Question about Whirlpool Washing Machines
Whirlpool 6140/3 cycle will not start, start/pause light is lit, program is selected and door light is on
  • jacko999 Aug 15, 2008
    I have tried the solutions posted so far and th emachine still will not start!
    Genius:
  • 1,011 Answers
Try after resetting the program..
try it neutral and then restart it. what about the pump conditions, does it feel that its trying to run or not..
if it feels that it is trying for running then it can be the bushes problem or like this.. is it so?
check if u can,
the filter, pump, drum belt,
regards,
Posted on Aug 15, 2008
  • 594 Answers
What is your model number?
    Master:
  • 521 Answers
Door is not closed properly or try reset by unplugging the machine n restarting it after 5 mins.
  • tech expert12 Aug 15, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further
  • 88 Answers
Door is not close poperly
    Genius:
  • 1,847 Answers
Upluge the machina and repluge after 15 min and then try.
  • Legin Varghese
    Legin Varghese Aug 15, 2008
    if that doesnt work. check the water inlet for any blockage.
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Brand New Whirlpool Dishwasher won't start, can't change program eiether
Make sure the dishwasher door is firmly closed, press and hold the start pause button for about 5 seconds, this will clear the cycle, The try selecting a wash cycle and push start.
See if this helps.
Mar 04, 2012 | Whirlpool Dishwashers
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
"Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WASHER WON'T START
possible door latch or even the strike on door itself may be broke
Sep 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
85 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
