Question about Canon LASER SHOT LBP-2900 Printer
My printer automatically printing the same documents every time and producing sound so please help me quickly
    Guru:
  • 610 Answers
You have to clear the print spooler to correct this.
To do that, go to START then RUN. Type services,msc and press ENTER. This should pull up another window that contains the services that running on the background. Look for "printer spooler" service and click on STOP to stop the service. After stopping, restart the service again and then try to print a new document. This should remove the "stuck" document from the spooler.
Hope this helps.
Posted on May 22, 2011
What is a PCL Error Press Set?
This is a somewhat generic error. It may indicate a problem printing that specific job (document). Sometimes a large or complex job can produce such an error such as a graphic intensive Word document or a large PDF.
You will want to first cancel any pending jobs.
Press Set on the printer.
Turn the printer off, wait 30 seconds, then turn it back on.
It doesn't hurt to restart your computer, too.
You can try printing the job again. If the same error is produced, try printing it from another application or from another computer. If that still fails, try printing the documents in smaller chunks. If the document is 100 pages long, try 25 at a time.
If the problem persists, you may want to consider how it is connected to your computer. If you are using a parallel port cable (fat cable with fat connectors on each end) you may want to switch to a USB connection. You will likely have to reinstall the printer using the driver CD that came in the box or by downloading the drivers from Dell's website. Though, if you have a newer operating system such as Windows 7 it may install automatically.
Mar 01, 2011 | Dell 3000cn Laser Printer
Check document, however there is no document to
check document on your canon ImageClass means that you need to check the ADF (Automatic Document Feeder) the feeder on the top of your printer. open it check for any paper inside .. if nothing turn off the printer and unplug from the wall.. wait for 30 seconds plug back in the power plug and turn back on.. let me know
Mar 31, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
HP 1315xi psc all in one error offline
Go to Control Panel- Printers
Right-click on your printer and click on Use Printer Online.
Hope this helps!
Aug 03, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer status- error offline
first go to services.msc refresh the spooler service. then insert the printer disc in to the computer . do a level 2 uninstallation .
restart the computer then again again reinstall the software issue will resolved
Printing multiple test pages
Check for a sticking button on the printer itself. The big Green button will produce a test print if pushed. Also try disconnecting it from the wall outlet overnight to reset it.
Jul 27, 2017 | HP LaserJet 1320 Printer
Scanner doesn't scan or transmit document to pc
My printer does the same. And it's my third Canon printer and ever time when I try to scan a picture or etc. it just ends up saying that the printer can't communicate or that it's shut off. :(
Nov 14, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Scanned Items or Copies all print in Solid Black
I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
Color Image Prints in Black and White
Good luck.
Sep 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Black Lines
Hi
Please try with replacing the INK catridge, it will solve your problem
Boopathy.T
Aug 17, 2008 | Lexmark X6170 All-In-One InkJet Printer
Printer print blue instead of black
I have the same problem with my ip 5200, when printing a document in plain black.. I spoke to canon support and they suggested to save the .doc document as a txt file before printing. It works. Not too sure if this uses any colour ink to produce the black.
You can also set the printer on grayscale. However, the printer uses the colour ink to produce black.... hence printing in black & white becomes rather expensive.
If anyone has drivers to fix this problem please let me know...
Jul 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Enquiry for best latest machine
The 856o is solid ink printer. DN is the duplex version of the 8560. Price should be less then $900.
All print features are available on it. The hard drive is optional.
  • Rich, vibrant colors on everything from cover-weight stock to recycled paper
  • Adobe PostScript 3 and automatic color enhancement tools ensure reliable and accurate prints learn about Xerox Color Correction (PDF)
  • 2400 FinePoint™ print resolution produces incredible detail and halftones you'll be proud to share
  • Consistent, vivid color from the first page to the last
collapse_off.gif more features
  • No penalty for color because the Phaser 8560 prints black-and-white and color at the same fast speed
  • High monthly duty cycle of up to 85,000 images means you'll get a reliable color printer that will last for many years to come
Features that Enhance Ease-of-use
  • Easy to install on your network with only a few clicks See how easy it is to install
  • No toner cartridges! Just drop the no-mess ink sticks into the Phaser 8560's shape-coded slots, close the cover and you're done
  • Instant on-screen alert notification and help when a print job needs attention thanks to Xerox PrintingScout™ technology
  • Access device and job status as well as accounting information from your computer via the Xerox CentreWare® IS Embedded Web Server
  • Prints are secure with Saved Print feature, which won't print your job until you enter your PIN on the front panel (requires hard drive)
  • Electronically "shreds" data stored on the hard drive after every job or on request (requires hard drive)
  • Real-time paper tray status on your desktop shows all available media types and sizes
  • Up to four paper trays can a hold a variety of media types and sizes
  • Automated online troubleshooting with PhaserSMART™ gets you back to work fast
  • Booklet printing feature automatically arranges your document so you can easily fold and staple it into a booklet (requires two-sided printing)
  • Job completion notification lets you know when your print job is finished
  • Run Black allows printing to continue in black-and-white if one or more of the color toners are depleted
  • Print With feature prints your current job (such as a cover letter) along with other jobs stored on the printer's hard drive that you specify (such as a brochure or two)
  • Personal Print feature can create your own private mailbox on the printer's hard drive where your processed print jobs are stored for quick printing via the front panel or embedded web server
Software Solutions Digitize . . . Organize . . . Distribute . . . Collaborate
With digital documents, you can easily create, search, re-use, and build upon your documents. Maximize your hardware investments with innovative software solutions from Xerox and Xerox Business Partners:
  • Contain costs
  • Share knowledge
  • Accelerate workflow
  • Integrate paper and electronic documents
  • Manage and distribute documents effectively
> Show me the Software Solutions
Pricing Details Prices do not include applicable taxes, shipping, or handling charges and are subject to change without notice. Products are available to qualified business customers installing in the US; subject to applicable terms and conditions, and may be either Newly Manufactured, Factory Produced New Model or Remanufactured; which have been produced to a Xerox pre-determined standard and may contain both new components and recycled components that are reconditioned.
1 Average standard pages. Average Continuous Composite CMY Yield in accordance with ISO/IEC 24711. Yield will vary based on image, area coverage and print mode. Read our Consumable yields guide (PDF) for more information.
2 Approximate pages. Declared Yield on Drums based on an average job size of 3 pages A4/letter size. Declared Yield on Fusers based on A4/letter size 20 lb (75 gsm) pages. Drum and Fuser Yields will vary based on job run length, media type, size, weight, orientation, and usage patterns. Read our Consumable yields guide (PDF) for more information.
Mar 07, 2008 | Xerox Phaser 8560DN Laser Printer
Canon LASER SHOT LBP-2900 Printer Logo
old marine
old marine
