Question about KitchenAid Refrigerators
Have Kitchen Aide Side by Side with ice and water in door. Model KSRG25FKS16. Lost power for 8 days due to Tornado's when got power back ice maker will not work replace water pump and blew air through water hose is not constricted or blocked. Have thawed out and still does not work. Does anyone have any suggestions and water works in door just no water going into ie tray.
  • 489 Answers
SOURCE: water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
Posted on Jun 08, 2008
geemarie
  • 876 Answers
SOURCE: ice maker kitchenaid
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Posted on Aug 01, 2008
  • 41 Answers
SOURCE: ice maker stopped working
take off the cover to your icemaker and make sure the 2 tabs in the center of the main gear are in tack and not broken or bent. if they are, the ice maker module will need to be replaced. if that is okay, check the fill tube in the back of the freezer that goes to the icemaker and make sure it is not frozen. if it is, it will need to be thawed. your water filter may be plugged and need replaced. if all those are ok, then there may be an issue with the water valve itself. Joe
Posted on Nov 18, 2008
  • 30 Answers
SOURCE: red light on ice maker blinking twice, no ice.
I would assume you are referring to the ice level sensor that is on the center divider. It is normal for it to blink if the door is open. You can test out this theory by holding the flap on the left side closed but not blocking the sensor. The light should go steady. If the ice maker is not working then you either need to change the lazer sensor or the ice maker itself.
Posted on Feb 01, 2009
SOURCE: no water flow to the ice maker
Here's a kinda clumsy solution: I had a similar problem--for several years I'd manually pour in just enough water to fill the spaces. Sometimes the ice maker would then start to work again for a couple of weeks. We have hard water, so I assume it's a problem related to minerals building up somewhere.
Anyway, most recently, I had some cubes frozen in the bottom of the drawer so grabbed the drawer and pounded it in and out a couple of times, bumping it onto the back wall a couple of times. Voila, the maker started making cubes. Now every time I get cubes, I first pull out the drawer halfway and then shove it against the back wall. ...seems to work--the drawer is always filled to the brim no matter how much ice I take. It's been a couple of months now so seems to be working...
Posted on Mar 21, 2009
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
Side by side kitchen aide 48"
What is the model number of the unit?
Nov 12, 2012 | Refrigerators
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Does not make ice
look inside the tray their should be an metal arm that may be stuck due to ice build up
Apr 26, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a kitchen aide side by side. Icemaker not working. Purchased new icemaker (Whirlpool 4322658A) and new optics. Old optics were bad, old icemaker mold heater burned out. New optics check out fine....
Good day,
Well your savvy, so, let's do it backwards.
Pull the power plug off of the water valve, and insert both prongs from a vom meter set at 150 Ac or higher.
Cycle the ice maker. You have time, fill is at the end of the cycle.
Just before the end of the cycle you should see 120 volts for approx. 7 seconds. Don't blink.
If you do get power, replace the valve. Jumping them will not always do the trick.
If no luck, then it has to be an ice maker issue. I've installed more than one that never worked from the time of installation.
P.S. You said the water line was not frozen. It's the fill tube that runs from the back of the machine into the ice maker that freezes and is a common problem.
If you can, remove the plastic tube from the bottom of the ice maker (it's the 1/4" inch smaller of the two if you have water in the door). You should be able to blow thru it freely. If not it's iced, problem with a filter ect.
This should be done first.
Thanks for using FixYa.
Dec 19, 2009 | Refrigerators
Kitchen aide ksrg22ftss fridge wont make ice and
check your fill solenoid located at the bottom back of fride the valve may have a verry fine filter inside the valve ether clean it or replase the valve valve cost aprox 20,00 thanks from gilles
Mar 15, 2009 | Refrigerators
Kitchenaid Icemaker with Aqua Sense is not working.
If the freezer was shut off for a time, then the water in the feed tube may have frozen when the freezer was turned back on. Check to see if there is ice in the mold. If empty, then the feed tube is clogged or frozen (or else the water inlet valve may have failed, less likely).
Feb 26, 2009 | KitchenAid 22.0 cu. ft. Side-By-Side...
Red light on ice maker blinking twice, no ice.
Feb 01, 2009 | KitchenAid KSRG25FK Side by Side...
Ice Maker not working
Hi!!! your ice maker might have frozen over and gears are stuck..remove your ice maker and unplugg from the frig clean it and all is resolved..
Jan 04, 2009 | Refrigerators
WATER WILL NOT GO INTO ICE MAKER. BUT IT DOES DISPENSE THOUGH THE DOOR
hi. thanks for the question. first is the arm on the ice maker up. or down . should be down.On the back of ice maker, a small tube, that lets water into the ice maker .sometimes it can freeze up .not allowing the water to flow ,in the ice maker .check that. the next check, is the water valve behind the fridge ,at the water source. thanks the appliance doc
Oct 02, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
