Question about Dometic Rooftop RV Air Conditioner
Duo-Therm Brisk Air Model 59516.601 Ducted Roof Air w/wall thermostat
I have a ten year old Sooner horse trailer with living quarters and it is equipped with a Duo-Therm Brisk Air ducted roof air w/wall thermostat (Model 59516.601). The fan will run at all speeds, the heat strip seems okay, but when I turn on the A/C mode, the compressor will come on after about a 10 second delay (which was normal) and then try to run (low groan) for about 3-5 seconds before kicking off due to pulling too many amps. I have a volt-a-check in a 110 plug in and it draws down the amps all the way to the left on the volt-a-check meter (guesstimate of somewhere around 50 amps). Of course the compressor should run at a minimum of 110+ and usually runs at least that or better. I will not run the A/C if there is not enough voltage as I know I can burn up the compressor or blow a capacitor. I never have been able to run the A/C and the microwave simultaneously as it will trip the breaker at my 110 source. The first sign of trouble that I had was when I was I came home from a camping trip Memorial Day 2008 and plugged back into my home outlet and turned on the A/C to cool down the unit before unpacking it. I came out about three hours later to find that I had water dripping all over the dinette table from the A/C. It was cooling, but I immediately turned off the A/C and started mopping up. I took down the inside plastic vent screen and dried out the filter mesh. The voltage seemed okay, so I just let the fan run on low and dried everything out. The next trip out on July 4th, the A/C seemed okay when I ran it while packing the trailer before leaving home. I did have a bit of dirt rattle through the ducts when I turned on the fan and some tiny mud chunks like that of a mud dabber wasp nest or spider blew out of the roof ducts. Upon arrival at the campground, I could not get the A/C to work. It did what I mentioned above as far as the way the compressor does not kick in, but no water this time. The amperage at the campsite was fine (microwave worked great) and the volt-a-check measured above 110 amps. Only when turning on the A/C did the compressor pull down the amps and not want to run and tripped the 30 amp breaker on the site pole. Thanks for your help! Hot Horse Lady from the Hoosier State.
  • Dometic Master
  • 6,674 Answers
First of all, I think you mean 110 volts on your meter, not amps, just so we're on the same page. It sounds to me like you may have a capacitor problem on your compressor. I'll try to see if I can find you a part # if you have someone very experienced with electrical that can change it for you. they can be a little dangerous, so only someone familar with them should work with it. What the capacitor basically does is store voltage and uses it to help the big draw on start-up of the compressor, kind of like giving it a boost to get it started, and after it's up and running, all should be well if everything else is up to snuff. How old is the AC unit? Did it run well for you in the past? I'm asking this just in case it was a recent installation, with perhaps wrong size wire used. Should be minimum 12/2 , with 20amp breaker,if that means anything to you, or your mechanic.
Posted on Aug 15, 2008
Dometic 457915 roof air wont shut off automaticly
check fan wiring on board possible bad control board
Jun 13, 2012 | Dometic 457915 Duo Therm Brisk Air...
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Does anyone know if a Duo Therm model 620515.331c is ducted or not???
The upper unit itself is not ducted. They are all the same. The ducting is done with the lower unit or "Ceiling Pack" of the air conditioner. You need to see your RV is ducted, ie...vents in the ceiling that blow the are out. Usually they are round and mount into the ceiling. Another way to tell is if the unit has a wall mounted thermostat.
Hope this helps,
Jeff
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm penquin 630215 went out, replace with what??
Actually thats a, Great Idea. And far Less Expensive.
1: The only thing i suggest is, Remember that a "Thermostats" Job is to Sense when the Temperature in the room is satisfied it Kicks off the Compressor, That is its Job.
2: The Front is Desinged to Cool Just the Front Area.
3: You Have 2 options
1: Close the Rear door when just Using the "Front Unit"
2; If you choose to Leave the "Rear Door" Open, Just make sure the "Rear Unit" is on Making the "Front Unit" Work far less.
You will be fine
Please Rate me, Thanks George
Apr 27, 2009 | Dometic Rooftop RV Air Conditioner
Dometic air conditioner
1The air coditioner does run on Electric. 110V 2. No you do not have to unhook the battery 3. Yes you need to put water in the hot water heater so you do not burn the unit up.
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,107 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
