack. Then open video files on the dvd. If it doesn't help try another codec player. If nothing helps could it be that dvd player is not capable of multilayer dvd reading.
Apr 10, 2009 | Acer Aspire 2930-4661 Notebook
Denon 3910 won't load some dvds/cds and vibrates while trying.."disc error"!
I have the Denon 2900 (about 4 years of use) and until recently, suffered from the same (growing) problem. CD's were very difficult to start/read. I recently found advice which I tried and was succesful with. It was manually cleaning the laserlens. I took away the outer housing by unscrewing all off the on top (6), side (4) and the back (2) bolts. After that I took out the top plate of the laserunit which took two very little screws taking out. Now you are looking at the cd-tray with the lens. Take a very soft and clean cloth and moisten it a little bit with clean water (be very carefull with the moistening, don't allow any waterdrop to come out of the cloth into the laserlens while cleaning! Carefully clean the lens and dry it with a dry part of the same cloth. Replace the top plate and the outer housing and the player will recognize the discs like it's new again. Good luck! Robert Jan, The Hague the Netherlands
Dec 25, 2007 | Denon DVD-3910 DVD Player
Samsung SD 616E Internal DVD not working
I have the same problem, wont read anything in the drive. It is a master and there is no slave dirve so its not that, jumpers etc checked, drivers, cables. Just wont work.
Dec 14, 2007 | Samsung SD 616E (729507925578) Internal...
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
