Question about Petzl Camping, Backpacking & Hiking
Head lamp seems to have a short inside , light will some times come on then just drop out, b pretty shaw where the wire connects to the inside, head lamp not old at all
  • 178 Answers
SOURCE: Park lamps
sounds like you have a short or defective headlamp switch switch contacts are probaly grounding internaly to hot
Posted on Sep 12, 2008
TimtheStick
  • 83 Answers
SOURCE: head lamp keeps burning out. replaced head lamp at
You either have a bad ground or the bad electrical connection at the light socket is "simulating" a bad ground. This is putting a high resistance on the bulb and it's taking it's toll by burning out the bulb. I would start with a new socket, and CHECK the ground. If you still have the issue, I would run another complete ground wire and not even worry about checking the ground itself. the Stick
Posted on Dec 10, 2009
SQUIRESXX
  • 486 Answers
SOURCE: 02 silverado, turn signals stop working when
bad earth/ground in the light clusters causing power to use other bulbs as earth / ground
Posted on Dec 27, 2009
  • 157 Answers
SOURCE: Replaced head light lamp on
Did you happen to check and see if the bulb is blown?
Posted on Feb 06, 2011
  • 14585 Answers
SOURCE: Trying to disconnect old wiring
The head light assembly comes out in one piece. There are two clips (usually white or black) in the frame just behind the headlights. Pull them up and the assembly will pull forward. Made this way to replace the bulbs. On some models the assembly will stick at the corner, this is just a plug holding it, tug on it and it will come loose and wont break.
Posted on Jul 20, 2011
Brake lights 1999 jeep. When head lights turn on, the third brake light works the other two go dead. during the day they(brakes?) work, but brakes are dim, with HL on, any help??
If the brake lights are to american system ?? then maybe a new switch .If europeon system then ??? i would start looking at the wiring loom on the tailgate door to body in the rubber boot .
Dec 17, 2016 | Jeep Cars & Trucks
Neither headlights working or fog lights any ideas please
First check for blown fuses (a blown fuse indicates there is a short in the lighting circuit ) and check any defective relays. When vehicles are operated with the fog lights on all the time this causes the wiring for the associated circuit(s) to operate at a higher temperature and eventually it will result in a burned out non-conductive connection. Usually the wire(s) burn out where they are connected to switches, at the headlamps, fog lamps etc... Also check for a burned out connection or a melted terminal contact board used for the high beam-low beam switch which is usually located inside the steering column.
Good luck.
Oct 29, 2014 | 2005 Renault Megane Scenic
What makes the jeep grand Cherokee limited dash lights flicker
The auto head lamp light sensor is connected ahead of the instrument light feed. Maybe, just maybe, that sensor is doing quirky things to the instrument lamp power feed and other interior lamps as well
Sep 25, 2012 | Jeep 1997 Grand Cherokee Limited
Short circuit in Stratoliner passing lamps
Hi, Doug you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away from the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable free downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Need help passing lamp probs
passing lights
Yamaha XV19SX Service Manual
OEM parts for Yamaha
Yamaha STAR XV19CSX Owner Manual
Jul 30, 2012 | 2009 Yamaha Stratoliner
My gpz500s keeps blowing the lighting fuse, on start up (with lights switched on) any idea's as to what may be causing this?
assuming it is the correct amp fuse there is possibly a short in the system somewhere.
check for broken wires, often jammed by the steering head, damage to the switch blocks, or the head lamp or tail bulb can short out inside, remove these one at a time and see if this helps
Feb 24, 2011 | kawasaki GPZ 500 S - GPX 500 R Motorcycles
I experienced a recent front end collision. After replacing the right head lamp assembly the lamp is very dim when on. I switched out lamps - connected right (dim) lamp with the left and it lights...
Sounds like a bad Earth connection. Check for a poor/loose Earth wire bolt inside the engine bay near the head lights. Also check any of the plastic block connectors in the wiring loom for the head lights. Sometimes the metal spade connections are not secured properly within the plastic block and can be pushed back when the plastic blocks are joined together.
Oct 18, 2010 | 2005 Chevrolet Impala
Head lamp keeps burning out. replaced head lamp at
Dec 10, 2009 | 2006 Suzuki Grand Vitara
I have turn signals marker lights interior light brake back up but no head lamps
Electrical problems at times are hard to diagnose without being present. If all other lights are working i would start by checking fueses and relays. If your fues for the head light circuit is burnt out you have a wire that is shorted to ground. Do you know that both bulbs are known to be good? If everything else seems to be ok I would check the switch by getting a manual with an electrical schematics. By locating the head lamp circuit and test the wires coming out of the switch for power with a test light or multi meter. You can probe the back of the connectors with a paper clip. If no power is present when switch is operated it should probably be replaced.
Oct 29, 2009 | 1993 Dodge Dakota
Brake light work fine as longs as the head lights are off. Once you turn on the head lights the brakes with the exception of the center light on top.
Check the bulb sockets, it is common on these vans that water gets into the bulb sockets and shorts out the socket. You may need to replace the sockets to get them to work again. Also check the bulbs as these are dual filament bulbs, when your lights are off and you step on the brake it lights the parking lamp filament. However as the lights are on the brake lights may seem to not work as the parking lamps are already on.
Aug 09, 2008 | 2001 Chevrolet Express
Camping, Backpacking & Hiking Logo
Top Petzl Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Petzl Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
