Booting problem...my laptop gets power off within 5to10 mins..while running...
  • 32,281 Answers
If you are notusing your laptop on a flat surface, it may be obstructing the cooling vents onthe bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust. A laptop fanassisted cooling pad may solve your problem
Posted on May 22, 2011
Lenovo z570 not powering on
Measure the voltage at the AC Adapter plug, and see if it is within 5-10% of the rated voltage. If the voltage is not correct, then the battery will most likely not be charging, and the system will drain the battery and die in the middle of what it was doing...booting in your case.
You can tell how much voltage is remaining in your battery and if it is charging by checking the blinking of the battery status light.
Download the Hardware Maintenance Manual here:
http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Z370&Z470&Z570/Lenovo%20Z370Z470Z570%20Hardware%20Maintenance%20Manual%20V1.0.pdf
and go to page 30 and look at item 7 under battery status for blinking light meaning.
1. Blinking amber: (500ms off/1s on)
The remaining power of the battery is less than 5% of
its capacity.
2. Blinking amber: (100ms off/3.2s on)
The battery is being charged with the remaining
power between 5% and 20% of its capacity.
3. Amber: The computer is operating on battery power with the
remaining power between 5% and 20% of its
capacity
With the AC Adapter plugged in, and giving the correct voltage, If you are getting 1. Blinking Amber (light on for 1 sec, off for 1/2 second), then the battery is not being charged. Could be AC Adapter, Battery or Battery Circuit on motherboard. If the light is solid on 3. Amber, then the battery is not charging, and is draining.
Also make sure the power socket on the laptop is not loose or damaged. If it is, then it will need to be replaced.
I hope this gets you in the right direction.
Apr 25, 2014 | Lenovo IdeaPad Z570 Notebook
I am using toshiba L395 T5800..after booting into vista os its getting my screen into black or blue colour within 10 min.i couldn't run my os.i have to switch it off and then have to start my lap..kindly...
Well, it could be the motherboard or the screen.
Plug an external screen in to the laptop and check. If it is still faulty, you have a motherboard error otherwise it is the screen.
There is a possibility, before we order a new motherboard, that you have a virus attacking the VGA ?Processor, so run an anti virus programme.
Hope that helps.
Jan 27, 2011 | Toshiba Satellite Pro L300 Notebook
My screen is black it sound as if it is starting up but the screen stays black
The motherboard is cooked. There is a fix that might work breifly if you need to try and salvage your files. 1 power on. (lights and fan are running but nobodies home) place thelaptop in a bag for about 20 min. (it will get really hot) now hold down the power button unroll it is off. Now try booting. Sometimes holding down f10 as you power on helps.
Oct 11, 2010 | HP Pavilion dv2000t Notebook
Dt 125 2001 starts and runs ok on tick over take it out for a run after about 1 min it cuts out leave for 5to10 mins and it will start again changed coil pack and spark plug cap and spark plug stripped and...
make sure bike is not overheatin!-carb may need overhaul-u disasemble n put in solvent-or mite just need jets worked-either way a manual bought or in library is paramount
Jan 22, 2010 | 2000 Yamaha DT 125 R
96 explorer runs good for 5to10 minutes then looses power when cooled off does same thing did complete tune up and still does samething
First things first... Check vacuum. It should be steady at 18-22 in. Hg. (inches of Mercury). You'll need a vacuum guage...you can buy or rent one at one of the local parts stores. while the engine off, disconnect the Power brake booster vacuum hose and plug guage into the hose going to the intake manifold, (you might need a larger adapter to fit that hose, it should be in the plastic box along with other fittings)...
Start the vehicle and watch the guage over the course of 5-10 min. If the vacuum drops, you have a plugged exhaust system. If that is the case. You'll need to figure out if it's the muffler or one or more of the Catalytic converters.
Oct 12, 2009 | 1996 Ford Explorer
I have a pc w/ asus k8v-mx mobo, the problem is it
scan for virus, if it is not a virus change the power supply unit.
Aug 14, 2009 | ASUS K8V-MX Motherboard
My Acer Aspire 5920 gets very hot within 20-30 mins of booting it up with the fan running on high speed to cool it down, everything then slows down and it almost stalls. The sound is very draggy and sounds...
The heatsink vents and fan could be clogged with dust. Remove the dust etc from the vents/fan, may have to remove vent panels to get to the hearsink fan assembly.
If the laptop has vents on the bottom, use the laptop on a flat surface to get good airflow, or purchase a fan assisted base that gives boosted airflow to the bottom of the laptop.
Jun 21, 2009 | Acer Aspire 5920-6727 Notebook
Toshiba laptop that shuts off 5 min after booting up
Hi
The problem is processor is getting too hot.Please consult to hardware technician about the problem.This may also result in loosing your processor also
May 20, 2008 | Computers & Internet
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
