Question about HP iPAQ rx1950 Pocket PC
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and they charge. When the charger is plugged into my ipaq the light blinks 10 times and then stays on solid for about 10 seconds and this repeats and does not stop unless I unplug the charger. After about 24 hours of charging I disconnect the charger and the ipaq shows that the battery has charged to 100% but after about a half hour the % drops to the original low state. I noticed on my friend's ipaq that the light blinks constantly until it has charged, then stays on solid. Is there any fix for this problem or is there such a thing as an off line charger for these batteries? If I use a battery that is correctly charged it lasts for a good amount of time and the ipaq works fine.
  • HP Master
  • 2,007 Answers
Buy a used smart phone for way less than fixing this old one.
11 years old it can be.
its now obsolete (
a uses smart phone can be as low as $20 (small)
or this. (endless choices, own or not)
Posted on Mar 31, 2017
  • HP Master
  • 20,706 Answers
Its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Posted on Mar 12, 2017
4 Suggested Answers
  • 58 Answers
SOURCE: Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Posted on Feb 05, 2008
  • 198 Answers
SOURCE: Ipaq 4155 wont turn on, dont charge, dont anything, is totally death
I had some similar experiences with these ipaq's when I was working in a specialised service center. I'll try to give some help or tips through the internet, altrough if i could have seen or diagnosticate these pda's myself it would have been more easier. First of all these problems have 2 main causes. Most of the pda's comply with one of them, it is very rare that a pda will develop this problem by having both causes.
The first cause is the hardware one. A component called the main voltage convertor is broken. It's a small chip that uses the voltage given by the main battery to convert it's value to various tensions required by some of the components on the pda's main board. If some sub-parts of this chip fails to work, the result will appear as the problem you face, In this case there isn't much to do. Most service centers will replace the whole mainboard because that particular chip is very hard to find as a replacement and difficult to desolder from the board.
The second cause could be a major firmware / ROM memory corruption. These things can happen out from nowhere. In my time working for service centers I've tried to isolate a pattern for this problem but without much succes. However it seems that most of these problem tend to appear durring charging cicles due to power spikes or drops on the main AC voltage supplied to the charger. This is only a supposition, I'm not sure yet on this cause. What to do here? Well this problems are fixable but first of all you must be sure that this is a software problem, not a hardware one. So let's diagnosticate some things.
Try to charge the pda. Ignore any lights or beeps or whatever your pda is showing on the screen. As long as the charger is connected the charging process is based on the most primary charging circuits on the pda's motherboard. If the pda is not charging or cannot hold any charge (when you unplug it the screen fades away or it simply doesn't do anything else) maybe that circuit is broken (this is a a sign of serious hardware problems ) or maybe the battery is to old/weak. Batteries don't die out of nowhere, if you remember your pda to work and have some 2-3 hours of standby time it's imposible that now, suddently the battery has drained out so much that even if charged it can't hold out at least 30 min.
So we will assume that you charged the pda for at least 2-3 hours and you see some sign that the battery is working. The next step is crucial. TRY TO PUT THE PDA IN BOOTLOADER MODE. You will achieve this by pressing (and keep them pressed!) the following buttons : power, the far left and right buttons near the control pad (joystick or whatever some people call it) and reset button. You may need another person to help you press these buttons. the order should be the following (first power, then the 2 keys, then reset button for as long as it takes to enter bootloader mode). YOU SHOULD SEE A WHITE SCREEN WITH THE HP LOGO.
If your pda fails to do that, there is nothing more you can do to restore it in a DIY fashion. Probably the bootloader is corrupted or you have a hardware fault. Only a specialised HP service center can help you now. In most cases this will end up with a motherboard replacement.
If your pda does that, then there is a chance to fix it. We will need to probe the bootloader for direct data acces. This is needed for having the ROM memory (and operating system) rewritten. A small program called Mtty will be required to access the bootloader via an usb link.
Please make this tests first and then reply with your results. If anyone of you is in situation #2 there may be a chance.
Posted on Feb 10, 2008
  • 30 Answers
SOURCE: HP IPAQ RX1950 - Installer
If for Ipaq installer you ment by Activesync this is the link:
Posted on Apr 11, 2008
Internal battery charger
Yes you can buy them on e-bay here is the link for one just charge up the battery externally and away you go I bought a second battery so I can have one on charge charging while I am using the one in the IPAQ so no down time
Dec 08, 2013 | HP iPAQ HX2490 Pocket PC
I bought a replacement hp battery for my HP Pavillion zv5000 a year ago. It was working fine for about 6-8 months. Then, it seemed to stopped storing energy even when the charging light stopped and...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 08, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have a fairly new HP iPAQ RX3115. I bought the charger today which also came with a USB cable to plug my iPAQ into my computer. When I connected my iPAQ with the USB charger, and plugged it in the...
2005 new, 12 years old, is new? really, and is no longer supported by HP, after 10 years.
my guess is the battery is toast,
never seen any battery last 12 years, ever.
not by a mile.
this thing has no value now.
if its LOVED, (why) then buy 2 and learn to fix them.
be like only on earth wanting to...
why not get a tablet.? modern.
here is all there is. RTM and get a new battery first.
Mar 02, 2017 | HP iPAQ RX3115 Pocket PC
I have an HP rz1710 pocket pc. Can't seem to get battery fully charged. It gotten worse over time. After charging overnight or all day, it still shows low battery, then displays the hp IPAQ screen with...
If the unit will work while in the charger, it is most likely the battery has reached the end of its useful life. If this is the original battery, you are quite fortunate it has lasted this long and have taken good care of it because these batteries seldom last more than a two or three years before needing replacement.
Jan 02, 2011 | HP iPAQ RZ1710 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
HP Ipaq does not turn on
Ufortunately, the battery is likely the culprit.
You can try removing the battery overnight, then leave on charger for at least 12 hours.
These batteries generally require replacement every 1-3 years. They deteriorate quite rapidly if left unused/uncharged for extended periods of time (like a year!)
Jun 25, 2009 | HP iPAQ HX2490 Pocket PC
HP PDA h1940
I just found the most protracted set of instructions to reset it for reference.
1. charge on ac only = 8 hrs
2. remove battey, soft reset, reinsert battery
3. charge on ac only = 30 minutes, remove battery, remove power, hard reset then soft reset.
4. charge on ac only = 4 hrs
5. Power off. Soft reset.
Oct 13, 2008 | HP iPAQ H1940 Pocket PC
HP Ipaq H4355 PDA charging problem
Use common sense and frequently charge the battery even when the device is not used.
Draining a battery fully often kills it permanently.
Mar 11, 2017 | HP iPAQ H4355 Pocket PC
Lying ipaq H5550!
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ rx1950 Pocket PC Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
