Question about H45 Quick DVD External DVD Drive
I got a problem with my hp external dvd drive, unable or failed to eject. I checked the properties and it indicates there that the device is working properly but still failed to eject. Could you pls. help me fix the problem. Tnks!
  • 27,725 Answers
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Posted on May 22, 2011
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
The disc medio tray will not open and will not run on hp g60
Hi I'm Rain ,
Ok follow these instructions to reboot your CD Rom drive.
  1. click start then My Computer .
  2. In My Computer right click the DVD/CD rom drive icon .
  3. In the list , Click eject to see if the drive is being reconized .
  4. If nothing happens repeat steps 1-2
Now when you get to sep 3 you will click properties .
5. In properties click Hardware .
6. In Hardware click the DVD/CD device to highlight it .
7. Click properties .
Now look to the bottom of that window to see device status .
If it says , this device is working properly .Properties .
Next click Driver . In driver you will see a list of option tabs that allows you to , Roll Back driver Update driver and Disable driver .
The other option is Driver Details.
Click Roll Back driver to restore the driver back to the state before you added the latest program . Click ok and follow the screen instructions.
If this fails , you can follow these steps to get back to Driver and chose
Disable Driver . Click ok if another window pops up.
Now what you are doing is rebooting the DVD/CD rom drive.
This will restart all the drivers that are associated with the DVD/CD rom
device .
Now follow all the steps again to get back to Driver .
Now in Driver you will need to click Enable to restart the DVD/CD rom
device . Reboot your system and try the DVD/ CD tray to see if it responds . If it still fails to respond you most likely will need to replace or service the DVD/CD Rom Hardware { the Tray } .
Jan 08, 2010 | HP G60-230US Notebook
Power producer cannot find dvd writer Help!!
1st Check to see if you have power (hit the eject button on the DVD writer). If not then you have a physical problem with the drive. If external DVD then reseat the power connections from the wall and to the drive (also reseat the USB cable from both ends). If internal drive then you would have to make sure the power is plugged in well (i doubt this problem as it almost never happens on an internal drive). If you still have no power for an eject, then you will have to get a replacement drive.
If it does eject, then check the Device Manager (right click "My Computer", select properties, Select the Hardware Tab, Click the "Device Manager" button) to see if your drive shows up. There should be a plus sign or minus sign (+)(-) in front of "DVD/CD-ROM drives". Click the plus sign if you have one, otherwise you should see your DVD writer here. If there is a "red X" on the drive, right-click it and then select "enable". Then your DVD should be active.
Otherwise if you have power and it is already in the device manager, then it is a problem with your Power Producer program and you will need to reinstall it or use another program (which you can find here http://www.thefreecountry.com/utilities/dvdcdburning.shtml) Hope this helps, Best Regards, -md
Nov 14, 2009 | Acer 7720G-602G50MN C2D...
I have a Lite-On LH20A1P dvd drive. The problem is, it starts to write and the about a minute later it kicks out the disk saying - could not perform end of Disc-at-once. Then burn process failed. Could...
-There a lot of things we may consider.I'll give some few things.
-It may be your dvd drive is not working properly.
-It maybe the setting of your dvd drive is not configure properly.
-It maybe the blank disc is having the issue not the dvd drive.
follow this steps to check and troubleshot:
-Set the dvd region
right click on my computer select properties, go to device manager click the + sign under dvd drive, right click on you dvd drive-choose dvd region.
-Enabling CD recording
Click on My Computer-right click on dvd cdrom drive-go to properties-select recording, then check if the Enable CD recording has a check on its box, then check the box that says Automatically eject the CD after writing.
If this steps will not work then send me feedback so we can move on to the next level of troubleshooting.
Oct 12, 2008 | Lite On Computers & Internet
I o magic external dvd burner wont work
most likey it is incompatlable with vista ? did you check the specks lala linda
Aug 14, 2008 | Computers & Internet
Dvd combo not reading/writing any CD
since the device can't identify a disc anymore it is adviseable to get another.
Uzowuanya
e-mail: uzowuanya@yahoo.ca
Feb 13, 2008 | Computers & Internet
HP DV2000 DVD CD ROM ejects
Check the system hardware properties.
right click on my computer icon --> choose Properties
System properties will pop up. go to Hardware tab --> click on Device manager. there all the hardware install on yr machine will display choose your DVD drive and check the property of drive.
if it is working file.
you just update your dvd drive. iether from web or from a driver cd came with your machine
Dec 25, 2007 | Acer Aspire One PC Notebook
Drive wont open/eject
try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the notebook and then the drive will be re installed with drivers automatically. it may be a firmware or driver error.
Apr 17, 2007 | LG GSA 4163B DVD±RW Dual Layer Burner
Hp z558
This sounds like a poor put together pc. If the DVD drive does not eject then either the dvd is faulty or the IDE cable and/or IDE1 connector on motherboard is not installed, try ejecting through my computer(right click on drive then Eject), if this works the button is faulty. The same goes for the TV Tuner card, again possibly a corrupt or non installed driver, try re installing mother board drivers and card drivers. This really needs to be returned as the pc is not fit for it's use.
Feb 19, 2007 | HP z558 (EG652AA) PC Desktop
H45 Quick DVD External DVD Drive Logo
129 people viewed this question
Top H45 Computers & Internet Experts
David Payne
David Payne
Are you a H45 Computer and Internet Expert? Answer questions, earn points and help others
