Resetting garage door using remote control firmadoor
  • 25 Answers
SOURCE: Garage door will not close from remote or car.
wI have never heard of this problem. you have to hold the button on your wall in to close the door. no way this is not right something wrong with your board insid the opener. get help from a pro. I would love to see this been doing this for 20 years never heard of this.
Posted on Jun 20, 2009
handygirl911
  • 65 Answers
SOURCE: garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Posted on Jul 22, 2009
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
FixinFax
  • 3085 Answers
SOURCE: I have an older Overhead Door Garage door opener,
The sender (remote) switches must match the switches in the lift motor case
Posted on Jun 11, 2010
swolfinor
  • 504 Answers
SOURCE: remote will not open garage door but the door still works
CHECK TO SEE IF THE LED ON THE WALL CONTROL IS FLASHING.
IF IT IS THE LOCK / VACATION SWITCH HAS BEEN ACTIVATED. THIS IS USSUALLY A SMALLER BUTTON ON THE WALL CONTROL OR A SMALL SWITCH ON THE WALL CONTROL.
WHEN THIS HAS BEEN SET TO UNLOCK THE UNIT, ALL OF YOUR REMOTE FUNTIONS SHOULD WORK.
Posted on Jun 16, 2010
I need the remote to my Genie Trac-Drive, model 250. It was not left in the home I bought. Any suggestion?
Hello, Teresa -
If you have not yet contacted the previous home owner and asked for the remote control/s for your garage door opener, do so.
Otherwise, there may be a business card, stuck in behind the garage door opener button on the garage wall, which advertises the garage door repair company which previously serviced the garage door. If so, call that company and ask to purchase the proper replacement garage door remote control/s for your garage door.
If there is no garage door repair business card, then use Yelp
( https://www.yelp.com/
- garage door repair) or Yellow Pages
( https://www.yellowpages.com/
- garage door repair) to find a local business, contact that business, and ask to purchase a replacement garage door remote control.
Best wishes.
Apr 12, 2018 | Televison & Video
Help truck was stolen, I used remote control to "teach" truck how to open door... I reset door opener and relearned the remote..my question is do the remote have a new entry code when I learn, or remote is...
Ounce you reset ALL code of the garage door opener (engine hook up to the ceiling of the garage that open up the door), ounce you press the reset button on the unit, it disable all transmitter (portable or the one install in your vehicle). Your garage door opener has a receiver in it and your all units that you press on to open the door are the transmitter, so by pressing the reset button on the door opener, you erase all codes of all the transmitter that where programmed to open-up that door.
So if you teach your vehicle using a portable unit and you now reprogram your new vehicle with the SAME portable transmitter, then yes who ever has your stolen vehicle can come back with your stolen vehicle to your house and open up your garage door since you re-programmed the door opener using the SAME transmitter same code sent to the unite to active it).
Buy a new transmitter to re-programmed your new vehicle
Jul 13, 2014 | Building Materials
Want to reset my garage remote control to sync with garage base
Garage doors will either have a manual sync. On the side of the main unit where the lights are you may see a bunch of toggle switches. These are the manual switches to configure your doors "code" Otherwise the door will be digital sync. In this type you will usually press and release the sync button on the garage door unit then press and release the sync button on the remote.
Dec 18, 2012 | Televison & Video
Batteries need changing in the garage door remote control. It requires the code to be reset but the previous owners of the house left no information. It is a Wayne Dalton, Magic Touch, Model Number...
Using a step stool reah up and remove the plastic light cover from the garage door opener and the the code setting instructions are written on its panel. Or seach on LiftMaster.com for help.
Jul 26, 2011 | liftmaster Remote Light Control Garage...
Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not respond to security plus remotes
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Remote will not open garage door but the door still works
Nov 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Jun 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Computers & Internet Logo
280 people viewed this question
David Payne
David Payne
