Question about Toshiba SD-6200 Multi-disc DVD Player
My toshiba SD-5200 is saying "disc error" when discs are loaded in either draw. These are discs that used to work.
  • 1 more comment
  • Jason May 22, 2011
    Hi bobhifi, the drive is ok. It will play cd's but not dvd's. It can't read the DVD format. Hope this is more useful info. Jason.
    Hi bobhifi, it is spinning OK. It is playing cd's but not DVD's for some reason. These are DVD's that the player used to play all the time. It's like it has forgotten how to read DVD language.
    I have a toshiba SD-5200 DVD player which has forgotten how to read DVD's. It will play CD's OK. The erroe message is "disc error" when a DVD is put in either draw.
  • Toshiba Master
  • 2,098 Answers
"Disc Error" or in some brand also known as "bad disc/no disc error" will be encountered once the processor fail to read the disc loaded to the unit. Here are some steps that may help you regarding the symptoms.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a CD/DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
Load the disc into the tray and play it to the unit. Observe if the disc try to spin or not, or the disc spin slowly, if so then check the spindle motor.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 22, 2011
  • 635 Answers
There is a simple test you can do to find out if the disc is spinning at all or not.
Eject the tray, place a disc with the title parallel to the front ( the writing should be readable with out bending your neck ). Close the tray and after you you get the disc error notice eject the tray, see how the disc is sitting on the tray. If its exactly as it was when you loaded it means that the disc is not spinning.
Open the top cover after unplugging the power cord . Plug the power cord and eject the lower tray. Unplug the power cord and using a cotton ear bud gently clean the optic lens ( looks like a fish eye ).
The optic lens is under a protective plastic plate to prevent you from directly looking at it and causing retina damage. Look from the side to see the lens.
After cleaning insert a disk and try playing while keeping the top lid open. If it still does not spin and load the disc its time to replace the optical unit. Will cost you about 20$ plus service charges. You will need professional help for that.
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
My toshiba sd-3205 will not load any of my DVDs anymore, the discs I insert into the player are in perfect condition and have loaded previously when the DVD player was working. it always says...
Probably dirty pick up lens.
Get a lens cleaning disc and run that and see if that cures problem.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba SD-3205 Multi-disc DVD Player
Won't load DVD
call support from manufacturer on how to reset your player,
For instance, on Samsung players after it is powered on you hold in both channel buttons for 10 sec and the player restarts. that fixed mine that had the same problem
Apr 21, 2009 | Televison & Video
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Toshiba dvd player - SD-1200
Its actually in the troubleshooting manual. Pg 126. Try putting in the disk with the label face up, that might work too,
regards
Jim
Dec 22, 2007 | Toshiba SD-1200 DVD Player
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
DVD player - ERR
error in any disk i put in!!!!!!!!!
Nov 14, 2007 | Toshiba SD-V280 DVD Player/VCR
Disc Read Error
This is the problem with your dvd player's lance so you need to repair it from your Toshiba DVD/VCR Home Theater System provider. and after replacing it u have to take care of it. do not use crashed disks . Use lance cleaner liquid to clean lance .
Aug 10, 2007 | Toshiba SD-V57HT System
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Toshiba SD-6200 Multi-disc DVD Player Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
